Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
Unread 08-03-2006, 18:02
jbill30 jbill30 is offline
jbill30 is an unknown quantity at this point
Vex line follower sensor kit program
I am trying to create a program that will allow the line flooer sensor to work. I am n ot sure of what to do. I am creating this robot as a class project for a class that I am in. any help that anybody can give me would be nice.
Thank you.
Unread 09-03-2006, 05:51
Dan Larochelle Dan Larochelle is offline
FRC #0040 (Pioneers)
Rookie Year: 1993
Dan Larochelle has a spectacular aura aboutDan Larochelle has a spectacular aura about
Re: Vex line follower sensor kit program
What kind of robot are you making? Vex, Edu, FRC? The Vex line following sensors come with some basic instructions that might help. EasyC Version 2 has a built in tutorial for line following that will also help a lot. Hope this helps.
Unread 03-04-2006, 17:37
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
With the line following kit you are given three sensors. If you play one at the front of your robot, one in the middle, and the third at the end, facing downwards, it gives you a reading based on how far away it is from a line of contrasting color. If you know the distances you can make the appropriate lines of code to turn to the right or left. If you get a reading on the first one that is off the line, the middle is slightly off the line, (both to the left), and the third one is on the line, you know that the line is curving and you shoudl turn to the right. Or vice versa.
VEX Robotics Blog
Unread 01-05-2006, 18:15
I am student at the New Hampshire Community Technical College in Laconia, N.H. I am not really a programmer so if anybody had a sample of the code I would use to allow the robot to run the course that came with the line-follower kit it would be a great help.
Unread 01-05-2006, 18:17
I am runniong the Vex robot. Using the EasyC Program for Vex.
Unread 12-05-2006, 14:43
vencetti vencetti is offline
vencetti is an unknown quantity at this point
Cool Re: Vex line follower sensor kit program
If you go to the easyc help, one of the tutorials walks through the setup of a line follower program, with code examples.
using eclipse dasRatsel Programming 82 02-01-2006 13:20
FIRST Vex in Radio Shack Ad Fran General Forum 13 29-04-2005 00:11
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
