Go to Post There's "FIRST the organization" and then there's "FIRST the vision for the future through a set of ideals". I've grown somewhat skeptical of the former in recent years, but, after 10 years, I'd still throw myself in front of a bus for the latter. - Rich Kressly [more]
View Poll Results: How is your camera mounted?
The camera is mounted stationary, off the turret using no servos 5 9.80%
The camera is mounted stationary, off the turret using servos to pan and tilt 20 39.22%
The camera is mounted on the turret, but using the turret to pan and tilt 11 21.57%
Other (specify in post) 15 29.41%
Voters: 51. You may not vote on this poll
Unread 06-03-2006, 18:15
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Just interested in how other people have their cameras set up...
Unread 06-03-2006, 18:22
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: How is your camera mounted?
Mounted on the turret with a tilt servo; using turret to pan.
The tilt servo only has two positions, near and far.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 06-03-2006, 18:29
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
ours is mounted (poorly . . . one of the things well be fixing on our thursday) on our turret, with both the tilt and pan servos(the turret is only 320 deg so we left the pan servo on to "keep a beat on the light"
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 06-03-2006, 19:05
Umm Errr...
We used the pan/tilt assy in the kit but locked the pan axis in place. Tilt is controlled by our turret. There is a lexan wall protecting it
1139 Alumni
Unread 06-03-2006, 19:56
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Pans with turret, no vertical adjustment.
Unread 06-03-2006, 19:59
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Who needs a camera? We don't have one.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 06-03-2006, 20:35
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Camera on turret with both pan and tilt servos. We decided the rotator would not have enough angle of rotation to be an effective pan adjustment for the camera (our rotator only does 40-60 degrees, just enough to hopefully keep us pointing at the goal if we start getting pushed while shooting), plus the camera can search faster moving the pan servo rather than the rotator.
Unread 07-03-2006, 17:14
mogunus mogunus is offline
AKA: Luciano DiFalcone
FRC #1350 (Rambots)
mogunus is an unknown quantity at this point
Our cameras are mounted one on either side of the turret mechanisim, both on pan/tilt servos. The turret itself pans and tilts.
looks sorta like this:
[[O]]---()______()---[[O]]
With the () being the rotating shooter motors, and the little [[O]] things being the cameras mounted on the pan/tilt servos.
... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
-- Robert Firth
Unread 07-03-2006, 17:26
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
You have two cameras? How did you wire them through one port?
Unread 07-03-2006, 17:50
FRC #1350 (Rambots)
I didn't. I have a custom circuit board with three rs232 level serial ports, two of which connect to the two cameras and one of which connects to the program port on the PIC, not the TTL level port.
Binocular vision could also be accomplished by connecting one camera to the program port and one to the TTL port, and then messing with Kevin's camera driver code to use the cameras on both ports. My way was just easier, 'cause I'm lazy.
Also note: the cameras don't really need to be powered by the 7.2 volt power supply on the PIC board. If you're not powering the servos off the camera board, 5v will do just fine in powering the camera itself, it says in the "Big Binder of the Camera" that power goes through a 5v regulator. So just hook up the camera to a digital inout or whatever for power, and you won't have to deal with backup battery foolishness, because that silly thing was being drained far too quickly by our two camera setup.
-- Robert Firth
Unread 08-03-2006, 11:09
Caleb A. Caleb A. is offline
FRC #0932 (Circuit Chargers)
Caleb A. is an unknown quantity at this point
Our is mounted completely reversed (y pan and backwards, x is tilt and backwards) because my crew didn't listen whenever the built the camera casing and it has to be out of the way of the shooter. The camera itself is mounted on our Shooter so the robot pans and the shooter tilts. Probably won't end up using it though depending on how much practice time I get.
"If you're not FIRST, you're last."
Unread 11-03-2006, 01:26
AKA: Dr. Brooks
no team (WRRF)
Our camera is mounted in a piece of 2x2 aluminum box tube, that is bolted to the turret. The camera itself is epoxied to the board it is plugged in to, using two wood blocks, and the wires are soldered to the board so no connectors can work out due to vibration. The camera lens looks through a hole in the box tube.
The camera pans with the turret using feedback to keep the turret locked on the target. The height of the target is used to control the wheel speed so that a fixed 45 degree shooter can hit the target from different ranges.
Unread 14-03-2006, 20:08
sur2124 sur2124 is offline
FRC #0116
sur2124 is an unknown quantity at this point
ours was mounted underneath the turret to prevent any from ball hitting it.
Unread 14-03-2006, 20:30
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Ours is mounted directly in front of our shooter wheel, with lexan protection of course, and the balls go over it. We just used the top part of the pan/tilt assembly, with only the tilt servo being used.
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
Unread 15-03-2006, 11:19
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
ours is on the turret and usses servos
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
Camera shows no love to drive motors anifinder Programming 4 13-02-2006 10:31
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
