Go to Post For some people FRC is an introduction into STEM and just a way to open someones eyes to a world they might not know exist. To other it is a lifestyle that makes crossfit look casual. - IronicDeadBird [more]
Unread 05-03-2006, 18:10
sur2124 sur2124 is offline
FRC #0116
sur2124 is an unknown quantity at this point
calculating distance
My team needs to be able to calculate distance, We first used a shaft encoder, we later learned that the shaft dosn't turn with the wheel. So any ideas?
Unread 05-03-2006, 18:34
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: calculating distance
trial and error . . thats what we did.
(edit)
if your talking about shooting that is.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
abrockhoff abrockhoff is offline
Team 11 Programming Captain
AKA: Alex Brockhoff
FRC #0011 (MORT)
abrockhoff will become famous soon enough
Send a message via AIM to abrockhoff
.. because of your phrasing im not sure if your talking about shooting distance or the distance your robot travels in autonomous mode.
If I'm correct in thinking that your talking about driving distance in autonomous mode, there are quite a few options to find the distance your traveling, the first is encoders, which you say your having trouble with.
You can also try to use timer interrupts, but if your having trboule with that, you can just count program loops. Each loop is 26 milliseconds, so depending on you robots speed you can estimate the loop count you need to travel a certain distance, and then jsut test your autonomous mode to perfect it.
Unread 05-03-2006, 18:59
mgreenley
Posts: n/a
If you are talking about distance driving or distance shooting, and a shaft encoder doesn't do the trick for you, here are some options that my team has explored in the past in similar situations:
1) Try mating the encoder to a different part of your drive train.
On my teams robot, rather than attaching the encoder to the axle that supports the wheel, we used our encoder to count revolutions of a gear in our transmission.
2) Optical encoders.
Because the shaft doesn't turn with the wheel, measuring the shaft, as you pointed out, wouldn't help much. However, you can, for a slightly less accurate measurement, use an optical encoder and some reflective tape.
3) Trial and Error with timers
As noted, possible, but time consuming in the "lets-try-it-out" department. An option not to be discounted, but not what I'd take as my first route.
4) Hall-effect sensors.
FIRST does include hall-effect sensors, which can count gear teeth, but I've heard mixed results about their implementation.
If you are trying to calculate driving distance, you only need the encoder and a known starting position (use a 3-position switch to accommodate for each starting box). Also, keep in mind that in their most simple implementation, these sensors act as courters; they are independent of direction. Hope this helps.
-Mike, Team 341
Unread 05-03-2006, 19:51
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Well, because you didn't state what you wanted to calculate the distance to, I'm going to assume it is the center goal.
If you are using a camera, track the light and use the camera's tilt angle (and a bit of trig) to determine the distance.
i believe the formula was
distanceToTarget = heightOfLight*tan(camTilt);
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 10-03-2006, 12:12
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
If you're talking about distance to the target, you can use the camera tilt angle (not very reliable or accurate), or you can use the camera's reported blob size.
If you take an average of the camera's blob size over several cycles (2-3 seconds of summing), you can get a pixel count that is effectively accurate to about 0.01 pixels. Once you know, for example, that you can see 5.27 pixels from your current position, you can plug that into an empirically derived equation to determine your distance in whatever units you want.
So here's what you can do:
1. Write code that sums up the blob size over the last 100 robot cycles
2. Have the code print out the sum of the last 100 cycles, and record this value
3. Measure the distance your robot is from the target, and record that value next to the value from step 2
4. Write the distance and sum down, and repeat for varying distances
5. Put all these (sum,distance) pairs into excel, and have it generate a matching function for you (our best fit was a polynomial).
Example data:
Pixels	Distance
5.27	8m
5.70	7m
5.95	6m
We ended up collecting five pixel sizes for each distance, and spaced the distances 25cm apart from 8m to 4m.
Once you have this polynomial function, you can use it to take a sum or average of blob sizes and turn it into a measured distance with great accuracy.
The problem with trig is that moving 1 foot when you're 10 feet away doesn't change the angle very much, and as such, you won't get a very accurate distance measurement. We tested this method, and it's accurate to about 10 centimeters. You can also make it variably accurate, depending on how much time you have to measure the blob size. The problem with the blob method is that when you're off to the side, the blob will be artificially smaller without decreasing the distance. However, if you're so off to the side that that is a big issue, you probably won't make the shot anyway.
Unread 10-03-2006, 12:46
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We used a gear tooth sensor on a wheel sprocket. Then divide the circumference of the wheel by the number of teeth to get "inches per count"
Then Easy C made it easy to program.
Unread 14-03-2006, 20:05
FRC #0116
I was talking in general, we needed the shaft encoder to find the distance to a point in autonomus mode. We used the Gyro to find direction, y-accelemoter to find tilt angle, and tried to use the shaft encoder to find distance to a point on the field.
Unread 15-03-2006, 16:31
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
why didn't you use another gyro to find the tilt angle? it makes things a bit easier
anyway, if you want to calculate distance (without using the camera), you might want to use that encoder.
the encoder counts can be extremely useful, (AFAIK) they count more times per revolution then a GTS can, and (once again, AFAIK) they miss less counters then a GTS.
anyway, what you have to do is figure out the amount of counts per revolution, and then how far each revolution makes the robot go. as far as I'm concerned, this is simple math.
once you have figured that out, assign a PWM value and count up to that value. you might have to use a bit of PI or PID to make sure that the robot will STOP at the desired length, but counting the encoder output is definitely a good idea.
If you are trying to discover position, then you would have to take into account the GYRO angle. By doing this (and a bit of trig i think) you can determine the position of the robot on the Field.
RPI 2012
BREAKAWAY
Unread 15-03-2006, 18:05
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
That should be pretty easy then. All you need to do is find out how many encoder ticks you get per revolution of the wheel. With that information, you can convert that to ticks per inch. From there you should be able to determine how many ticks you need to go a certain distance.
Edit: This is similar to what Uberbots posted. Should have read more carefully
Unread 15-03-2006, 18:36
Andrew Blair's Avatar
FRC #0306 (CRT)
As far as saving your encoders- try mounting a small sprocket onto the encoder shaft, and let it run right with the chain.
Be careful though - from what I've heard, encoders don't exactly take kindly to side loads...
-Sir Francis Bacon
-Albert Einstein
get distance from cmucam ModMan24 Programming 14 29-10-2010 17:51
Sharp IR distance sensors Gdeaver Electrical 13 10-02-2007 20:36
Some ways to measure distance during autonomous shamu1001 Programming 2 06-02-2006 15:24
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Long distance... Ashley Christine Chit-Chat 6 27-04-2005 15:11
