Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
  #76   Spotlight this post!
Unread 12-03-2006, 15:35
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Re: Rules that are [not] getting called at Regionals, the +s and -s
Originally Posted by Kit Gerhart
In the case we experienced, we were rammed by a fast robot which was pre-aimed to intersect the path we normally took to shoot balls at the high goal. The collision bent our 1/4 inch aluminum side panel.
Our match in question was an early match on Friday, and hearing George 1902's experience, things were called differently later during the UCF event.
I cannot speak for the other referees, but I was personally repremanding teams that I saw had a repetative nature of running cross-field and slamming into whatever was there. Each team that I talked to changed their programming to let up at the last second to allow for another robot being there.
Originally Posted by Gary Dillard
Neha is being very kind in her post, by speaking in generalities - her team was on the receiving end of what I felt was an obvious violation of the tipping rule during elimination matches. Another team with a long, high blocking "wing" that extended outside the base footprint came alongside them, turned around and used the force of their wing against the top of 1345's robot to tip them over. Intentional or not it happened right in front of the head ref who immediately signaled that there was no foul. If that's not a tipping violation I don't know what is.
The robot you are referring to was warned for this action and was watched for further violations of the tipping rule. I didn't see the original tip, so I cannot comment further on this.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
  #77   Spotlight this post!
Unread 12-03-2006, 16:26
Generator of Entropy
FRC #2973 (The Mad Rockers)
I'm not aware if you spoke to our team or not Dan, but here's what we did and why:
We were intentionally trying to knock the autonomous 3 pt shooters off target, before they started shooting. This required us to notice/guess where they were going to be and when they would be there. We also had to account for their alliance partner coming between us to block us or knock us off course. What we knew was our speed in each gear - we didn't have shaft encoders or a yaw rate sensor hooked up (yet) so we had to program a distance based on time. As you can imagine that's a pretty big window to account for all of the unknowns. To expect programming to "let up" is rather optimistic - if you're already travelling at 12 fps, letting off the gas isn't going to slow down a 145 pound robot much as far as impact momentum. We've got plenty of power to push other robots around, but we needed the speed to compensate for all the stuff that the robot can't sense in autonomous.
But we did set a limit; our concern was if we missed their robot and ran full bore into the field railing that we would topple over out of bounds. Again, in the finals the robot we were trying to knock off target remained in the starting box so that gave us a better window for aim but not much for distance, especially if their alliance partner tried to block us.
Team 86 (Resistance) had an excellent autonomous in that they changed their shooting position on the field so we couldn't predict where to aim.
I don't see how you can call any robot with regulation bumpers for ramming - as Ken said it's only a couple g's and certainly can't fit the intent of the rule which is to penalize intentional damage, not defense.
  #78   Spotlight this post!
Unread 12-03-2006, 16:44
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Originally Posted by Jack Jones
I'm sorry to hear you lost a match. But not as sorry as I am the hear that one official put themselves above another. Please say it wasn't so! I hope your team mate (sic) was mistaken. Officials have no business apologizing for another's call.
Ok, orinigally I was just going to PM Dan, but I feel I should clear this up.
I was both the ref who made the call and the ref who "apologized". However, I was not apologizing for making the call nor was I saying it was a bad call. I was merely saying that they did a good job, congrats on chairmans, etc, and that I wished I didnt have to make the call in the first place as I know what it's like to loose a match off a penalty and the ref's arent there to ruin people's fun.
Regardless, I stand by the call I made. It was discussed after the match with fellow refs and those that saw it agreed with the ruling. It was not the first time we penalized a team for such an action, nor was it the last.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
  #79   Spotlight this post!
Unread 12-03-2006, 17:07
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
I had an issue with the same robot and the 60" max height rule. This wing was statically within the rules but when used for blocking it would continually deflect several inches higher - it was made of PVC and contact with the other robot would bend it up. I must say, however, that this is an excellent feature and very effective so a simple modification could prevent violation of the 60" rule.
So alot of people are probably wondering about this...I talked with ref's aobut the wings and asked the extent of this rule, they said that if we had them up and someone ran into us and they went outside the 60" cube it was ok, but if we drove into someone with them up and then this happened then we would be penalized.
As to tipping 1345, I was pretty sure we were going to be dq'd after that I don't know why it wasn't a penalty.
Penn Class 08
  #80   Spotlight this post!
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Originally Posted by Brindza
Well I just got back from the Pittsburg Regional...and well I was a little dissapointed to say the least.
I don't know how the other regionals were called, but at Pittsburg the pinning rule (G24 i believe) was COMPLETELY disregarded. If this was the case at the other regionals i would like to know before we go the the Annapolis Regional.
Team 888
I would be interested to know the specific circumstances as many people do not know/understand the pinning rule (which has changed this year from previous years).
Directly from <G24> (emphasis added):
Pinning - While on the carpeted field surface, a ROBOT cannot pin (inhibit the movement of another ROBOT while in contact with a field element or border) for more than 10 seconds. This rule does not apply if either ROBOT is entirely on an ALLIANCE PLATFORM...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
  #81   Spotlight this post!
Unread 12-03-2006, 18:02
Brindza's Avatar
Brindza Brindza is offline
AKA: Jordan
FRC #0888 (Robotiators)
Team Role: Operator
Brindza is a jewel in the roughBrindza is a jewel in the roughBrindza is a jewel in the roughBrindza is a jewel in the rough
Send a message via AIM to Brindza
I will post the video tommarow when I go to school. I feel like that is the best way to show it. Explaining wouldn't cut it. but our robot was on the carpet when it happened and the explaination the ref gave me was that since I was pinned against a field element and not a barrier the penalty did not apply.
Which is clearly wrong, although I did not think of asking for a rulebook since I figured the head ref would know the rule better than me, so it may be my fault for not demanding that the rulebook be reviewed.
  #82   Spotlight this post!
Unread 12-03-2006, 18:08
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
I wish that more people had this opinion
Originally Posted by DjAlamose
Hopefully I don’t blow up in this conversation...
There is a HUGE difference between ramming and defending. When ramming you are using excessive force to move something. You are unleashing a greater amount of energy in a single instant than pushing. This can be harmful to robots. That is why bumpers are helpful, they cushion the impact. But it is still not within the spirit of the game to harm a robot, bumpers or not. I am fine with robots pushing robots around. But any contact between two robots that are going more than 2 ft a second, in my book is ramming.
Instance A: Bluebot A charges across the field only to slam into Redbot C who is shooting into the goal. Obvious ramming.
Instance B: Bluebot A is near Redbot C and pushes on Redbot C moving out of aim with the center goal. No ramming (given that the robot moved to Redbot C without going over 2 Ft/sec)
Instance C: Bluebot A charges accorss the field only to slow down right before it reaches Redbot C. No ramming.
Instance D: Bluebot A repeatedly backs up and moves to push Redbot C. No matter what speed Bluebot is traveling it should be considered ramming because the robot backed up and moved back in to "push".
I saw many times through the VCU feed of instance D. Even if the robot only backs up once and moves in again it is not within the rules. (I can't quote a rule right now but i will work on getting it).
Let’s take it out of context of robots and move it to cars. If a car gets into an accident most likely it’s because of a ramming action. But if a car was to push another car (say a car was broke down and another car was helping it along) then there would be no damage to the car being pushed (or very little).
What I think needs to be defined by FIRST is ramming. It is a very open term that can be interpreted by many people in many different ways. I have just given my interpretations of what ramming is.
it should also apply during autonomous too
  #83   Spotlight this post!
Unread 12-03-2006, 21:16
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
On a few occasions at Arizona we were "rammed" pretty hard. I do not know if anything was said or done to the offenders. When my kids asked me if they could do the same, I said no...GP comes first. Maybe I am old fashion, but "it is not about the robots."
Ken
Ken Loyd
Teacher/Advisor
Team #39
Highland High School
  #84   Spotlight this post!
Unread 12-03-2006, 22:30
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Originally Posted by Richard
I saw what struck me as a very interesting (!?) call by our head ref at STL yesterday. I didn't observe the play itself, but did see the position of the robots just afterward. Bluabot had pushed Redabot so that Redabot extended more than three inches into a corner goal. Redabot was DQ'd for the incursion and Bluabot was DQ'd also. One ref thought that Bluabot's DQ was called for ramming, while another thought it was called for intentionally causing the incursion. Since it occurred in the elimination rounds, the result of this double-DQ was a replay.
Can someone who was directly involved please offer clarification, or correction if I got the story wrong?
Wasn't there, nor involved, but it's been posted and in Q/A (and maybe update?) that regardless how you get in the goal past 3in, you will be DQ'd... so if a robot gets pushed into the goal that far, they can be DQ'd.
http://forums.usfirst.org/showthread...=1811#post1811
I suppose the
I believe update 15 addresses this as well.
The pushing robot risks penalty from ramming or safety, as I'm not sure what the point of pushing a robot at the corner goal would be.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
  #85   Spotlight this post!
Unread 12-03-2006, 22:37
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Originally Posted by Steve W
It seems that they were very liberal on all of these rules. I measured one bumper that started 6 1/2" from the floor. There was another that cleared the bumpers on the other bots. I hope that this is standard throughout all regionals. If not then there will be a lot of upset teams that attend second regionals.
Were they inside the robot dimensiosn? Because if so, they are completley legal. If not well then they aren't.
Also, yes balls being behind the human player was useful, to mea s human player because then i didn't have to worry about stepping over the line as i would hit the holder first.
VEX Robotics Blog
  #86   Spotlight this post!
Unread 12-03-2006, 22:42
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I suppose the
I saw the earlier thread, and expected that the incursion DQ would be called as it was on Redabot. The earlier thread doesn't anticipate Bluabot also being DQ'd -- that's why I asked for clarification (or correction) of what actually happened from someone who was directly involved.
A referee who was on the scene and witnessed the play commented that he hoped this double-DQ call would not occur frequently, since it seems to be a method for a team that is hopelessly behind in an elimination match to force a tie and (in effect) get a replay.
Richard Wallace
since 2003
  #87   Spotlight this post!
Unread 14-03-2006, 22:05
atomikitten's Avatar
atomikitten atomikitten is offline
blowing things up, making things go
AKA: Megan
FRC #0888 (Robotiators (Glenelg Gladiators))
atomikitten will become famous soon enough
Send a message via AIM to atomikitten
disclaimer: neutralize the acidity (even though I've already posted this elsewhere)
Sorry, I know this is redundant, but I feel it's very important to reiterate.
Hey now... one catchy soundbyte echoes in my head: "life's not fair, and neither is FIRST." I'm saying this even though it was my team that suffered because of some other people's errors. We're going to put up with a lot of crap from a lot of idiots in the real world; frankly, I'm just greatful to have experienced FIRST, where idiots and crap are at a minimum.
Having cleared that up, I can say confidently that team 888 had an overall pleasant, positive experience at the Pittsburgh Regional, despite the frustrations. To any individuals who made our acquaintances, please understand the team's frustration and try to look at it from our point of view--you were there too. The situation simply outraged us. This does not excuse our team's rants, but perhaps the rest of the FIRST world could borrow a little bit of perspective.
To tell you the truth, on Thursday, we felt that a few other teams were absurdly aggressive towards us, both in and outside of the arena. We were even subjected to repeated "speed screenings" because "other teams reported" that our shooter violated a velocity regulation. After three intermittent screenings, absolutely no breach of regulation was found. We were suspicious and a bit insulted, but we beared it.
I feel it's also important to acknowledge that there were individuals who were notably courteous and pure-intentionedly helpful to us as well. They made gestures that were more typical of FIRSTers.
most importantly:
I'm ready to put all of this behind me so that I am completely unburdened to look forward to the Chesapeake Regional. I can only ask and hope that everyone else feels similarly. After all, each day is fresh with no mistakes in it [yet].
  #88   Spotlight this post!
Unread 15-03-2006, 13:38
sw293 sw293 is offline
Former Coach (2005)
AKA: Scott Weingart
FRC #0293 (SPIKE)
sw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of light
Robot Interaction Rules
The key to understanding this year's Robot Interaction rule <G22> is to look at last year's rule, <G25> and compare.
The first difference is in the title. <G25> last year had none. This year's reads, "Intentional Robot - Robot Interaction." This makes is more clear that unintentional interaction is generally not governed by G25.
The first two sentences start off the same the same: "Strategies aimed solely at the destruction, damage, tipping over, or entanglement of ROBOTS are not in the spirit of FIRST Robotics Competition and are not allowed. However Triple Play/Aim High is a highly interactive [contact] game" (2005-G25 includes the word "contact", 2006-G22 does not)
Here, the rules diverge crucially in setting the standards for legitamite and illegitamite interaction. First, 2005-G25:
Some tipping, entanglement, and damage may occur as a part of normal game play. If the tipping, entanglement, or damage occurs where it is not a part of normal game play, at the referee’s discretion, a 10-point penalty will be assessed, and the offending team/ROBOT may be disqualified from that match.
The standard here is "where it is not part of normal game play, at the referee's discretion". This can be very broadly interpreted, and in some regionals last year, it was. In an attempt to clarify the rules and establish some consistency, FIRST offered examples of normal/inappropriate robot interaction.
On the other hand, 2006-G22 reads "Some appropriate contact is allowed subject to the following guidelines:", followed by a list of guidelines, followed by: "In all cases involving robot-to-robot contact, the Head Referee may assess a 5-point penalty and the robot may be disqualified, subject to these guidelines." The standard for allowed robot interaction is specifically laid out here in a set of guidelines. It does not depend on a referee's opinion of "normal game play".
The guidelines themselves specifically set a great deal of robot interaction inside the realm of allowed play. Contact within bumper zones and extension-extension contact "will generally not be penalized", and incidental contact "will not be penalized." Notably, FIRST makes it clear twice that tipping over a tilted robot is usually considered incidental contact: "Contact outside the BUMPER ZONE that is a result of tipping caused by contact within the BUMPER ZONE will be considered incidental contact. ... Contact with a tilted robot such that the contact is outside the bumper zone will generally be
considered incidental contact." As for ramming, "high speed ramming" in 2005 has become "long-distance high speed ramming" in 2006.
It is arguable that the <G25>-to-<G22> changes were made to avoid the controversial robot-robot interaction calls that occured in several regionals last year. It is not arguable that this year's rules governing robot-robot interaction are far clearer and easier to interpret, and the standard they set for improper interaction is much higher than the standard applied by many regional referees last year. Read them throroughly and realize that they do not read the same as last year's rules.
Team 293
Uncrowned Champions, 2005 Philadelphia Regional
Champions, 2007 Chesapeake Regional
AZ Regionals: Incorrect Scoring? ArmoredFairy698 Regional Competitions 68 21-04-2005 21:34
Should teams be allowed to attend multiple regionals? AJunx General Forum 56 12-04-2005 14:13
Chief Delphi went to three regionals? FIRSTfan General Forum 12 08-04-2002 11:07
Robot electrical systems rules Morgan Jones Rules/Strategy 5 06-01-2002 00:50
