Go to Post You can reduce the size of your wench. - ngreen [more]
Unread 14-03-2006, 20:43
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Black & Decker Fisher Price Transmission
Recently while at VCU our team was stuck with a problem.
One of our double stacked BaneBot transmissions bit the dust on practice day and that was when we really put them to the test.
We did not have a replacement and because one transmission was not enough to power our ball pickup and shooter delivery system, we needed to find something if our second one decided to fail. We were forced to eliminate and modify some of our ball conveyors.
So we sent someone from our team to the Lowe's right down the street to find a 12 volt drill.
He came back withTHIS
With a little tinkering and figuring how to get the drill apart, the Fisher Price motor was a direct drop in.
Unlike the Bane Bots, this little gearbox also has an adjustable clutch, a good feature to prevent motor burnout.
I did get this setup nearly ready to be placed on the robot if needed before the end of practice day; however, we have not done any testing to see how this gearbox may handle on a FIRST robot.
If anyone is interested in this gearbox perhaps I may make a white paper on how to tear it down and place the Fisher Price in it.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 14-03-2006, 20:50
JAH's Avatar
JAH JAH is offline
My two weeks notice is in...
AKA: Jason Hoff
FRC #0234 (Cyber Blue)
JAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to behold
Send a message via AIM to JAH
Re: Black & Decker Fisher Price Transmission
That sounds pretty neat. I'd love to see a white paper on how you did it. It really seems that you guys are good at thinking on your feet which is a good quality for any team to have. Assuming that there isn't a ton of power put into it I'd assume it would be ok. Other drill transmissions have been used before, granted they were stronger, but this is a really neat idea and hopefully it will work. Post pictures at some point if possible!
Jason Hoff
Team 234
jhoff@cyberblue234.com
"Red, White, and CyberBlue..."
2006 Arizona Regional Imagery Award Winner
2006 Arizona Regional Entrepreneurship Award Winner
2006 Arizona Regional Website Award Winner
2006 West Michigan Regional Website Award Winner
We've got 2 Woodies, Chris Fultz and Scott Ritchie.
Unread 14-03-2006, 21:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Cool. Let's see some pictures. I wanted to get some $8 drills from Homier to try. By direct drop in, do you mean no change of pinion? If so, that would be incredible.
Unread 14-03-2006, 21:13
AKA: Bradley Rigdon
We had to remove pinions from Black & Decker motor and the Fisher Price motor.
We then had to press the B&D pinion on the Fisher Price and cut some of the shaft just as you would do to make them fit the Bane Bots.
Unread 14-03-2006, 21:15
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
What sort of weight are we looking at for one of these?
What is the reduction?
More pics?
I'd love a whitepaper.
www.metalmoose.com
Unread 15-03-2006, 07:26
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
I would also like to see a white paper. Does it have variable speeds?
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 15-03-2006, 08:14
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
What about Harbor Frieght Drills? You can get various different voltage models (most are very cheap) and use the transmissions off of them. I think a 12v model is around $10 and you can get 18v ones too. Seems like the Johnson motor from the FP would adapt well to the drill gearbox.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 15-03-2006, 08:55
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Any idea on the gear ratio?
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 15-03-2006, 10:15
AKA: Bradley Rigdon
I do not have the gear ratio at this time, I am working on that.
I do know that the output of the drill with the stock motor is between 0-700RPM, but that does not mean a thing unless the stock motor and the FP motor RPM's are nearly the same.
This is only a one speed transmission with a 24 position clutch.
Perhaps a Harbor Freight drill would work the same but we didn't have one around.
I am not sure on the weight, but it is a bit more than the Bane Bots.
I would say between 1 - 2 pounds.
Unread 15-03-2006, 11:37
Andy A. Andy A. is offline
Getting old
FRC #0095
An instructor of mine worked at Black & Decker for several years developing assorted electronic 'tools' for the home and nonprofessionals (things like that drill would have been up his ally). From what he's told the class, black and decker pretty much takes the same motor/gearbox assembly and just crams it into what ever clamshell they need at the time. So I suspect this gearset lives in many products under the same brand.
I'll talk to him about this and see if he can find any 'real' information about this or other B&D transmissions. It may be possible to order the gearbox directly, or find the least expensive device it comes in. Maybe even find multiple ratios ala BaneBots.
As an aside, I like the XRP tranmission conversions. DeWalt being owned by B&D, could some of the B&D trannys from the 'firestorm' line be an alternative to the cronicly out of stock XRP? It seems all the firestorm sets are only 2 speed, so I don't see getting the exact same model happening. I've only done a very casual search for transmissions alone, and have not come up with anything.
I guess I'll grill my instructor and see if he has any info or can put me in contact with someone who does still at B&D.
-Andy A.
Unread 18-03-2006, 00:08
AKA: Bradley Rigdon
Tonight I investigated the gear ratios.
I do not know how to calculate planetary gear ratios, so here are the #'s
The sun gear attached to the motor is a 9 tooth which meshes with 3 16 tooth planet gears and they mesh with a 42 tooth stationary ring gear.
These gearboxes have 2 stages the first set of planet gears is plastic, while the second set is metal along with the whole ring gear assembly.
The second stage is basically a repeat of the first stage with the sun gear attached to the planet carrier and in the last stage the planet carrier is the output.
Can anyone tell me how to calculate the gear ratio for this?
Last edited by team222badbrad : 18-03-2006 at 00:43. Reason: In our english language we have two words no and know, both pronounced the same but 2 very different meanings :-(
Unread 18-03-2006, 00:27
teamtestbot's Avatar
teamtestbot teamtestbot is offline
Prophet of ROFLCOPTER
AKA: charles
FRC #1771 (NGHS Robotics)
teamtestbot is a jewel in the roughteamtestbot is a jewel in the roughteamtestbot is a jewel in the roughteamtestbot is a jewel in the rough
Send a message via AIM to teamtestbot
Hey,
Most lower end and "common" drill gearboxes are 36:1, 9 tooth pinion, 18 tooth planets, and 45 tooth rings. This is the case with drills from Harbor Freight, Homier, and lower voltage Black & Decker and Ryobi. The reduction is (1 + R/P), so two stages of 6:1.
Those drill parts tend to be interchangeable, e.g. a B&D 9.6v will fit on the back of a Harbor Freight transmission.
Heat Sinks for Fisher Price sanddrag Motors 10 08-02-2005 09:33
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Fisher Price used on Arm? eddwahd Motors 24 03-02-2005 08:39
Need Fisher Price Motors kevinw Motors 1 13-02-2003 18:44
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
