Go to Post FIRST: Making women's hair grow, and mens hair fall out. - Ashley Christine [more]
Unread 14-03-2006, 22:48
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Allen Bradley Photo Sensors
well with the LED on at least you know it has power (12v right?). Maybe there's a short somewhere? Our robot is still in the crate so I'm trying to remember...The receiver has 4 insulated wires, 1 for ground, 1 for +12 and the other two for signal. When you strip down the outer cable insulation there is also foil and a bare wire right? Make sure none of that is shorting. I would think that with the LED always on the sensitivity is set too high. Or check the lenses and make sure they aren't blocked or smudged or something...clean em off.
Good luck!
EDIT: Oh BTW the adjustment for the emitter changes the IR beam intensity. But since your receiver is showing an LED even without the transmitter, focus on that problem first.
Sharp IR distance sensors Gdeaver Electrical 13 10-02-2007 20:36
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
jumper cabling from sensors to controller Gary Dillard Electrical 4 23-12-2005 07:42
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
