Go to Post Some of the most talented people in the world are designing robots in FIRST. If that were taken away, all of us would be poorer for it. - Andrew [more]
Unread 06-03-2006, 17:35
Umm Errr...
Linux handholding needed
I would like to be able to program for the RC under linux. I assume the best route would be to use use eclipse and C18 under wine. I have both eclipse and wine installed. how do i proceed?
1139 Alumni
Unread 06-03-2006, 23:23
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Linux handholding needed
There's a good makefile floating around for specifically this purpose - it calls wine and mcc18 properly. There are a few things you have to do to make it work - I seem to remember that I had to link all of the binaries from (for example) mcc18.exe to mcc18 because the makefile assumes that there's no file extensions on executables and that you have to change a flag to indicate that you're using 18f8722 instead of the 18f8520. It's not very difficult once you get the makefile working - Eclipse can use it to build just fine.
Good luck!
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 07-03-2006, 06:44
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Here are the threads which helped me get it working:
http://www.chiefdelphi.com/forums/sh...=linux+compile
http://www.chiefdelphi.com/forums/sh...threadid=36377
http://www.chiefdelphi.com/forums/sh...ad.php?t=37736
Unread 07-03-2006, 13:28
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Eclipse can run natively under Linux.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 07-03-2006, 16:58
Umm Errr...
I meant run eclipse natively and run C18 under wine.
1139 Alumni
Unread 07-03-2006, 17:10
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
When someone gets a working/updated makefile, could you post it? I'd do it myself, but it seems others are already working on it and it's relatively low priority for me.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Let's have Linux Robots Next Year! jdong Control System 52 22-08-2005 09:40
Any teams use Linux? gobeavs IT / Communications 14 03-04-2005 17:58
Using Linux? Raven_Writer IT / Communications 41 05-07-2004 16:53
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
