Go to Post FIRST teams are made of people - students and mentors. In my humble opinion, it doesn't make one iota of difference if the name of the sponsoring organization or the name of the school changes over time. - dlavery [more]
View Poll Results: What 40A guage
12AWG 8 24.24%
10AWG 25 75.76%
larger than 10AWG 0 0%
Voters: 33. You may not vote on this poll
Unread 15-03-2006, 20:12
in between teams
AKA: Luke Van Oort
Which did you use?
Did you wire your 40A loads with 12AWG or 10 this year? We did 10 because the 12 isn't rated for a constant 40A. (All our wiring, including 20A loads, ended up as 10 because I forgot to bring smaller guages home when I wired the board)
Team 1219: 2009 - Mentor
Unread 15-03-2006, 20:53
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Re: Which did you use?
I used 10 awg mainly because we didn't have any 12 guage. I used 16 for the 20amp loads, so much easier to work with! I used 10 for everything last year, couldn't find any smaller wire.
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
Unread 15-03-2006, 21:20
Andrew Blair's Avatar
FRC #0306 (CRT)
10 gauge gives you some performance niceties when dealling with constant load. We used 12 on some stuff last year, and I didn't see a problem with it, but 10 makes me feel better.
-Sir Francis Bacon
-Albert Einstein
Unread 15-03-2006, 21:35
We use #10 because .001 ohm/ft. is better than .0017 ohm/ft. When needed for weight or size we would use #12, but not often.
Unread 15-03-2006, 21:53
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Well we started with 10 AWG but then we weighed the bot and we switched to 12...
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 19-03-2006, 21:50
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
On our robot some components like yours require 10 AWG for good/reliable performance. We wired our robot in 10 AWG across the board, that way we only had to buy 10 AWG, and if a connection needs to be replaced, other than the battery, everyone knows that it is 10 AWG.
Eat, Sleep, Build Robots
Unread 20-03-2006, 00:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If we are ever forced to run 12 instead of 10 gauge for purposes of weight, we'd have bigger weight problems than the weight of our wires.
Unread 26-03-2006, 10:10
Team75electric's Avatar
Team75electric Team75electric is offline
AKA: Alex Kimmelman
FRC #0075 (Roboraiders)
Team Role: Electrical
Team75electric has a little shameless behaviour in the past
Send a message via AIM to Team75electric
We use 10 Awg fo rthe 409 amp fuses mainly so we dont over heat any of our CIM motors. espically on our drivetrain, b/c we have a ton of power
