Go to Post any robot that can hold and transport its team has found its purpose and can be considered complete - Nitroxextreme [more]
Unread 13-03-2006, 13:00
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Back-up battery charging circuit from IFI
After a fun weekend with the back-up batteries, we were told about the back-up battery charger on the ifi website that charges the back-up battery from the robot's main battery.
Has anybody made this circuit and if so, what are your thoughts, suggestions, etc. We want to make one in the fix-it-window before the Detroit Regional, but any lessons learned, advice, or whatever is appreciated.
Thanks.
Link:
http://www.ifirobotics.com/docs/firs...up-charger.pdf
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 13-03-2006, 13:12
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Back-up battery charging circuit from IFI
We learned that the 8.2V zener is absolutely necessary.
Luckily we tested the output with a multimeter before putting it on the 'bot...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 13-03-2006, 13:14
The Lucas's Avatar
CaMOElot, it is a silly place
The backup battery should be charged initially at bot startup or your camera will have problems.
Robot Inspector
Unread 13-03-2006, 13:21
Don Wright's Avatar
FRC #0469
It will be. But we just want it so that the back-up is actually what it is called, a back-up battery for powering the RC when the main battery dies.
We just want the charging circuit so that the camera servos and other servos don't drain our back-up batteries during testing and a match.
Product Manager
Unread 13-03-2006, 13:42
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
We used it, the only problem we had was a slight trickle through of power to the RC when the breaker was open and the backup battery connected, it wasn't even really a problem, somewhat amusing is all. I don't think we ever had to remove our backup battery and everything worked great for us, it gets a thumbs up from me.
Matt Krass
Unread 14-03-2006, 09:09
Don Wright's Avatar
FRC #0469
Anybody else?
The circuit looks a little "interesting" to myself and some co-workers, so I'm looking for some experiences of it working.
We are probably going to try it anyway...
Product Manager
Unread 14-03-2006, 09:16
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
At my school we used the Vex backup batteries, which are more powerful, and last longer. Also they can be quick charged using a standard RC car charger. We had three we rotated, and it worked perfectly .
My Blog!
Unread 14-03-2006, 13:31
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Originally Posted by Don Wright
Anybody else?
I've got one that I wired up, but in the haste to ship it never got onto the bot. It seems to work fine in bench tests.
Unread 24-03-2006, 18:59
Barry Craig's Avatar
Barry Craig Barry Craig is offline
Crazy Mad Filer
FRC #1852 (Team Amore)
Team Role: Electrical
Barry Craig is an unknown quantity at this point
My team had the same thing happen. We also discovered that if you push the robot for a few yards while the breaker is tripped and even when the Anderson connectors are unplugged, the same thing happens.
Barry "Barricus" Craig
Electrical Head/Leadership/Hammer & File Man
Team Amore 1852
"Details, details!"-Mentor Mark Johnson, on everything that we thought was important.
2006 AZ Regional - 8th Place, Highest Rookie Seed Award, Judges Award
Amore Robotics
Unread 24-03-2006, 20:42
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
The reason that happens is because the motors are acting as generators, powering your breaker... I wonder,
If you push your robot too fast, could you burn anything out?
Unread 25-03-2006, 01:36
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
One recommendation I would make after seeing the schematic is to mount the LM317T (regulator) to a heat sink or piece of copper. This is the unit handling the power dissipation and it may get too hot.
And of course you could blow something by pushing your bot. Voltage is voltage, and current is current (i wont say resistance is resistance because negative resistance gets tricky) But, the motors would have to spin faster than they do with the power on.
Unread 26-03-2006, 12:33
We originally thought that might be the case, but after testing the completed circuit it turned out heat dissipation isn't a problem at all. A plastic housing will work fine.
Unread 18-04-2006, 21:45
DonRotolo's Avatar
Back to humble
FRC #0832
Note that the tab of the LM317T is electrically hot, meaning it has output voltage (and not ground!) on it. It needs to be electrically isolated from everything else.
We built the circuit, and saw the same issues as others: The backup battery 'powering' the bot, making for some anxiety but no real issues. We used it for testing, but took it off for competition.
Anyone wants a PC Board etching pattern, PM me.
Don
Unread 18-04-2006, 22:35
AKA: Bert JW Regeer
My team wanted to reduce the amount of extra electrical components on the robot, so we used the Vex batteries which are also 7.2 Nickel Cad, which are allowed under rule R68 (IIRC), which allows any replacement backup battery. You get longer runs with them, and charging them is the same as charging RC batteries, so they can be quick charged in 15 minutes, so with two there should be almost no downtime.
They do add a bit more weight, but it is negligible compared to what you get in return, which is extra power for the camera and servo's as well as anything else that gets it's power from the RC through the backup battery.
Edit: Seems I had already told my story, sorry for the double posting
My Blog!
Unread 20-04-2006, 13:45
Alex G Alex G is offline
FRC #0201 (FEDS)
Alex G is an unknown quantity at this point
There are two problems with the schematic from IFI. The first one is that if the 8.7V zenner comes off or breaks, you risk supplying a full 12V to your RC and backup battery.
ANother problem is that of the main battery is dosconnected, the backup battery will end up "replacing" the main battery. It will supply power to the motors through the 43 ohm resistor. At 7.2 V, the power dissipation inside that resistor is about 1.20W. You will end up frying the resistor.
My recommandation is that you add a diode(any diode that can take over 1A will work)before the output.Disconnect the "+" ouptut, and connect the anode of the diode to it. Connect the cathode to the wire you just disconnected. Or just build a new circuit with the extra diode. This will prevent power from the backup leaking back if the main power drops too much, or the main battery is disconnected. However, this modification will not protect the backup if the 8.7V zenner fails.
Dead battery! krhs_programmer Electrical 19 11-02-2005 07:31
Back up battery Jeremy General Forum 3 25-02-2004 09:56
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
