Go to Post I've been inspired for real engineering during the build season and on the playing field, but the inspiration I found in the pits is often for creative thinking and intuition. - artdutra04 [more]
Unread 09-03-2006, 05:06
Tim566's Avatar
Tim566 Tim566 is offline
FRC #0566 (Hot Wired)
Tim566 will become famous soon enough
Re: Update #15
Originally Posted by Wayne Doenges
Does this mean that the backbot must be stationed near the opposite ramp That's a long way away.
No I believe it means that the backbot must remain on that side of the field and is free to move anywhere as long as it remains on that side without crossing back over the line.
The only thing about the future of which we can be
certain is that it is uncertain and it will be there whether we are or not.
So my advice is to enjoy life in the present while not disregarding the future.
To everyone going to the competions good luck out there and remember whatever you do have fun doing it
Unread 09-03-2006, 09:12
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Update #15
Originally Posted by DjAlamose
Update 14 Thread
Link to update 15
Alot of reminders about backbots. I can understand from all of the penalties that were going on during the regionals. But one thing I don’t understand is why a robot that is either mechanically, electrically, or programmably inept (meaning they cant move) why the robot would not be considered inoperable. So if my team puts a 120 lb weight onto the field and it gets pushed across the line then we are still somehow operable... I'm sorry but I don't like the call that the GDC made on that one.
mechanically, electrically, or programmably inept does not mean cannot move. A robot that cannot turn due to too high friction on the wheels coud be considered mechanically inept.... etc.
If a Robot throws a chain or loses motor wires (and is in the frontcourt) then another robot from that alliance must move to the back court or the damaged robot needs to be e-stopped (otherwise it should be penalized).
And, yes, your 120 LB weight could become a 40 point liability if it ends up on the wrong side of the field and is not E-stopped.
As far as the corner goal issue. If they enforced the ramming rules, then I dont believe they would have needed this clarification (JMHO).
Unread 09-03-2006, 19:25
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Update #15
From Update #15:
"Once a robot is in place to deposit balls in the corner goal, ramming it from behind generally has no purpose other than to destroy, unnecessarily harass, or force a goal incursion of the scoring robot. Repeatedly ramming a robot that is depositing balls in the corner goal from behind may be called for a <G22> violation and may incur a 5 point penalty or a disqualification."
From Q&A:
Question: "Our robot is in the process of dumping balls into the corner goal and no part of the robot is extended into the goal. We are then pushed by an opponent's robot such that our dumping mechanism is now more than 3" into the goal. Who would receive the penalty for extending into the goal more than 3"?"
Answer: "Any robot that extends more than three inches into the goal (three inches past the plexiglas barrier) will be disqualified. If your robot has been designed such that it can extend into the goal, even if pushed, then you would be wise to operate the robot cautiously when in the vicinity of the goal."
Are these two official statements from FIRST:
A) Contradicting each other?
or
B) Attempting to tell us that ramming is a no-no but pushing a robot into a goal is a fair play?
I tend to think that teams should have thought of this when they designed and built their robot so that if you get pushed through the goal it is your fault for having a part of your robot sticking out. However, repeated ramming serves no real purpose at anytime during the game and should be penalized. I don't see any difference between pushing an opposing robot into a goal and flipping one over as they climb the ramp. If you design a robot that is "tippable" due to high COG then why would it be the opposing robot's fault if they tip you over by pushing on you while you are on the ramp. Now if you fall over on the ramp and they continue to ram you that is just plain unsportsman like. With all the pushing and shoving designed into this game why should an alliance get penalized for the design flaws in their opposing alliance?
I believe that FIRST is trying to tell us ramming is bad but pushing is OK.
Unread 09-03-2006, 19:34
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: Update #15
The point I was trying to make is that if a team just puts their robot out onto the field and their alliance is considering them the backbot and they get pushed across the line they are going to get penalized even though they are just dead weight on the field. I wasn't trying to get to technical and specific oriented. I really don't like this though because I can see teams using this to their advantage because there will always be one team out there that will do stuff like this.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 09-03-2006, 19:39
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
Re: Update #15
<G17> ROBOT Orientation - ROBOTs must maintain their vertical orientation with respect to their starting position throughout the match. ROBOTs may not intentionally tip over onto one of their initially vertical sides and operate with this side parallel to the ground. “Flop-Down” robots will be disqualified.
Do I understand that right? No drop down robots? Have any teams been disqualified now because they flip their robot for a 3 by 5 foot drive base? It was very popular last year...
Unread 09-03-2006, 19:43
in between teams
AKA: Luke Van Oort
Re: Update #15
This happened to our alliance twice in elims, the first time 540 threw their battery, the second time they shorted to their frame. (At least, that's what they suspected) That said, having been in this position, I can tell you a 120lb weight can be very effective. Where 540 was they completely blocked a lower goal, not that it mattered in an elim against high scorers, but in a qualifier... Anyway, if you don't want this to happen ziptie and electrical tape all "joints" in the electrical system, loctite all bolts, have redundant systems, etc. For example, we threw a chain, and weren't useless, far from it! We still could play really rough defence because I made a drivetrain with redundant chains. Although that choice was made to help chain pathing, it saved our butt. (sort of, we still lost, but not that badly) Design like server admins, redundancy and fault tolerance in power supply (UPS/zipties), programming (UNIX/self-recovery), and delivery. (RAID/multiple drive chains)
Team 1219: 2009 - Mentor
Unread 09-03-2006, 19:45
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Update #15
I agree with you there. But to add: The statements do not contradict eachother. One says that if you go into the goal farther than 3", you will be DQed. The other states that if you RAM a robot into a corner goal, you are liable to be penalized. The actions of the other robot are not part of the responses, and therefore i see no contradiction.
As for the ramming, it would be nice if they actually called it during play. I saw a lot of hard hits on the VCU webcasts that would have been considered ramming in my book. However, FIRST provides NO guidelines as to what is ramming other than the description (Long distance, high speed). This leaves it very ambiguous and hard for the refs to determine.
Unread 09-03-2006, 19:53
Nuttyman54's Avatar
Mentor, Tactician
Re: Update #15
What confuses me is that this was in the rulebook from the begining...all they added was the "flop-down" clause, which seems pretty redundant to me. It was clearly stated that a robot which intentionally tips onto its side will be DQed, and is also not allowed to score, which should've discouraged any team that read the rules to not do it...
Sorry for the double post.
Unread 09-03-2006, 20:02
Master Dictator's Avatar
Master Dictator Master Dictator is offline
AKA: CJ Myers
FRC #0341
Master Dictator is on a distinguished road
Re: Update #15
That rule has been set right from the start thats what makes offense a 3 on 2. My guess is either you haven attended a regional yet or not a operator. So let me reword this rule for you. It means that when you are on defense one of your alliance members needs to be on the farside from you at all times or its called offsides. If anypart of the backbot robot crosses the center line its offsides.
Unread 09-03-2006, 22:58
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Update #15
If the ALLIANCE has a third operable ROBOT, that ROBOT (the BACKBOT) must be positioned on the end of the field farthest from the ALLIANCE STATION
Farthest: Def. To be at the most distanced point.
I was being facetious with my comment but it does state FARTHEST from the alliance station. This would put your backbot near the opposition's ramp.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 09-03-2006, 23:12
Re: Update #15
You still sound confused. The end of the field with the opposing alliance's ramp is where the backbot is to stay. What it says is exactly what it means.
Unread 09-03-2006, 23:21
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: Update #15
Originally Posted by BrianR
I have to respectively disagree with your interpretation. As per rule G21(below), note the last sentance, with the word any in it. This would seem to me to say that if you go too far into the corner goal, you will be penalized. There is a different rule about ramming, which I interpret to be different than pushing. Thus, any time when you go too far into the corner goal, expect to be penalized. They also make the point to reference extending over the scoring system, for that will artificially inflate the score of your team, and that is definately illegal. Thus, because they have to keep this scoring issue as a nonfactor, anyone who causes this to become a problem will be DQ'd. This is perfectly fine, as this rule has been around since the kickoff, and no team should have built with the assumption that they were allowed further into the goal. I think that this is simply clarification that any time you go too far into the goal, you will be DQ'd.
<G21> ROBOT Incursion into the Corner Goal – Robots should not enter the corner
goals. Incidental incursion into the corner goal that occurs as a result of a ROBOT
pushing balls into the goal is permitted, not to exceed a distance of approximately 3
inches. The 3’ does not include the deflection of the goal panel or structure.
Intentional incursion, for example to use a ball gathering mechanism to drop off balls
inside the goal, or extending a portion of the ROBOT through the goal opening to
activate the ball counting system, will result in disqualification of the offending ROBOT.
Any incursion substantially beyond 3 inches, particularly if the robot extends over
the lighted scoring system panel, will be considered intentional incursion.
I stand corrected, Sir.
www.metalmoose.com
Update 10 Tomasz Bania General Forum 2 20-02-2006 22:41
Robotics Film and promo video contest update BuddyB309 Off-Season Events 0 20-02-2006 15:32
2005 FRC Team Update 21 Available! dez250 General Forum 13 19-04-2005 08:44
Team Update #18 (Let's Try This Again) Travis Hoffman General Forum 11 30-03-2005 22:18
A Message from John Abele, Chairman, FIRST Board of Directors [Logo Update Message] dez250 FIRST E-Mail Blast Archive 4 26-01-2005 23:02
