Go to Post You can also always use the "Report Post" button on each post and that'll dispatch a carrier pigeon to each of our homes...or an e-mail if the carrier pigeons have taken the day off. - Madison [more]
Unread 07-03-2006, 21:06
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Keeping a certain heading using a gyro
Hi all,
OK, I've been looking at Kevin's gyro code, and have been trying to work out an algorithm to maintain a certain heading using the gyro supplied in the kit.
My thoughts are leaning towards something like this:
Reset_Gyro_Angle();
if(Get_Gyro_Angle > 10){//1 degree
   turn left
else if(Get_Gyro_Angle < -10){//-1 degree
   turn right
else
   stop
Am I correct about the gyro values, where a positive value would be a turn to the right and a negative value would be a turn to the left?
And would this code (without optimizations) allow self adjustment to a certain heading (despite oscillations)?
Thanks,
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Labview used to debug the Gyro joshR515 National Instruments LabVIEW and Data Acquisition 1 09-02-2006 20:56
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
