Go to Post Now, I either need to convince Mike Martus to start the webhug early (or move it back 1 hour), skip the webhug, miss the first part of the presentation, or just clone myself. - Andy Baker [more]
  #33   Spotlight this post!
Unread 08-03-2006, 08:11
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: The 8.2 (or 8.3) Battery Voltage Bug
Originally Posted by Eldarion
Try uploading Kevin's frc_gyro.hex as many times as necessary to cause the error. (See previous post; I have also confirmed that this causes a similar "bug" on the 2004 RC)
I tried it a bunch of times last night without triggering it,
However, (1) I only tried it with the tether (the radio modem pair I scrounged up at the clubhouse appears not to be working), and (2) I don't have a backup battery handy, but I did vary the voltage on the backup battery lugs by (a) hooking a +5V signal from the pwm outputs to it, (b) hooking up a 1.5v battery, and (c) hooking up a 9V charger to the pins
I'll try it again today with an actual battery and see if massive repeated uploads of frc_gryo.hex do it.
Was the robot tethered when you had the bug, or was it on the field with the radio?
Both, and oddly, I saw the error about half of the time.
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
