Go to Post And who knows, maybe one day you'll prove the impossible possible! - MissInformation [more]
Unread 07-03-2006, 21:10
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
Re: Keeping a certain heading using a gyro
Well, it may or may not work entirely depending on how much play there is inyour drive train, how hard you turn left and right, and a bunch of other issues. The general idea is right though - you just may need some P, PI or PID control instead of using some set turn speed.
PS: I didn't use Kevin's gyro code this year so I don't know about the snippet there; however, the idea is in general correct.
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Labview used to debug the Gyro joshR515 National Instruments LabVIEW and Data Acquisition 1 09-02-2006 20:56
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
