Go to Post However, in the end, the renderer is only as good as the artist. - MiNT [more]
Unread 10-03-2006, 18:45
PIRATECAPTIN's Avatar
PIRATECAPTIN PIRATECAPTIN is offline
Logo desigenr
AKA: Jim aka Paul Bunyan
FRC #1732 (Hilltopper Robotics)
Team Role: Marketing
PIRATECAPTIN is on a distinguished road
Tubbing problem
How do you creat tubbing in Inventor? I really need to figure out how so I will be able to finish of my team's CAD drawing.
Yo ho! Yo ho! A Pirate's Life for me!
-Pirates of the Carribean
Unread 10-03-2006, 19:02
Logo desigenr
Re: Tubbing problem
Originally Posted by PIRATECAPTIN
How do you creat tubbing in Inventor? I really need to figure out how so I will be able to finish off my team's CAD drawing.
spelling error
Unread 10-03-2006, 23:39
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Tubbing problem
Are you having trouble with the tub or the jets?
Unread 11-03-2006, 00:13
Ebolagirl's Avatar
Ebolagirl Ebolagirl is offline
I <3 Inventor!!!
AKA: Tracey
FRC #0418 (Purple Haze/LASA Robotics)
Ebolagirl has a spectacular aura aboutEbolagirl has a spectacular aura aboutEbolagirl has a spectacular aura about
Send a message via AIM to Ebolagirl
Re: Tubbing problem
What kind of tubing are you trying to create? Please be more specific.
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot."
-Someone
My other passion... http://www.cdc.gov/ncidod/dvrd/spb/m...s/ebola/qa.htm
Isn't it adorable?
http://www.giantmicrobes.com/calamities/ebola.html
Unread 11-03-2006, 20:58
Logo desigenr
Re: Tubbing problem
It is 1/4" PVC pipe. We use it to make a circular "ramp" inside our helix. I also need help with rubber band like material used for the conveyor and the wires.
Unread 11-03-2006, 22:27
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Re: Tubbing problem
I think your best bet for the helix is the "coil" feature. The initial sketch is the same as if you were revolving it (axis and circle dimensioned so it is the correct radius away. Then define the variables (which are pretty self-explanatory) and you have a helix. It will be a bit tricky to constrain, so make sure that you are centered on the origin so you can constrain with work planes.
Inventor is really no good for the flexible materials, so the best bet is to make a profile path in a 2D or 3D sketch and then sweep the correct profile. For this you need two sketches, one for the profile (from what it sounds like, just a circle), and another for the path (be it 2D or 3D)
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
The best thing you can do when reporting a problem .. Brandon Martus CD Forum Support 1 08-02-2006 07:46
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
