Go to Post This year should be an unusual object game. You know what an unusual object is? Water. - TheBoulderite [more]
Unread 08-03-2006, 10:48
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
pic: Dented IFI Wheel
Unread 08-03-2006, 10:51
Drew Hopman's Avatar
Drew Hopman Drew Hopman is offline
Last Resort
FRC #0801 (HorsePower)
Drew Hopman is a jewel in the roughDrew Hopman is a jewel in the roughDrew Hopman is a jewel in the rough
Send a message via AIM to Drew Hopman Send a message via Yahoo to Drew Hopman
Re: pic: Dented IFI Wheel
Those wheels are trash, They are not even near round as far as where the sprocket hooks in. Whe had to make a lot of mods to the wheels to make them better, but still they are not near perfect. They are to expensive, and take forever to put together.... Our team will not buy again.
Unread 08-03-2006, 11:03
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I don't think the IFI wheels are trash at all. They are very grippy and very light. They are also exceptionally strong for their weight. This photo is the only example of damage to an IFI wheel that I have seen so far, and the damage appears to be minor.
My team decided to go with holonomic drive this year so we didn't use the IFI wheels, but we certainly would have used them had we gone with a 6WD drivetrain.
Richard Wallace
since 2003
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Wow this is one of the first negative posts I have heard about the IFI wheels. I just have a few comments to make about your picture and the IFI wheels all together.
1.) In the picture i can't really tell where the dent is. Do you mean on the edge of it where the picture is a little blurred? If so it looks like you hit something with it.
2.) The IFI wheels are almost indestructable. Even with dented wheels you can still drive.
3.) The IFI wheels shouldn't have taken you to long to put together. I showed a group of high school kids how to put them together and in under 10 minutes they had the IFI wheels put together and the sprockets put on them. And we have yet to have a problem, even with the original IFI wheels that we tested we didn't have a problem with them.
4.) These wheels beat just about anything you can make. They are light, and almost indestructible, what else could you ask for?
Did you try different wheels out? Such as to buy another one from IFI to see if it was the batch of wheels that made things so difficult for you?
/edit:
It took us (team 229) hitting the wheel repeatedly with a hammer to get any significant dents that would disrupt the driving of a robot. I doubt a robot is going to have its wheels hit nearly as hard in competition.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 08-03-2006, 11:14
Last Resort
We must have got a bad batch of them, because all 6 that we got are way out of tolerance. It took about 45 minutes to put each one together, bc the tread material was to short. At first it caused out chain to pop every time, because there was a high and low point from the chain caused by the sprocket holes not being drilled in the center. And I have also herd some horror stories from down south that the bearings tear apart after about a week and a half of use from more than one team….
Unread 08-03-2006, 11:39
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
To expand on what Tim said,
Our experiences were very positive, like they weren't perfect but they were darn good. With what I’ve learned this year I’d use them again in a second, I’d probably change a few things about the way I used them (such as sprocket placement, and hardware used) but we were pleased.
Another important point is we fought weight hard core this year, and there is no way Irrational would've ever made weight without the IFI wheels.
We have 12 on the robot.
8 in the 8 wheel drive system
4 in the ball lift system
Chalk up one to a statisfied customer,
Chris C.
Team 229
Unread 08-03-2006, 12:07
The designer of these wheels visited St. Louis back in December, serving as a technical advisor for our FVC demonstration event. He left me a sample 6 inch x 1.5 inch IFI wheel.
A few minutes ago I took that sample down to the CMM that we use to check parts here at Emerson's motor tech center. The results showed that the six hole pattern intended for mounting sprockets is concentric to the bearing hole within 0.004".
Each of the sprocket mount holes was 0.197-0.198 diameter (very nearly 5 millimeters). I'd conclude that the ideal sprocket screw size would be #10, or M5 if you wanted to use metric fasteners. Off center sprocket mounting could result from using smaller fasteners such as #8.
Of course, my CMM results are from a single sample. Close inspection of the holes indicates to me that they were punched, not drilled or bored; from this I guess that the sample was made using the punch tool that IFI subsequently used to make production parts.
Richard Wallace
since 2003
Unread 08-03-2006, 12:13
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Did you assemble them with a shaft down the middle of the bearings? I don't know if that's in the instructions, but it is absolutely imperative that you do this. If you omit that step, your wheels will likely exhibit the misalignment problems described, and your bearings will be very unevenly loaded. The bearings themselves are relatively good quality (probably ABEC-3), and have never caused a problem for our team (either on IFI wheels, or on dozens of other applications over the years, where we used identical bearings).
My only real concern is with the press nuts; I realize that that's a concession to cheap manufacture, but I really hate the things. (They can, if overtightened, strip out.)
Unread 08-03-2006, 13:39
Last Resort
Yes, its not the wheel itself that seems to be the problem, it is the hole location for where the sprocket connects to the wheel, it seems as if they didnt do a good job making it centered, and causes the sprockets to wobble as much as 1/16" inch. If the wholes were correctly drilled then i beleieve we would be in a much better situation I am not trying to spark controversy, i am just expressing my personal experiance with the product.
Unread 08-03-2006, 18:54
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
We used 6 of the 6"x2" wheels this year on our 6 wheel drive. As has been said these wheels are a bit expensive when you add up the wheels, separate tread, and sprockets, however, as has also been said they are super strong and super light and have great traction. I know our team couldn't make any wheels ourselves as strong and light any cheaper. I also don't know of any other off the shelf wheels as strong and light so pretty much I don't think you can beat these wheels. As to the manufacturing "defects" we noticed this as well, however, the holes are not drilled (technically punched) off center. What we found was that the holes that attach the sprockets to the side plate of the wheel are just a bit over-sized for the #10 screws that come with the wheels which allows for the sprocket to be bolted up off center. It was pretty much impossible to align the sprockets by hand so we overcame this minor problem by making an alignment tool. It works sort of like a clutch alignment tool and is nothing more than a piece of aluminum round stock turned down to the inside diameter of the sprocket and then turned down again to the ID of the bearings (3/8") to allow all the "centers" to be held in place as you bolt the sprocket to the side plates of the wheel. It still wasn't perfect but it was close enough to work fine. A second thing we noticed was that the holes were similarly over-sized for the two screws that hold the bearing retainers in place and thus the bearing retainers may (and probably will) bolt on a little off center. While this in no way effects the wheels operation it causes an optical illusion if you look down center of the wheel bearings making you think the sprocket is possibly more off center than it really is. Just pointing out our observations.
I really like the new IFI wheels. It would be great if they could lower the price by about half by next year. They were new and expensive this year but maybe by next year they can produce them in enough volume that the price will come down. I would dearly love to see these included in the KoP next year. Like I mentioned before in another thread, it would really be nice if FIRST would ditch the wheelchair wheels next year and include vouchers or something for 2 or 4 IFI wheels in whatever size you want. Sort of like they do with Bimba for the three air cylinders. If you want more than the 2 or 4 included in the KoP then you can buy them.
Unread 08-03-2006, 19:09
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Denting the corner of one of those wheels after hearing that is pretty impressive.
Oh Jeff... always being such an aggressive driver... after I saw the thread title I figured it was you. I didn't even look at your name under the title.
Team 151 slammed into the lexan on the ramp and they bent a peice of their angle stock. I don't have pictures, but it was scary seeing them carrying it around.
Unread 08-03-2006, 20:36
Jeff K.'s Avatar
Hmm..now what?
That picture was the only problem that we've had with these wheels at competition. Haha and Dan, you're right, I am sometimes too aggressive for my own good, but we were able to outpush any robot out there and we're very pleased with the wheels. We still were able to drive the robot and it didn't affect its performance. The dent is around the middle of the picture, where there is a slight blur. Sorry for it being of bad quality, it was from my camera phone
We had another problem before this though and it was partially due to the chain on the sprockets being too tight. It would squeeze the sprocket off alignment, and so we fixed that by using the 3/8" ID bearings since they are the same OD as the hole in the sprocket and so it is supported that way. Adds some weight but fixed the problem.
All in all, we're more than pleased with the IFI wheels and chances are, we'll use them in the future.
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Planetary Wheel - Exploded View 4 Matt Krass Extra Discussion 5 23-06-2005 23:56
pic: Wheel got dented during a match davelu Robot Showcase 24 05-04-2005 23:58
pic: 296's Tri-Star Wheel CD47-Bot Robot Showcase 23 16-02-2004 11:27
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
