Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 07-03-2006, 14:24
Faith's Avatar
Faith Faith is offline
AKA: Plooshiska
FRC #1100 (The T'Hawks)
Team Role: Scout
Faith will become famous soon enoughFaith will become famous soon enough
Excel Help for Scouting Database
I'm not sure where this should go, so I'll try here...
I am trying to make an excel spreadsheet where I input the scouting data on a sheet and then I can type in a team number on another sheet and pull the information from the sheet with the data. Only problem is, I don't know how to pull information from different sheets.
If I just confused you, sorry, I'm having trouble putting this into words...
Thanks in advance!
FRC: TEAM 1100
FVC: Team 3377
Unread 07-03-2006, 14:37
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Excel Help for Scouting Database
Thanks in advance!
I think I understand the question. The feature you want to use is under "Data" on your tool bar, then select "Validation." Pick under the validation criteria "list" and it will give you a dialogue box to pick where you want that list of data to come from - you can select from a different worksheet. Let me know if you have any other questions!
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 07-03-2006, 14:47
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
I don’t think what is need is to see if the data is true or not, I think what is wanted is to sort the data by team on another sheet.
If this is the case then you can use filter commands. Go to data, then filter, then advanced filter. You can type in what team you want to show and it will filter out all of the unnecessary data. You should be able to preset up a sheet with the teams going to the regional and have the filters update automatically. If not then you will have to do it after the data is collected. But, you could always just sort by a certain value such as shots made into the goal in the data entry sheet. I hope this helps.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 07-03-2006, 14:53
Faith's Avatar
AKA: Plooshiska
Team Role: Scout
Let's see if I can be specific... I have a "data" sheet, where I input the data by team number. Then I have an "interface" sheet, where I want to be able to type in a team number and have the data on that team from the "data" sheet appear.
Does that make more sense?
Thankyou, I'll try everything suggested right now
FRC: TEAM 1100
FVC: Team 3377
Unread 07-03-2006, 14:59
Faith's Avatar
AKA: Plooshiska
Team Role: Scout
For that it says column labels are needed. I think I know how to do those, but... I have never done that before in Excel. Could you verify how?
FRC: TEAM 1100
FVC: Team 3377
Unread 07-03-2006, 15:20
DjAlamose's Avatar
AKA: Teh Albie
Eureka I’ve got it!
All you have to do is select the entire area you want to sort. Then you go to Data/Filter/Auto Filter. This will insert a new column with drop boxes where you can select from teams, sort ascending /descending, or some other functions. It will sort all of your data and find it for you, it’s just that simple. If u have any more questions please ask.
2004 GLR Champs
Unread 07-03-2006, 15:25
Faith's Avatar
AKA: Plooshiska
Team Role: Scout
Eureka I’ve got it!
That is awesome! It isn't what I meant, but it works even better! Thankyou very much
FRC: TEAM 1100
FVC: Team 3377
Unread 07-03-2006, 16:16
Here is one example on how to do that: http://www.chiefdelphi.com/forums/pa...le&paperid=487 Karthik used the OFFSET and MATCH functions.
Autofilter works great as long as you only displaying the data. I haven't figured out how to do calculations on the just the autofiltered data, though.
Unread 07-03-2006, 16:20
Faith's Avatar
AKA: Plooshiska
Team Role: Scout
Thankyou .
I'll look into that. It would convenient to have two ways to view the data, alone and in comparison.
FRC: TEAM 1100
FVC: Team 3377
Unread 07-03-2006, 16:54
Faith's Avatar
AKA: Plooshiska
Team Role: Scout
Thankyou very much for helping me! I now have a spreadsheet where you can input data and then pull it up for a specific team by typing in the team number (using offset and match commands) . I also have it so that you can compare the teams by there attributes (using autofilter). I'm going to work on it a little more, and then I think I'll post it here.
Again, THANKYOU!!!
FRC: TEAM 1100
FVC: Team 3377
Unread 08-03-2006, 17:02
Faith's Avatar
AKA: Plooshiska
Team Role: Scout
I just realized another thing that would be awesome.. Does anyone know how to pull a picture from one sheet to another? I'm not sure if this is possible, but...
Thankyou!
FRC: TEAM 1100
FVC: Team 3377
[IMG] code is Off
Using Inventor without Excel jdiwnab Inventor 4 14-12-2005 14:28
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
Teach Genia How to Program and Win a Prize Eugenia Gabrielov Chit-Chat 25 25-02-2005 13:31
We have to organize to win archiver 2001 18 24-06-2002 00:00
