It's against my rules to be greater than 80" away from you.
  #61   Spotlight this post!
Unread 06-03-2006, 19:10
Bharat Nain's Avatar
Re: The 8.2 (or 8.3) Battery Voltage Bug
I have a 2004 upgraded to a 2006 RC sitting at my house. I will try to get a battery and try to reproduce the results. Since we were also having similar problems through the day, I would be glad to test out anything suspectible. Please get in contact with me if you think you have a possible solution to this problem or a way to get there. I never spent time at NJ trying to correct the bug. I just replaced the battery. Thanks
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
  #62   Spotlight this post!
Unread 06-03-2006, 19:17
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
-Bharat
Try downgrading your controller to the v11 master code. I'm wondering if something got messed up in the v12 master code.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
  #63   Spotlight this post!
Unread 06-03-2006, 20:56
Eldarion's Avatar
OK, I might have figured this out:
Has anyone noticed if the red "Code Error" LED on the OI is steadily on during the 8.3-volt bug?
I was doing some experimenting with the 2005 RC upgraded to v12 of the master firmware. Taking the advice of another person in this thread, I tried downloading frc_gyro.hex to the controller, at which point I was greeted with the 8.3V display and a solid red Code Error light. The interesting thing about this was that the Program State LED on the RC was steadily orange and the RC was ready to accept programming?
On power off / power on, the RC errored with a BLROD. I tried recompiling frc_gyro for the 18F8520, and it worked fine.
My thought is that maybe the 8.3V display is one manifestation of the sequence that is supposed to trigger a BLROD, halt the user processor, and kill all the PWMs, and it is simply displaying the 8.3V without doing the rest? I am guessing that user program data corruption (similar to what would happen trying to run an 8722 file on an 8520 chip) is fooling the master processor into this "half-disabled" mode.
Unfortuately, without a 2006 controller at my diposal, this is all speculation.
I just found it interesting that it is possible to trigger the same 8.3V bug on the 2004 / 2005 RC as well.
-- Thomas Paine
-- Anonymous
  #64   Spotlight this post!
Unread 06-03-2006, 21:05
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Originally Posted by devicenull
I'm using 2.40 and I haven't seen any of the problems stated here..
And neither did we, with almost 100 hours of autonomous mode testing in our clubhouse. At BAE we were batting 50%.
I'm going to check tonight to see if we have a spare 2005/2004 RC that we can bring, but as of the current FIRST rules, they are not allowed.
Under the circumstances, you can probably get a ruling on the field. They originally gave us trouble last year about subbing a 2004 RC for our 2005 when we broke a terminal off of it, and they eventually calmed down.
  #65   Spotlight this post!
Unread 06-03-2006, 21:10
kaszeta's Avatar
For us, the Code Error light WAS NOT on. The Radio light showed an error, and the Team LEDs quit blinking, but the Code Error light was the first thing we and Corey from IFI (who did a good job peering at dead bots on the field trying to debug them) checked.
Odd. I haven't been able to replicate this on a 2005 RC, but I'll try upgrading to v12 firmware.
I'll note that you can see the 8.3V problem with code that otherwise appears to work correctly.
When I last talked with IFI, their guy was fairly convinced it was something in the ADC interrupt handler (which has a lot of code for an interrupt handler)
  #66   Spotlight this post!
Unread 06-03-2006, 22:16
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Um, I'll eat the cardboard box that housed the last dozen Krispy Kremes that Dave Lavery polished-off if this is found to be true .
-Kevin
Kevin Watson
http://kevin.org
  #67   Spotlight this post!
Unread 06-03-2006, 23:37
It happens to us without the ADC code.
  #68   Spotlight this post!
Unread 06-03-2006, 23:47
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
-Kevin
Kevin -
Just as a precaution, I really hope you are hungry. We experienced the "8.2V problem" over the weekend at the VCU regional. Ricky Torrance from IFI was there, and we reviewed the problem with him. We were not able to confirm it in the time we had to work the problem, but issues with overwhelming the interrupt handler was one of the two plausible explanations we were able to identify (the other was a memory overrun situation into a specific unprotected memory space that affected the ADC lines).
At the time, we only had that one known case of the problem to give to IFI as an example, which limited the options for investigation of the problem. As of this afternoon, IFI is aware that the problem may be larger, and is looking in to it. We have pointed them to this thread for more information.
-dave
  #69   Spotlight this post!
Unread 06-03-2006, 23:49
Gdeaver Gdeaver is online now
FRC #1640
Question. Are all of the teams that are having problems using the most recent IFI loader? Wasn't the latest loader upgrade to allow full use of the new pic's increased memory? Could this be something in common with teams having problems. Wouldn't a fully charged back up battery show between 8.2 to 8.4 volts? When the error occurs what happens if the back up battery is unplugged? How does IFI manage the change from the 12 volt bat to the back up? Could a drop out from those shooters starting up hang the processor?
  #70   Spotlight this post!
Unread 07-03-2006, 00:17
FRC #2429
Originally Posted by dlavery
Kevin -
-dave
Dave,
Well, I'm pretty confident it has nothing to do with my code for several reasons. The first, and most important, is that Mark has duplicated the problem using IFI's own default code.
-Kevin
Kevin Watson
http://kevin.org
  #71   Spotlight this post!
Unread 07-03-2006, 00:30
dlavery's Avatar
Curmudgeon
Dave,
-Kevin
I would not be surprised if that turns out to be the case. If so, then I will gladly eat a dozen Krispy Kreme donuts (notice I didn't say anything about the box...). Either way, I understand that both Mark and Tony Norman will be at the Arizona regional with us this weekend. If the problem is not solved by then, we can hold them down and sit on their heads until they fix it...
-dave
  #72   Spotlight this post!
Unread 07-03-2006, 03:57
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
When we have seen this problem it has been immediately after a power up,
and is not cleared by using the reset button, but can be cleared by powering down and bringing it up again.
What is different between the data segment initialization when the reset button is pushed and the initialiazation when the system is powered up?
It almost looks like the code in _do_cinit is not setting the initialized memory
up correctly sometimes.
  #73   Spotlight this post!
Unread 07-03-2006, 08:27
kaszeta's Avatar
Dave,
As have I, and demoed it to Corey at BAE, hence my skepticism that the interrupt handler is the problem. My money is on something being wrong in the master CPU, since bad user code shouldn't be able to cause some of the problems I've seen.
  #74   Spotlight this post!
Unread 07-03-2006, 08:29
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
-Kevin
We are not even useing the adc code and we get the problem. So lucky for you it looks like you wount have to eat a cardboard box.
  #75   Spotlight this post!
Unread 07-03-2006, 10:59
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Can someone who has experienced the problem and have the hardware upgrade to the latest 2.44 version of the C18 compiler. Compile some user code and with the newly compiled code try to replicate the problem. I find it highly suspicious that Kevin Watson does the amount of development he does on the IFI boards and he hasn't experienced the problem.
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
