Go to Post Hall of Fame FIRST Team 254 has arguably helped more teams become good than any other team in FIRST. I don't think they need a lecture on helping their opponents. - Karthik [more]
Unread 14-03-2006, 11:01
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Attention tipped over robots! Please use the e-stop button.
Originally Posted by M. Krass
In years past, I recall that it was possible to reenable your robot using that same button. Is that still possible?
...I'm imagining a situation where a robot is 'disabled' in front of a corner goal for the duration of a period and reenabled so as to continue playing.
I'm not saying I'd do it, but I'm curious if it's possible.
No. Once disabled you are down for the count.
Wetzel
Viva Olancho!
Unread 14-03-2006, 11:20
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
This will be discussed in the Head Referee conference call as I don't believe the referees have any way of knowing if an E-stop button has been used. I'll report back on this issue after the call.
PLEASE NOTE though, that the head referee at the event makes the final call. It is always best to ask the question at the driver's meeting prior to the start of competition.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 14-03-2006, 11:38
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
I thought your team station light flashed when your disabled, via estop or via field disable.
In any case, if you KNOW you wont be able to be righted, might as well hit the estop just to be sure.
Unread 14-03-2006, 12:16
Godzilla!'s Avatar
Godzilla! Godzilla! is offline
a
AKA: Ron Webb
Godzilla! has a spectacular aura aboutGodzilla! has a spectacular aura about
Smile Re: Attention tipped over robots! Please use the e-stop button.
I guess I would look at the e-stop/robot disabled from a slightly different point of view - If I were a team starting to play defence in the alliance zone with 3 robots and I did not want to get a penalty for having more than 2 operable robots on defence at any given time I would do my best to insure I took an action whereby the Head Ref would not have to ask him/her self "Are they Disabled?" and the answer should have been an immediate YES!
Now, what action could that be?
1. Hope the ref knows that since my robot is not upright it must be
disabled - right?
2. Have my robot catch on fire/emit copious amounts of smoke and shutting down the match (used a couple of times at GLR) thereby avoiding a penalty
or
3. Use the e-stop for my robot (not the alliance member on the right) and give a clear concise signal that my robot is disabled
I would vote for #3 - #3 my lord ( oops sorry have Shrek on my mind).
When taking this action the corresponding light over the team station starts to blink which among other things means that the robot is disabled.
A riskier path to take is for the driver to assume that since the robot is not upright that must mean to the Head Ref that the robot is disabled.
At GLR I saw a robot that was tipped over during auto and was the 3'rd robot when on defence. I gave the alliance a grace period to see if they would disable the robot and luckily for the alliance one of the running robots went to the other side of the field to wait.
I said luckily because I did not know for sure if the robot was really disabled because when offense for this alliance was ran the robot righted itself and continued to play the game. If the team did not send a running robot over to the other side of the field I would have awarded offside points and would have been correct to do so especially when the robot joined in when offence was ran and thru it's actions was clearly NOT disabled.
-Per last nights head ref discussion. If the team playing defence had not sent a running robot over to the other side of the field during defence and given that the "tipped over" was righted whe it was their turn for offfence they could have been awarded a 40 point offside penalty.
Choose wisely grasshopper
Unread 14-03-2006, 14:10
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Yeah I believe that once the E-Stop is pushed down the light over that particular station should flash 2 or 3 times then repeat to let field control the E-Stop is down - Field Control will also see that the E-stop is down via the scoring system which has a special line that shows the E-Stop Status.
Fill free to correct me if I'm wrong, I know the scoring system has that function I just don't remember how many times the light flashes to signal the E-Stop is down.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 14-03-2006, 14:17
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
A VERY safe way to show that you have no control of your robot is to have the entire drive team hold their hands up in the air.
We lost control of our robot in a match (it wasnt hurting anyone, though it shoved another robot into the corner even though we were trying to back off) because it never came out of autonomous. Our drivers didnt think of hitting the estop, but they threw their hands up in the air after trying to back away unsuccessfully, and were NOT called for pinning because they did not have control.
Per update 15 if a robot has NO way to right itself, you do not need a backbot. The intention is that you only have 2 robots running interference, theoretically so that one robot can score at all times.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 14-03-2006, 14:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The light blinks constantly, just like it does before you connect a control system and have communication with your robot. And E-Stops can't be undone. After scoring the 2000 game and constantly running about resetting E-Stops, I'm just a bit familiar with how they work.
Unread 14-03-2006, 14:31
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Originally Posted by sanddrag
As I understand it, if a robot is disabled by means of the e-stop button, the alliance is no longer required to have a backbot. (please correct me if this is untrue) So, for the courtesy to your alliance, if you tip over, please hit the e-stop button. Thank you.
^^ this is not the correct interpretation
Originally Posted by GDC
If three robots are on the field for an alliance at the start of the match, then the alliance must have a backbot during all defensive periods of the game. If one of the alliance robots is disabled during the match, then it is up to the two remaining alliance members to either bocome the backbot, or move the disabled robot into an appropriate position such that it can be the backbot.
Unread 14-03-2006, 14:38
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Yes it is:
Originally Posted by Update 15
ROBOT Off Sides - During the SECOND and THIRD PERIODS the ALLIANCE on
defense can have at most two (2) operable* ROBOTS on the defensive end of the field (the
near end of the field, from the ALLIANCE point of view). If the ALLIANCE has a third
operable ROBOT, that ROBOT (the BACKBOT) must be positioned on the end of the field
farthest from the ALLIANCE STATION.
* Note: a ROBOT will be considered operable unless the robot has fallen over and cannot
be righted, or the ROBOT has been disabled by the field control system, or the team has
pushed the "E-Stop" button to disable the ROBOT. Loss of control due to operator error,
user software errors, or faulty mechanical systems are not sufficient to cause a ROBOT to
be classified as "inoperable."
As stated by the GDC, updates take precedence over what is stated in the Q&A. This is an old answer (02-02-06)to the question and a new answer in update 15 was posted. So disabling your robot during a match is valid for avoiding backbot penalties.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
2006 CMUcam2 Code Kevin Watson Programming 81 10-02-2007 20:17
Tipping and Tipped robots Brandon Holley General Forum 11 18-01-2005 13:06
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
A Real BALANCING Act !? archiver 2001 4 23-06-2002 22:35
