Go to Post "Oblivious" people asking questions are what gives us an excuse to sit around on CD. - Ryan M. [more]
Unread 16-03-2006, 11:09
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
autonomus rules....
Can the robot read from the OI during autonomus? That is, can i have switches on the OI to dictate what autonomus i want to use?
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 16-03-2006, 11:13
Re: autonomus rules....
When the autonomous flag is set you cannot see the OI control settings. They appear to be neutral for the pots and off for the switches.
Just read and save the OI settings whenever the autonomous flag is not set. After it's set use your saved OI values.
Unread 16-03-2006, 11:33
Validius's Avatar
AKA: Mark Ratering
Originally Posted by Mark McLeod
After the autonomous flag is set you cannot see the OI control settings.
So in the few moments between turning the robot on and autonomus when disable is set the bot can read those paramaters?
-Peggy Noonan
Unread 16-03-2006, 11:38
Yes, the OI values come through fine while only the Disabled flag is set.
Unread 16-03-2006, 11:39
Validius's Avatar
AKA: Mark Ratering
Beautiful, thank you.
-Peggy Noonan
Unread 16-03-2006, 15:47
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
If you want to switch between autonomous modes you should use the Digital Inputs on the RC. Just wire a switch to each Digital Input for each autonmous mode you need, between the signal and the ground.
Just the way I would do it.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 16-03-2006, 16:46
Andrew Blair's Avatar
FRC #0306 (CRT)
What works very nicely is to use a pot on the OI, saving it's vale into a variable to set you auto-mode. Lets you change the auto from the player station, and is so much more convenient.
-Sir Francis Bacon
-Albert Einstein
Unread 16-03-2006, 19:48
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
I guess I'm a fan of the only system that hasn't been mentioned yet: analog controls on the RC.
Unread 16-03-2006, 20:04
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
And I'm a fan of just reprogramming it
Unread 16-03-2006, 22:57
The Lucas's Avatar
CaMOElot, it is a silly place
We use two 6-position rotary switches on OI. They are nicer than pots because they have definite positions, but they require a bit of soldering to attach the resistors. Digital inputs on the OI are so precious, I hate to waste 5 of them on Auto switches.
Robot Inspector
Unread 16-03-2006, 23:47
AKA: Eric
Digital inputs are indeed precious. We have basically have what you described on the robot itself: 2 10-position rotary switches, each of which involve soldering the 10 resistors together in close quarters.
Last year, my team used a bank of dip switches that went to digital inputs, plus one three-position switch wired to an analog input, which we used to denote the starting position.
Unread 30-03-2006, 23:32
Longhornchris04 Longhornchris04 is offline
AKA: Chris
FRC #1759 (STARS)
Longhornchris04 is an unknown quantity at this point
Well, our robot was very simple this year (rookie year, we followed the KISS philosophy), so we had the digital inputs to spare, but for next year I'm suggesting the following.
On the OI, have a couple of fixed position analog or digital inputs used to select the autonomous mode and a "Lock Autonomous Mode Switch." After the robot is powered, have the robot placement team signal the OI team to "Lock" the autonomous selection. One note on this is the "Lock Switch" will probably need an LED and an "Arming Cover" The OI has 16 analog and 16 digital inputs, so this shouldn't be a problem. This would require 1 digital (lock switch) and 2+ analog (start position and drive pattern??) inputs.
If we go this way though we will test the heck out of it using a competition port dongle and have a startup checklist... which reminds me. There are 2 kinds of people: Those with checklists, and those that will soon have checklists.
Unread 01-04-2006, 10:23
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Our programmers got really tired of having to upload a new program into the robot in between matches, so they came up with this. I think we have around 99 autonomous modes now, which we can switch between right before the match, while the robot is on the field. It helped us out a lot during the finals at Chesapeake. What do you guys think?
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 01-04-2006, 10:29
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
That's a really nice product!
I made something similar this year for our robot, but it's not as neat and compact as that one is. I used short lengths of wire between the connectors and the dip switch. We used it with fair success at Chesapeake as well, I think we had about 5 different auto modes, hopefully we'll get some more programmed before nats!
-Chris
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
Unread 02-04-2006, 22:49
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
we also used a bank of dip switches and came up with at least ten autonomous modes for them. the all the modes and positions were labled in binary.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
On Rules, Referees, and Rewards (aka Penalties) RyanMcE General Forum 29 21-03-2005 13:20
You write the forum rules Ken Leung CD Forum Support 8 17-01-2005 11:18
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
Time for new rules! archiver 2001 11 24-06-2002 02:01
