Go to Post You can learn a lot from making mistakes - even more from fixing them. - DarrinMunter [more]
Unread 11-03-2006, 03:10
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Unhappy Confused about potentiometer values
We're trying to solve a problem using a steering wheel. We tried using a joystick potentiometer hooked up to the operator interface but, when we spun it to the 270 degrees that we needed, it only gave us the values from 127 till 170 while turning 45 degrees left and right of center. What kind of potentiometer should we use to correct this. We want it to read from 0 to 254 for the full 270 degrees.
Unread 11-03-2006, 08:18
Re: Confused about potentiometer values
On the OI, you need 100 kohm linear taper pots. Do you know what value you were using?
You can get one that works for about $3 at Radioshack.
Unread 11-03-2006, 15:54
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
You can get them much cheaper from places online, such as Jameco or Digikey...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 11-03-2006, 16:10
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
We were using one pulled out of a joystick. Could the problem have been those potentiometers really only move 45 degrees, and as such, only effectively work through that range?
I am off to buy a radio shack 100k ohm pot and see if that fixes the problem.
Thanks!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 11-03-2006, 16:29
DonRotolo's Avatar
Back to humble
FRC #0832
Joystick potentiometers have a total of 90 degrees of rotation, and the full zero-to-100k Ohm range is limited to that 90 degree movement. A standard pot has around 300 degree rotation for the 100k range. Make SURE you use a LINEAR (also called B-Taper) potentiometer, NOT an A-Taper (Audio) pot!
Umm, how exactly do you have the pot connected? 127 to 170 is not a good thing, but maybe it's not connected right. There are three terminals on a pot, you need only two, the center and one end. (Your choice of end depends on whether you want the value to increase or decrease when you turn it clockwise). The one end goes to Pin 1 of the 15-pin OI port, the other end goes to Pin 3, 6 or 13 (depends on whether you want it to be read as X, Y or Thumbwheel axis, respectively). See the schematic. Any other connection would bring problems.
Good luck,
Don
Camera Lighting Values At Regionals nukem Programming 5 06-03-2006 18:47
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Do you need the exposure values? Code\\Pilot Programming 5 20-02-2005 20:08
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
Confused about Camera AnkurG Programming 5 26-01-2005 19:50
