Go to Post I heard that the only gift UFH wants on its birthday is an inbox full of nominations. :D - Brandon Martus [more]
Unread 10-03-2006, 21:39
AJunx AJunx is offline
AJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to all
3.2.3 Center Goal
To all those who made the NASA/VCU Regional go so smoothly--considering all of the difficulties associated with hosting a first-week regional-- Thank You.
Now, on to business.
Does this sound familiar?
"SHOOT SCORE...SHOOT SCORE...SHOOT SCORE, oops, ummm...SHOOT SCORE"
Rule 3.2.3 of the Revised Competition Manual states:
The Center Goal is located above each Alliance Station. The center six-foot section of each Alliance Station Wall extends to approximately 10-1/2 feet above the floor. A 30-inch diameter opening is located in the extended portion of the wall, centered at 8 feet, 6 inches above the floor. The opening is outlined by a 4-inch wide border of red or blue acrylic. The opening is backed by a rope mesh and suspended chains to absorb the impact of any scoring objects going through the opening. Scoring objects passing through the opening will be deflected downward by the mesh, and will exit the Center Goal by dropping into a collection tube at the bottom of the goal. There, they can be retrieved by the Human Players.
As you can see, I have highlighted, italicized, and underlined at my discretion. Why? Because I watched many a "scoring object" bounce right back out of the center goal at VCU.
Were any matches swayed one way or another due to "bounce-back"? I can't say; however, I can say that I witnessed, on multiple occassions, two out of five balls shot into the center goal bounce back out, never to be counted among the lucky poof-balls who so willingly gave their lives to the AIM HIGH cause.
Now I have questions for you:
1) Have you witnessed bounce-back at your regional?
2) If so, have you seen any attempts made by FIRST to reduce the pervasiveness of bounce-back?
3) If you have not witnessed bounce-back at your regional, what does the netting situation behind the center goal look like? (i.e. what has changed?)
4) Do you find the occurrence of bounce-back ______________?
A) Acceptable
B) Unacceptable
Have a good day.
-Andrew
Unread 10-03-2006, 21:49
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: 3.2.3 Center Goal
1) Yes. It seems to be worse when shooting straight on.
2) No.
3) Nothing has changed.
4) A. This is definitely part of the challenge FIRST has given us. If they saw an issue with bounce-back, they would change the situation. FIRST loves to see us franticly coming up with ideas; it's exciting for me to watch the people in the next pit going "It wasn't like this in the shop!" So, I don't see any problem with bounce-back; it's just part of the game.
Cheers,
JBotAlan
Aren't signatures a bit outdated?
Unread 10-03-2006, 22:10
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
You know, i had a feeling that something like this would happen. like i guessed at VCU they would only use solid neon bright green poof balls to throw off the camras, or something like that, to pose a task for teams AT the regionals on the spot. guess i was right.
Unread 10-03-2006, 23:10
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
From what I could tell from the Wildstang invitational, this is only an issue for teams that put a lot of backspin (or forward-spin) on their balls.
We shoot without much spin at all (more like a rifle bullet ) and haven't seen this issue (yet!).
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 10-03-2006, 23:49
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
as far as i remember from VCU, ther were counting those balls and points. I mean if the ball goes inside the goald and bounces back, it counted in as 3 points. Thats why me and my team was ok with this situation.
Unread 11-03-2006, 01:32
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
That's quite interesting if they did count them as scored, because I believe somewhere (rules or Q/A) it explicitly says, balls that bounce out do not count.
Was this actually happening?
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 11-03-2006, 01:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Not really...FIRST told us about the chains from day one. They were a design constraint that had to be thought about when you made your robot.
It's not like they suddenly sprung the chains out of nowhere in week 1 just to screw with our heads.
2001-2004: Team 100
2006-Present: Team 254
Unread 11-03-2006, 02:22
Eldarion's Avatar
Right, the things sprung at us as regionals were:
1) The interrupt bug (OK, while not at regionals, after ship nonetheless )
2) The 8.2V bug
-- Thomas Paine
-- Anonymous
Unread 11-03-2006, 02:55
George A.'s Avatar
George A. George A. is offline
I come through in a spinsch
AKA: George- The Voice
FRC #0303 (TEST Team)
George A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond repute
Send a message via AIM to George A.
I always thought that the balls had to fall down the chute in order for them to count...since that's where the sensor is.
My Volunteer Resumé
Game Announcer NJ: 2005-Present
Game Announcer Philly: 2006-Present
Game Announcer NY: 2005-2008
Game Announcer Champsionships: 2005-2008
Unread 11-03-2006, 21:48
sgsdragons's Avatar
sgsdragons sgsdragons is offline
Team1595
AKA: Josh Lambeth
FRC #1595 (The Dragons)
Team Role: Driver
sgsdragons will become famous soon enoughsgsdragons will become famous soon enough
Thats what I thought also. I was watching the Arizona Regional on NASA TV(Before the feed got all screwed up and I couldn't watch anymore, but thats another story) and in one of the matches, the balls got stuck in the center goal during autonomas and they had to knock them down so they would be counted. They have to go through the chute to be counted.
Josh
Team Driver/Designer
2005 Pacific Northwest Regional Winners
2005 Pacific Northwest Regional Judges Award Recipiants
Our Team would like to thank both Team 492 and Team 604 for helping our team win the Pacific Northwest Regional.
2006 Season...
Reginal Event: Las Vegas!!!
Nationals: Atlanta!!!
Unread 11-03-2006, 22:09
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I noticed in some videos that there was a person standing behind the teams with a long stick to unjam balls.
Unread 11-03-2006, 22:19
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
2) The 8.2V bug
IFI did a very good job working around these difficulties. I know it wasn't discovered until Week One, but at UTC they explained the bug in very clear language and provided all teams with a sheet with instructions on how to modify the compiler behavior to avoid the issue. Maybe someone who has one of the sheets could post it on CD so anyone interested could find out about it?
Unread 11-03-2006, 22:35
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
i think bounce back is part of the game. if you read carefully it was actually kinda in the hint the "pasta" could have been the pool noddles or the chains in the goal.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 11-03-2006, 22:49
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
1) Yep, mostly by 1276 cause they got up onto the ramp and shot from there so quite a few bounced out.
2) No
3) Same as always
4) Acceptable. Every team agreed with the rules and they should have no reason to complain about the bounceback. It's a part of the game and if the match is lost due to bounceback situations, then you had better fix it if you care enough.
Unread 11-03-2006, 23:23
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Very few robots had problems with bounce back at AZ from what I saw. We had one ball bounce it (in autonomous), and that was because it hit very low in the goal and hit lexan only, no chains. For all the matches I saw, any problems with bounce back occurred when teams fired rapidly into the goal (many balls piling up and spilling out, or the chains swaying alot from all the shots and tossing balls back out).
Will the Center Goal be able to keep up? Nitroxextreme Rules/Strategy 2 26-01-2006 19:08
When does a center high goal really get scored? dhitchco Rules/Strategy 14 12-01-2006 16:10
Midfield Collisions Swampdude General Forum 36 31-01-2005 23:51
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
