Go to Post While we all look back and appreciate the shoulders of the giants of the past upon which we are standing, let us not forget that we are the giants of today. Ours are the shoulders on which others will be standing in the future. - Mike Rush [more]
Unread 15-03-2006, 20:23
Billfred's Avatar
Billfred Billfred is offline
2005 Electricals or 2006?
Did your team use the 2006 electrical setup from the kit, or did you order the 2005 breaker panel from IFI?
Why?
Unread 15-03-2006, 20:39
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: 2005 Electricals or 2006?
Why?
2005 - best US$ 84.95 spent this season, in my opinion.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 15-03-2006, 20:43
The Lucas's Avatar
CaMOElot, it is a silly place
2005 breaker panel for weight
Maxi blocks weigh a ton
Robot Inspector
Unread 15-03-2006, 20:44
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
2005 set-up for sure. Makes everything neater, lighter, and more reliable in my opinion.
The weight of that maxi fuse block makes me cringe.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 15-03-2006, 20:48
UngsFree's Avatar
UngsFree UngsFree is offline
"Bad Bow Tie"
AKA: Mike Unger
FRC #0272 (Cyber Crusaders; #1930 Comets)
UngsFree is on a distinguished road
Send a message via AIM to UngsFree
We also used the 2005 Setup, less weight and it makes everything much cleaner in my opinion.
Rochester Institute Technology, Class of 2011
Mechanical Engineering Technology
Delta Force 1930 Mentor
Unread 15-03-2006, 20:50
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Looks like 5 for 5, we used last years panel too. It's so much easier to wire up, and you can hook 6 40amp loads to it, not to say anything of the weight of the gold maxi holder.
-Chris
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
Unread 15-03-2006, 20:54
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
2005, for weight and layout efficiency.
Also, as an inspector I prefer 2005 because it makes wiring easier to trace.
Can anyone offer some reason(s) for using the 2006 components, other than the extra cost of purchasing the 2005 breaker panel?
Richard Wallace
since 2003
Unread 15-03-2006, 21:12
The Lucas's Avatar
Board space and perhaps a separate drive electrical panel. Thats all I can think of.
Robot Inspector
Unread 15-03-2006, 21:17
Andrew Blair's Avatar
FRC #0306 (CRT)
Make that 7 for 7. Makes it so much easier and neater. Separate blocks inhale audibly
-Sir Francis Bacon
-Albert Einstein
Unread 15-03-2006, 21:43
2005 because it is what I would have designed if I were doing it. The electrical runs are straightforward, minimum loss, with monitoring and good electrical input posts. The high current positions are near the input terminal. I also like the fact that ground returns are numbered to match the fuse (output) positions and there are more positions than the smaller blocks. The Maxi blocks require some fudging to get a reliable contact on #6 (folding stranded wire is not a good way to fill the hole) although the distro block is an easy way for inexperienced electrical teams to get a good return connection.
Unread 15-03-2006, 22:19
Board space is why we used the 2006. It turns out we lost a mechanism and we had more space then we planned, but in any case, that huge breaker panel is really hard to work around.
Unread 15-03-2006, 22:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Large one (2005). Space, 6 40 amp circuits, weight, ease of use.
Unread 15-03-2006, 23:23
AKA: Dr. Brooks
no team (WRRF)
We used the 2005 panel, although having that ground stud on
board to use as a lift point for the robot might have been nice...
Eugene
Unread 16-03-2006, 16:27
in between teams
AKA: Luke Van Oort
2005. I fought tooth and claw for it since the beginning of the season. Other team members were against it saying something about filipping it around in competition being hard.(I never did figure out what they meant) It's a good thing I "convinced" them that it was the better choice, we had to eliminate 15lbs (stupid bathroom scales in our shop said we were 10 under... next time I see them I'm going to bust out the bloody sledgehammer) at competition as it was, I'd hate to have to remove another one or two.
Team 1219: 2009 - Mentor
Unread 16-03-2006, 16:34
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
2005, of course.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
2006 code on 2005 RC? RedBarons Programming 1 04-03-2006 14:29
2006 Camera identical to 2005? de_ Programming 6 23-01-2006 03:28
CMUCam2 - 2005 vs 2006 changes kmcclary Programming 1 09-01-2006 17:24
2005 - 2006 NASA FIRST Robotics Sponsorships KathieK Fundraising 2 27-11-2005 11:04
