Go to Post FIRST provides evidence that many of us are optimists. - mrnoble [more]
Unread 14-03-2006, 16:43
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
EasyC and the 8.2/8.3 Volt Bug
There has been a lot of discussion about the 8.2/8.3 battery voltage bug (which leads to memory corruption and hardware shutdown) in the 2006 RC. Does anyone know if this is an issue with the EasyC programmed robots? Has the problem been addressed with the current WPLib and EasyC updates? This is the fix that is being suggested right now:
http://www.ifirobotics.com/docs/memory_problem_8722.pdf
Obviously, this isn't doable with EasyC, but if the WPLib has it covered then we should be ok.
Unread 15-03-2006, 08:37
intelitek_Chris intelitek_Chris is offline
intelitek_Chris will become famous soon enoughintelitek_Chris will become famous soon enough
Re: EasyC and the 8.2/8.3 Volt Bug
The latest update of easyC, posted last week (see the forum sticky for downloading information) contains a fix for the 8.2/8.3 Volt Battery Bug. This fix is the last entry contained in the upgrade information text document available on the ftp along with easyC.
The second issue addressed in that PDF regarded programs whose maximum size exceeds 64k. This should not be an issue in easyC and was not extensively tested, as it is exceptionally difficult to create meaningful programs in easyC greater than 45-50k large. This is because the vast majority of the size in any easyC project lies in the code generated by easyC in the background. If anyone has problems with programs of this size (that isn't related to becoming lost and confused with your code!), please let us know.
Unread 15-03-2006, 11:45
AKA: Dan
Thanks for the clarification Chris! Now I only have 876 other things to worry about
Known Bug With mcc18 and Wine 0.9.22 ScottWalls Programming 1 05-11-2006 15:03
Charging the 7.2 Volt Batteries roboticsguy1988 Control System 43 17-01-2006 20:59
What the...? casting bug? gnormhurst Programming 4 22-03-2004 15:49
The 9:43 PM Server Bug sanddrag CD Forum Support 11 12-11-2003 19:13
