Re: v1.1 STAMP Release (Install fix and calculation bugs)
Would haivng one or 2 people doing data entry work also?
How exactly do i run the "database setup"?
http://(Yourserveriphere)/database_setup.php (i think, verify that this is the file) Essentially your simply loading up the database_setup.php in a webrowser. Also, if there is any intrest, i have a demo STAMP v1.1 on my webserver here: http://stamp.rombus.us If you would like to create a test account and get a feel for how it works: Use team number 3000 and team password 89967 Screw around with it, right now there is no data except for my teams robot, so some stuff wont look right. Ill try to put some real data in from buckeye after the competition. Also after this weekend ill upgrade to 1.2! |
#7
Rombus, you're at the Buckeye? So is Team 93. When your in the stands look for the Red Apple and a bunch of red shirted scouters. Jeremy Johnson shoudl be in that group, he is one of the developers on the project. I would be curious to see how our databases compare to see how accurate our scouters are.
Good luck! Brandon |
