Go to Post Deadlines are part of everyday life. - Steve W [more]
Unread 14-03-2006, 11:05
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: External Output Device
The default code has an example of using the user byte to display the backup battery voltage in the numeric display on the OI.
Otherwise, I think you can use the dashboard, in conjunction with your operator interface to display data values. Then you could output the data on an unused PWM and display that.
Unread 15-03-2006, 07:57
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
You can use the dashboard port with a laptop. Another option is to directly use an LCD like what Kevin Watson posted some pictures of his color screen he used during camera code testing. There are more ways involving custom PCBs, but those 2 are the easiest ways.
Unread 15-03-2006, 08:13
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Smile Re: External Output Device
Hi Crhis! That was a great info. However can you please provide a bit more of detail regarding how kevin actually did it? Like we already bought our LCD. I just want to know how to hook it up to the Operator Interface. After reading through PDF's i herad that you can see the outpouts from dashboard port. However do you actually need extra software(environment) to see the outputs? Or is it as simple as plugging in LCD or Laptop to Dashboard port and it will work?
Unread 15-03-2006, 08:23
Billfred's Avatar
Billfred Billfred is offline
Yes, you will need to use some software to translate the Dashboard data to something a human can comprehend. You can use IFI's Dashboard program (on their website), use LabVIEW's VI for Dashboard data (search CD for it), which has the added benefit of working with Macs, or rolling your own, if you possess 1337 h4x0r skills.
Unread 15-03-2006, 08:31
Jigar Patel
AKA: Jigar Patel
WOW! Amazing that was very helpful information its like right on dot thanks!
Ultrasonic Sensor output Dillon Compton Programming 5 03-02-2006 10:20
Output Error magical hands Programming 3 18-01-2006 18:54
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
