Go to Post "The world is not idiot-proof. Pay Attention." - DonRotolo [more]
Unread 09-03-2006, 00:20
jamesgecko's Avatar
jamesgecko jamesgecko is offline
Linux Guy.
AKA: James D
FTC #0040 (Grep Lurch Grab)
jamesgecko is an unknown quantity at this point
Send a message via AIM to jamesgecko Send a message via Yahoo to jamesgecko
Question Turning problems in Vex autonomous. [Solved]
I wrote the following code using easyC for Vex.
It's a function, it's supposed to take the angle I give it and turn in that direction. If I give it a positive angle, it turns to the right. I'm trying to make it turn to the left if I give it a negative angle, but it ain't happening. For some reason it simply turns to the right again. Any ideas?
#include "Main.h"
void turn ( int angle )
{ // Turns the robot a set number of degrees
      int done = 0;
      int abs;
      angle = angle/4 ; //For the optical sensors, one turn is 90 pulses.
      if ( angle < 0 )
            abs = -angle ;
      else
            abs = angle ;
      PresetEncoder ( L_OPTICAL_SENSOR_CHANNEL , Left_Optical_Sensor ) ;
      PresetEncoder ( R_OPTICAL_SENSOR_CHANNEL , Right_Optical_Sensor ) ;
      StartEncoder ( L_OPTICAL_SENSOR_CHANNEL ) ;
      StartEncoder ( R_OPTICAL_SENSOR_CHANNEL ) ;
      while ( done != 2 )
            Left_Optical_Sensor = GetEncoder ( L_OPTICAL_SENSOR_CHANNEL ) ;
            Right_Optical_Sensor = GetEncoder ( R_OPTICAL_SENSOR_CHANNEL ) ;
            if ( Left_Optical_Sensor < abs )
                  if ( angle > 0 & angle <= 90 )
                        SetMotor ( L_MOTOR , 255 ) ;
                  if ( angle >= -90 & angle < 0 )
                        SetMotor ( L_MOTOR , 0 ) ;
            else
                  SetMotor ( L_MOTOR , 127 ) ;
                  done = done + 1 ;
                  StopEncoder ( L_OPTICAL_SENSOR_CHANNEL ) ;
            if ( Right_Optical_Sensor < abs )
                        SetMotor ( R_MOTOR , 255 ) ;
                        SetMotor ( R_MOTOR , 0 ) ;
            else
                  SetMotor ( R_MOTOR , 127 ) ;
                  done = done + 1 ;
                  StopEncoder ( R_OPTICAL_SENSOR_CHANNEL ) ;
      return  ;
FVC40: We use all of the buffalo.
Unread 09-03-2006, 00:58
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Re: Turning problems in Vex autonomous.
This should be the logical operator &&, not the bit operator &.
Personally, I always write multiple expressions in the following form. It is more readable and forces the precedence I want. I have to type a few more keystrokes but it is worth the correctness and clarity.
                  if ( (angle > 0) && (angle <= 90) )
Otherwise someone who knows the functions you are calling will have to help you.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Last edited by Keith Watson : 09-03-2006 at 01:02. Reason: added not and fixed typo
Unread 09-03-2006, 07:18
koenig3456 koenig3456 is offline
Programming Coach
None #0681 (EARTH Squad)
koenig3456 is an unknown quantity at this point
Since the wheels are mounted on opposite sides of the robot, they need to be operated opposite from each other. For example: To drive straight you would use:
Try swapping the SetMotor ( R_MOTOR , 255 ) ; and SetMotor ( R_MOTOR , 0 ) ; calls.
Unread 09-03-2006, 16:41
jamesgecko's Avatar
Linux Guy.
AKA: James D
Lightbulb Re: Turning problems in Vex autonomous.
Thanks, Keith. It works great now.
koenig3456: But I want the robot to turn... ;-)
[moderated]: NASA/VCU field problems Stephen P General Forum 42 09-03-2006 19:59
BAE Granite State Regional MattK Regional Competitions 15 03-03-2006 23:38
Autonomous Camera Integration GregC Programming 2 06-02-2005 14:34
Next Years Game? Jeremy General Forum 49 27-04-2004 01:53
