Go to Post And while I am not that big on hero-worship, I am pretty darn proud to know Dave. However, this does not mean that I will stop picking on him - MissInformation [more]
Unread 18-03-2006, 07:46
Loki1989's Avatar
Loki1989 Loki1989 is offline
AKA: Mike Parker
FRC #5338 (RoboLoCo)
Loki1989 will become famous soon enough
help on easyC
does easy c automatically vary the speed for the amount that you move the controller.
please answer this if you can.
2017 - FRC 5338 RoboLoCo - Mentor
2005-2013 - Team 1544 - One Byte Short
Unread 18-03-2006, 11:01
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: help on easyC
Loki1989, I dont entirely understand the question; could you elaborate a little bit?
Are you wondering about joystick input to the speed controllers?
I cant quite tell from the question. I'll be happy to help you out if you explain a bit more!
www.metalmoose.com
Unread 18-03-2006, 21:53
Loki1989's Avatar
AKA: Mike Parker
Re: help on easyC
because of our C++ we have a different speed for our robot depending on our controller values
im wondering if easyC will do this.
Unread 18-03-2006, 22:57
Jack-Of-All-Trades
Re: help on easyC
If I understand the question correctly, you are asking if easyC automatically relays the joystick values to the speed controllers to the motors; i.e. does easyC automaticall map joystick output to pwms. The answer to that is no; it is, however, very simple. You create an infinite while loop in the operator control section [while(true)], and then within that loop you put the code that maps your style of drive to the motors. easyC has "drag and drop" functions that allow you to drag, for instance "4 wheel tank drive" into the code window, and then use a GUI to assign axes and pwm outputs- very user friendly, very easy.
I'll be happy to help you out with any other questions you've got, and I hope I understood the current question correctly; just a tip, but the more detail you provide, and the more precise the language you use, the easier and more accurately one can answer your question!
-Dillon Compton
team 1394
www.metalmoose.com
Unread 19-03-2006, 08:34
Loki1989's Avatar
AKA: Mike Parker
Re: help on easyC
ok that tells me what i wanted but now i dont understand putting in a while loop because what exactically does a while loop do
Unread 19-03-2006, 08:42
AKA: Brad
#0190 ( Gompei and the Herd)
Re: help on easyC
Those blocks on the palette like "Tank 2 motor", etc. only read the joystick values and send the output to the PWMs once. Generally in your operator control program you have to do that repeatedly until the match is over. That's why you have to enclose those blocks inside of a while loop.
Brad Miller
Robotics Resource Center
EasyC Wish List dcbrown Programming 32 14-08-2006 09:24
EasyC autonomous modes TubaMorg Programming 25 12-04-2006 22:53
EasyC v2.0 is mandatory for FVC! skimoose FIRST Tech Challenge 7 14-01-2006 18:37
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
