Go to Post If there's one bit of advice I can give, its never underestimate the power of a hurricane. - Joshua May [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 09-02-2006, 22:10
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is online now
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
How to create 3D dxf files in Solidworks, Inventor, or other?
I am needing to create 3D dxf files for a project, and am unable to find a way to easily do it.
I primarily use solidworks, but know inventor and autocad equally well. Any ideas?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 10-02-2006, 02:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: How to create 3D dxf files in Solidworks, Inventor, or other?
Not a clue. Any CAM software that costs money should be able to import either STEP or IGES though which Inventor or Solidworks can easily export from a part file. Be careful about threaded features though, you might lose them.
EDIT: My mistake in assuming it had to do with manufactuing robot parts. For a 3d dxf, have no idea for Inventor or SW
Unread 10-02-2006, 02:39
Engineering Mentor
FRC #0254
This actually has nothing to do with manufacturing parts. The dxf file will be used for registering a virtual baseball diamond. Currently the only format the software can read is a dxf or csv data.
Edit: It looks like I can do it in autocad... I absoolutely hate doing 3D stuff in autocad, but I have no other options right now unless someone can enlighten me.
Thanks so far!
-Travis Covington
Unread 10-02-2006, 12:28
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Unless I am horribly wrong, dxf files don't translate from 3d files.
You can take 2d views of your 3d model, and make a dxf, but it'll only be 2d.
3d export formats, are something like, stp, iges, and the like.
CSV, I think as far as what I remember what Brandon told me when I asked about saving messages, is data files that can easily open in excel.
I'm guessing in this case, it would be co-ordinate system points.
x, y, and maybe z would be your data table.
Ed Sparks, where are you?? You know about CAD exports/imports from the firstcadlibrary.
edit: Hmm.. I hate being wrong. I have found out how to export a simple 3d part from autocad as a dxf but Solidworks... hmm.. I have no clue for now.
Sorry. I'll look at it later if I get a chance. Other work related project issues are a little more important as of now though.
It's been a crazy day so far, and is getting crazier.
TGIF! lol
Unread 10-02-2006, 13:46
Engineering Mentor
FRC #0254
I was able to create everything in autocad and save it as one of a few different dxf formats that retained the 3D aspects of the drawing.
All is fine now. I appreciate the help.
-Travis Covington
Unread 09-03-2006, 23:55
Darrel Lampley Darrel Lampley is offline
Darrel Lampley is an unknown quantity at this point
Youcan export Solidworks to .SAT, then "ACISIN" into the DWGEditor where youcan save it as a DXF.
Unread 03-05-2006, 21:46
CalvinEiber CalvinEiber is offline
FRC #1308 (Ignatius Wildcats)
CalvinEiber is an unknown quantity at this point
I think there is also a way to save a drawing as a .dfx. I know the company that I work for has that, but I suspect it may be some kind of mod or macro.
Solidworks Files Panther378 Technical Discussion 1 21-01-2006 22:34
(SolidWorks) Create Sketch Points Around Curve Yan Wang Inventor 6 04-08-2005 21:20
