Go to Post Sometimes our greatest failures lay the foundations for our greatest success. - =Martin=Taylor= [more]
View Poll Results: Do you think all the penalties are fair?
Sure, Why not 45 35.71%
Definately Not 19 15.08%
Yes, but a few could be changed 62 49.21%
Voters: 126. You may not vote on this poll
  #31   Spotlight this post!
Unread 13-03-2006, 12:39
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: 2006 Penalties
Originally Posted by cmaccoy
-If you interrupt the sensor system (go further then 3 inches in the side goal) your entire alliance is disqualified.
This is only durring elimination rounds not durring qualifying matches. Durring qualifying matches the team that is dq'ed is the only one that suffers penalties (so that alliance can still win).
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
  #32   Spotlight this post!
Unread 13-03-2006, 12:59
Re: 2006 Penalties
Where is Barney Fife when you need him.
Two years ago if you broke the plane of the goal you were penalized
this year they gave you three inches. I dont think the intent was that 2.99" incursions are OK. [Fife] you give them 1 inch and they'll take two, you give them two....[/Fife]
Are the corner ref's able to tell if the incursive robot has triggered the ball counter? That is the reason for the rule. If your bot triggers the counter and the score shoots up by 50 points that is a real mess to straighten out at the end of the match.
Also, the fact that you measured the front of your robot and its only 2.5" long doesnt mean that for every possible angle and condition it will not exceed 2.5". For example, if your bot lifts up its front wheels it may be able to extend further into the goal.
Bottom line is, if your bot triggers the ball counter you should expect a penalty.
  #33   Spotlight this post!
Unread 13-03-2006, 13:49
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Re: 2006 Penalties
My concerns are as follows:
-There are no "instant replays" so we can't have the refs look at the incident a few times to confirm.
The rules aren't that bad this year but still they could be edited.
I definitely agree that there needs to be a camera in place where these types of penalties may occur. I also believe that there needs to be a vertical view of the field recorded during the entire match to be reviewed in the case of high goal scoring issues. It turns out that the goal of making a ball in the high goal is to trip the sensor at the top of the tube, not to make a ball through the bit red/blue circle. Our team made 3 balls in autonomous mode, but only 2 were counted because 1 got caught in the goal and didn't roll down to the tube. Because of this, we lost autonomous and ended up losing the match. Had the match been scored correctly we would have won. When our team approached the judges with video of this, they wouldn't look at it.
  #34   Spotlight this post!
Unread 13-03-2006, 14:00
Re: 2006 Penalties
Its been in the manual since day 1.
Refs will NOT looks at any videos after a match, from any source.
  #35   Spotlight this post!
Unread 13-03-2006, 14:21
Volcomdude412x Volcomdude412x is offline
Biggest Pimp in tha 'burgh
AKA: Alex Rajcsok
FRC #1708 (Natural Selection)
Volcomdude412x is an unknown quantity at this point
Send a message via AIM to Volcomdude412x
Re: 2006 Penalties
We kinda got screwed eac time we attempted to score, each time someone came up and rammed us causing our corner of our robot to enter the side goal, i think it should be changed so that this problem can be fixed
  #36   Spotlight this post!
Unread 13-03-2006, 15:40
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: 2006 Penalties
The corner goal DQ is pretty annoying. The whole "approximately 3 inches" is so judgemental at the time it occurs that you can get penalized when it didnt do any harm. It's also annoying that the robot that is pushed in is DQ'd, there should be no reason to DQ them for something they can't control, but atleast the one who pushed you in gets DQ'd.
As for ramming, I don't really mind that penalty...if you're trying to ram another robot to disable it, you deserve a penalty. However the Autonomous mode ramming is a tough subject to deal with. A team angled towards our bot and rammed us preventing us from scoring in the corner goal during autonomous and got a 5 point penalty. It should be more during a regular match since you have more control over it.
As for the offsides penalty, that really upset me. A call was made that one of our alliance partners crossed the line 3 times, but we have 3 videos showing they were 10 feet behind it. The Ref must have been confused about it or something. The one thing that upset me the most was that he didn't even know who he called it against, when we questioned it, all he said was "You should have discussed it better before the match, and you're lucky i only threw three flags becuase it should have been more." The other annoying part was that the only way for the score to be over turned was for all 6 teams to agree to have it changed....sure FIRST is about GP, but the teams that are in it "just to win" won't even think about giving up a win.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
  #37   Spotlight this post!
Unread 13-03-2006, 16:03
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: 2006 Penalties
I have a question about the exact definition of ramming.
If redabot A and bluabot B are both going at high speeds and collide is that a ram? and if yes who is it on? This is basically what people are talking about in autonomous, when one robot drives to the center to shoot to the goal and the other one drives and they have a high speed collision, I don't think any penalties should be called in this case, auto or regular mode. Now if a team is sitting there and someone comes flying across the field that is a different story.
Penn Class 08
  #38   Spotlight this post!
Unread 13-03-2006, 16:15
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: 2006 Penalties
I agree with you, but we didn't go past the black line and into the scoring panel... there was no mess up with the scoring. The team on the opposing alliance that was stationed beside the goal even said that we didn't go in...
and we made sure that from pretty much every angle we couldn't go in.
I really appreciate the refs and what they do for us, but I am just trying to point out that all of the calls they made were not perfect, and some were downright unfair. I also want to point out that the rule was 3", and we were a full half of an inch under that... If you want me not to be snippity about a half of an inch, then somebody talk to the refs about giving a penalty to a team because the driver had their toe over the line during autonomous...
The thread is about weather or not all of the calls were fair, and I am just out to prove that they weren't.
  #39   Spotlight this post!
Unread 13-03-2006, 16:16
Re: 2006 Penalties
I saw so many offsides penalties at the FLR last weekend it made me think that many teams dont understand what the offsides foul IS.
the whole nearBot/BackBot/FarBot confusion.
I dont think all these teams were deliberately playing offsides - I think it was a mistake or confusion on the part of the driver.
So you really got to stop and ask yourself: if the ref called your team offsides are you SURE he was wrong?
  #40   Spotlight this post!
Unread 13-03-2006, 16:22
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: 2006 Penalties
You need to keep in mind that the opposing alliance, though well-meaning, was most likely very much occupied with their own robots at the time. That is the reason for the refs/volunteers in the first place. The penalty was called by a ref standing at the goal, and reinforced by Pika1579 who was the manual counter at that position and whose job it was to keep a constant watch on what went into and out of that specific goal. It is a hard call to make, and harsh penalty, but you must consider the possibility that they weren't wrong in the call.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
  #41   Spotlight this post!
Unread 13-03-2006, 16:25
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: 2006 Penalties
I think the rules are very fair. It's those who try to bend the rules as far as physically possible that are having issues. Here's a thought, build a robot that doesn't break any rules from ship? Because then guess what...NO PENALTIES!
Sorry to sound so brash, but I've been a ref since 2003...and it never stops. Before you say that the refs are all on an ego and power trip, why don't you try it and then once you've experienced how DIFFICULT being a ref is, make your judgment. Have I screwed up...yes, and I am sincerely appologetic for those who the screw up affected. We are all human, and being a ref can be so demanding...you have to constantly watch each robot, the field, interaction between bots, offsides, 5', and pinning countdowns. There just simply is way to much to focus on and call everything 100% correctly, I would probably say all refs do about a 98% accurate job of calling the game. If you have any problems with your outcome TALK TO THE HEAD REFEREE!!!
So my moral? Put yourself in our shoes before you run the marathon...you'd be suprised in what you may learn.
PS. STOP BASHING REF's...email FIRST and your issues will be promptly reviewd and during the head ref meetings will be discussed.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
  #42   Spotlight this post!
Unread 13-03-2006, 16:27
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Re: 2006 Penalties
Okay, I concede... there is about a 2% chance that the STEEL was bent out of place by a half of an inch, and then bent back into place, perfectly as it was in the beginning of the match, before the match was over.
P.S. I did not intend any of my posts to bash the refs, I am simply stating (as this is what the thread is about) that no, they do not make 100% accurate calls... nobody could. We are only human
  #43   Spotlight this post!
Unread 13-03-2006, 16:28
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Re: 2006 Penalties
I believe we were called once or twice for being off-sides when I hadn't thought we were, but then I really wouldn't bet my life (or my robot) on it. Once, we were supposed to play backbot and our driver moved towards our alliance station before moving to the back side of the field...that was a rightful penalty, we needed to have been moving back by then. Miscommunication between myself and the driver caused that.
Since none of the penalties cost us a match, though, I really can't speak for how I'd feel then about a call I wasn't sure was warranted. I do know, though, how I felt when we "lost" a match we knew we won. Something was wrong with the scoring system; I honestly don't know what it was. If anyone knows what the problem was during match 5 of Friday at Pittsburgh, please post it. We simply couldn't let that match go. It was a 2-on-2 match, us and 1727 versus 1370 and 365. We played extremely hard and stuck to our strategy; we knew that was the only way we'd beat those two awesome teams. We knew we'd won, but the results said we didn't. Our driver went and talked to the refs, and they reviewed the scores. I'm not sure where it was eventually decided the error was, but they found one and actually corrected the scores - and we had won.
Edit:
ORIGINAL: Greg Perkins
(snip)
You posted while I was typing mine...you're completely right. We were very content with how the head ref handled our concerns; we asked if they were sure the scores were correct, and they checked them for us. The refs want the games to be fair, otherwise they wouldn't be refs. Ask them about any potential discrepancies, but remember to bring your GP when you do.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
  #44   Spotlight this post!
Unread 13-03-2006, 16:31
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: 2006 Penalties
Specific to your robot, there was also a cable tie that was sticking off your robot into the goal... The refs aren't out looking to make alliances lose points they're looking to make sure that the games are fair...
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
  #45   Spotlight this post!
Unread 13-03-2006, 16:38
George A.'s Avatar
George A. George A. is offline
I come through in a spinsch
AKA: George- The Voice
FRC #0303 (TEST Team)
George A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond repute
Send a message via AIM to George A.
Re: 2006 Penalties
I really don't think the penalties are all that unfair. I mean they're simple enough to follow. Either have one of your robots behind the line when it's supposed to or get penalized. Don't go in farther than 3" or get penalized.
One easy way of avoiding the Incursion DQ? Make it so your ball deployment system CAN'T fit in the corral. If the deployment system is so ridiculously huge that it can't fit in then there's no way to get penalized. IMO if your deployment system has the risk that it could get pushed in at a certain angle then you're playing with fire and you're going to get burned.
It's foolish for anyone to think that their opponents will just sit idly by and let their opponents score. They're going to play defense, and as such they might end up pushing their opponent into the corner corral. The action is at the opposite end of the field from the drivers so they can't tell.
And here's a sob story for you...
MY team (11) were in the final match in the 2001 Championships on Galileo field before allaince pairing. We were in 6th place and barring any catastrophe's it looked like we were going to elims. The first robot went over the teeter-totter bridge...and the bridge popped off the fulcum making it immovable, as such we couldn't score, so we shut the clock and took the points we could. The end result we get a horrible score, our rank gets dropped from 6th to ninth. We miss 8th place by .5 points, and we don't get picked. When we talked to the ref about a redo since the field broke, they said that it wasn't their fault as it was an "Act of God' . Granted, we didn't like the ruling but we lived with it, and next year we made sure that our robot would be able to adapt to field conditions.
Sorry for the ramble, but the rules are the rules, if your risking coming close to incursion...find another way to score or live with the penalities that you might acrue.
My Volunteer Resumé
Game Announcer NJ: 2005-Present
Game Announcer Philly: 2006-Present
Game Announcer NY: 2005-2008
Game Announcer Champsionships: 2005-2008
White Paper Discuss: Updated - 2006 Penalties and Scoring AmyPrib Extra Discussion 3 29-01-2006 20:21
White Paper Discuss: 2006 Penalties and Scoring AmyPrib Extra Discussion 4 10-01-2006 15:38
Are The Penalties Too High? AJunx Rules/Strategy 49 06-04-2005 20:37
On Rules, Referees, and Rewards (aka Penalties) RyanMcE General Forum 29 21-03-2005 13:20
