Go to Post Andy Baker doesn't go to IRI. IRI comes to Andy Baker. - tim_reiher [more]
Unread 19-03-2006, 15:22
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
How To Test Autonomous
You could copy and paste from user_routines_fast to user_routines. However, the loops run at different frequencies so teams using counters will get different results.
Here's what you should really do:
Get an electrically inclined person to read this post or you could probably do it, it isnt too complicated.
Have them build you a nice competition port tester and all it will take to run the autonomous in user_routines_fast is to reset your robot and flip a switch. Plus, you'll have another switch to disable your robot when it starts knocking over your toolbox in the pit (that of course would be the fault of a mechanical engineer, <wink> )
This will be a tremendous help for those teams trying to develope autonomous codes with a rapid schedule that only gives you 5 minutes of testing before your next match.
Please email me at colehasson@gmail.com for more information or to ask questions.
cout<<"Good luck";
System.out.println("-Cole");
(out (- Team 888))
Unread 19-03-2006, 15:32
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: How To Test Autonomous
Or you could buy a nice one from andymark.. http://andymark.biz/mode-switch.htm
Make sure you don't just wire up auto, you will need disable too. Just believe me on this one.. you want a nice easy to use disable switch.
Unread 19-03-2006, 15:53
coldabert's Avatar
The Dude
The link had the disable switch too. I'm sure AndyMark's would work well, but teams on a tighter budget, you can the parts from Jameco for under 2 dollars rather than $36 from AndyMark (although the AM one does look nice).
Unread 19-03-2006, 17:11
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
Both loops should run at the same frequency (every 26.2 ms or ~38 hertz) so that should work. Though it is still better to be able to switch modes from the OI.
Behold the power of SPAM.
Unread 19-03-2006, 20:10
coldabert's Avatar
The Dude
The loops will run differently due to additional processing and functions.
Unread 20-03-2006, 21:56
Umm Errr...
Pshh who needs these things. At our regional, we lost our auton dongle at the bottom of a box. We didn't find it until we were packing things up to go home. A paperclip between pins 5&8 of the competition port works just fine. You need disable? Simple. just pull the tether out.
1139 Alumni
Unread 20-03-2006, 22:13
Neo3One3 Neo3One3 is offline
AKA: Nick
FRC #0175 (Buzz)
Team Role: Driver
Neo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to all
I know one of our electrical mentors made a smaller one this year, rather than the monsterously huge one we had last year. If anyone wants info on how to make one with an Autonomous mode switcher and a Disable switch, I'd be glad to ask him.
Go Buzz!
Unread 20-03-2006, 22:58
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
yeah 1745 uses a single 2" cat 5 wire to short out the auto pins . . and to disable we pull out the teather . . no need to spend any money on something that you just use to test
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 21-03-2006, 09:03
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
That is why I strongly recommend all teams build the Auto and Disable switches into the regular switch box. At least fasten them to the board holding the operator controls. Before we started doing this I was always looking for the separate one. I seem to remember finding it left at operator stations, toolboxes, back at the school, and at least once in the bag with Shop Rags.
Unread 21-03-2006, 09:12
we built one with a 6 foot cable in a box that is separate from the OI.
That way you can have one person hold the disable box, so they can hit the kill switch when needed, instead of the driver.
The driver always thinks they 'have it', until they run someone over.
Much easier to have a second person on the kill switch, who knows, when the robot crosses this line, shut her down!
Unread 21-03-2006, 09:34
Yep, I can see the advantage of a remote kill switch. I think we'll add that. I will fasten that cable to the box so it doesn't get lost and still keep the switch at the operator's controls.
Unread 21-03-2006, 09:39
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
we built one with a 6 foot cable in box that is separate from the OI.
Oh so true! Our driver would keep going no matter what, until the robot is a smoldering heap of rubble, unless someone else was around to disable it. Then we all have to ask: "Were you the one making the robot spin around and bounce off the walls?" "Uh no, but I almost had it stopped!"
Unread 21-03-2006, 09:54
Electrical Engineer
Rookie Year: 1995
...You need disable? Simple. just pull the tether out.
Not a viable option... If you pull the tether and your robot is still powered, your robot radio link is now "live" and could interfere with robots on the field.
Mike
Mike Betts
As easy as 355/113...
Unread 21-03-2006, 10:15
Umm Errr...
Mike
Not if its not plugged in on either end.
1139 Alumni
Unread 21-03-2006, 10:18
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Our auto dongle has a kill switch of a different flavor.
The kill button has to be held down for auto to work. Let go and it is disabled.
Why?
Because people tend to walk away from the disable switch. If someone HAS to hold it, they can't walk away. Forces... absolutly forces... the use of a safety officer.
Brian Graham
Week 1: Thoughts, comments Joe Johnson General Forum 65 08-03-2006 19:56
How do you test AUtonomous Doug G Programming 6 21-02-2005 13:23
How do you turn on the Autonomous mode (to test)? Salik Syed Programming 6 03-03-2004 23:37
test autonomous mode CharlieWilken Programming 14 20-02-2004 00:39
