Go to Post Our team has a forum..... chiefdelphi.com Ok I had to say it. - Mike Martus [more]
Unread 13-03-2006, 23:19
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Fuse Block and Panel Dwgs
I am trying to CAD out a new electronics configuration for my team's robot. I found the drawings for the Robot Controller, the Victor 884s, and the Spikes on IFI's website. Does anyone know where to get drawings for the Maxi Fuse Block and the ATC Fuse Panels? I need drawings with correct measurements, preferably manufacturer specs, for the screw locations and to determine my overall layout.
Thanks,
indieFan
Unread 13-03-2006, 23:38
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Fuse Block and Panel Dwgs
Thanks,
indieFan
Right here
http://www.firstcadlibrary.com/
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-03-2006, 01:14
FRC #5941
Originally Posted by Coffeeism
Thanks, but I'm using AutoCAD which I don't believe will read any of the file types available here. (I'll double check it, though.) What I'm really after are engineering drawings in something like a .pdf format.
indieFan
Unread 14-03-2006, 01:20
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
indieFan
The import feature (under the Insert menu) should allow you to import STEP and IGES files. Also, if you install inventor, it can export to those two filetypes aswell. I've had no problems using the CAD library with AutoCAD.
Unread 14-03-2006, 01:39
FRC #5941
1. Thanks for letting me know about importing. I'm used to exporting .stl files, but I never use the import stuff.
2. It turns out that I have AutoCAD Architectural 2i (from 2000) which is unable to open the .sat files. *argh*
I'll see if I can get them opened at work during lunch tomorrow.
Labview Video Tutorial? Dashboard Chris_Elston National Instruments LabVIEW and Data Acquisition 21 25-01-2008 00:29
Breaker Panel not in this years kit? 527point Electrical 26 14-01-2006 00:50
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Help with understanding Fuse panel Blue_Midnight Electrical 3 10-02-2004 23:12
