Go to Post IMO, everyone should experience at least one Battlecry. - Dan Petrovic [more]
Unread 10-03-2006, 13:14
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
wiring color question
Hey guys,
One concern we have for competitions is our wiring. We used color coded wiring so we could follow wires easily, for example CIM1 uses blue and yellow wires, CIM2 uses purple and red wires. This made wiring very easy this year. We also used red heat shrink for positive and black heat shrink for negative, but only over the last two inches of the wire to cover the connectors. Hence, you can tell that the wire is positive or negative, AND you can trace the wire across the chassis. There is a rule that says your wires should be red for positive and black for negative, I forgot which rule number it was. Now, do the wires have to COMPLETELY be red or black? And will our funky color coded wires pass inspection?
Thanks.
Unread 10-03-2006, 13:36
527point 527point is offline
FRC #0527
527point is an unknown quantity at this point
Send a message via AIM to 527point
Re: wiring color question
while i like this idea if you personally can tell which is which, i don't think the rules are very forgiving:
5.3.9
<R81> All wires distributing power with a constant polarity (i.e., except for Relay Module, Speed Controller, or
sensor outputs) must be color-coded as follows:
• Use Red, White, or Brown wire for +12 Vdc and +5 Vdc connections.
• Use Black or Blue wire for Common (-) connections.
___________________
Plainedge HS Robotics -- 527
Unread 10-03-2006, 13:38
<R81>:
All wires distributing power with a constant polarity (i.e., except for Relay Module, Speed Controller, or sensor outputs) must be color-coded as follows:
The rule says "must", not "should". However, it's not explicit about about the entire wire being of the specified color, so maybe your heat shrink at the ends will count as making it "color-coded". I don't know how flexible inspectors will be about it.
Unread 10-03-2006, 14:35
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
5.3.9
Note also that it says "except for ... Speed Controller ... outputs". If you just used the color-coding scheme on the run from the Victors (or Spikes) to the motors, you should be just fine.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 10-03-2006, 17:48
Thanks for all your input.
Just one question: As Eldarion brought up, this excludes victors and spikes and sensors. So, if the only color coded wires are the ones from the victors/spikes to the motors, we should be fine? We still have red/black wires giving power to the victors/spikes.
Thanks everyone.
Unread 10-03-2006, 17:55
yes, if your rainbow wires are on the output side of the Victors and Spikes you are ok.
There is no polarity issue there- if you wire a motor backwards it will happily run backwards - it wont burn up like a Victor would with reversed power.
Unread 10-03-2006, 18:19
Veselin,
As an inspector I would really need to see the robot before I would pass on this. On the surface it seems to satisfy the rules but the inspector is there to make sure that the robot is safe to compete and easy for field volunteers to help you run in case of problems. I wouldn't expect an automatic pass on this at any or all competitions you attend. (what passes at one event may not pass at another) I always recommend color coding wires, and we use color coding tape on everything including PWM cables, speed controllers, wires, motors and circuit breakers.
Unread 13-03-2006, 12:48
GB330033 GB330033 is offline
Programming Manager
FRC #1255 (Team Blarglefish)
GB330033 will become famous soon enough
Send a message via AIM to GB330033
I can't tell you about this year, but last year my team wired everything in green and white wire, in no particular pattern. However, we did wrap the ends of the negative wires in a bunch of electrical tape, so you could tell it was negative. The inspectors said it was fine (I made sure to ask just in case) and we went about our business.
Hook'Em
Unread 25-03-2006, 13:32
RoboCoach RoboCoach is offline
AKA: John
FRC #0128
RoboCoach is on a distinguished road
Send a message via Yahoo to RoboCoach
For some of the power wiring, what we did was take the black and red wires, chuck them into a drill and twist them together (not too tightly as to compromise the insulation). This makes for a neat cable that can be traced across the chassis without much of a problem.
Taking this one step further you could twist onto the red/blk bundle a third 'tracer' wire of a different color (and maybe lighter gauge) to identify that particular pair.
Discovery is seeing what everyone else has seen and thinking what no one else has thought. --Albert Szent-Gyorgi
Unread 25-03-2006, 23:42
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Originally Posted by Al Skierkiewicz
Veselin,
We followed Al's advise this year and it has been a great help in troubleshooting a problem.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 26-03-2006, 09:38
John,
This isn't a bad idea. Teams should be cautioned to not wind the wire so tightly that it stretches (reduces the cross sectional diameter and current handling ability) or squeezes the the insulation such that the wires will become shorted.
Wiring the robot in inventor. vVigglEs Inventor 15 06-03-2006 11:35
Excellence in wiring - post your pics sanddrag Robot Showcase 32 15-02-2006 23:09
The importance of clean wiring sanddrag Electrical 20 14-02-2006 20:04
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
