Go to Post Even then, the robotics competiton is only part of FIRST. - Billfred [more]
Unread 16-03-2006, 22:42
Barry Craig's Avatar
Barry Craig Barry Craig is offline
Crazy Mad Filer
FRC #1852 (Team Amore)
Team Role: Electrical
Barry Craig is an unknown quantity at this point
Re: 2005 Electricals or 2006?
2006 because it came with the kit. If it works, why not use it? And we never tripped a breaker or set the robot on fire. Therefore, we win.
Barry "Barricus" Craig
Electrical Head/Leadership/Hammer & File Man
Team Amore 1852
"Details, details!"-Mentor Mark Johnson, on everything that we thought was important.
2006 AZ Regional - 8th Place, Highest Rookie Seed Award, Judges Award
Amore Robotics
Unread 16-03-2006, 22:52
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
2005. I hope FIRST sees the overwhelming preference and considers switching back next year.
Unread 16-03-2006, 23:31
The Lucas's Avatar
CaMOElot, it is a silly place
Chief Delphi is not the best sample set. The 2006 stuff works fine for most of the teams. People who post on this thread have spent time thinking about which setup is better, something I don't think the majority of teams think about. People posting this thread also represent teams that have stricter weight budgets than most. My team takes sensors off to make weight.
As an inspector, I would like to see the 2005 panel in the kit. It is very easy to trace wires back to the single panel. With only 1 panel, it is less likely that teams will make mistakes or forget a piece. Many teams have problems running #6 wire for the 2006 setup, while the 2005 panel can be done with a single Anderson connector and a couple ring lugs.
Obviously, the underlying factor is cost (2005 panel is $85). I would like to see IFI make a cheaper 2007 panel without all the bells and whistles of the the 2005 version.
How many people actually use the serial breaker trip feedback?
I don't, because serial cables weigh too much
Robot Inspector
Unread 16-03-2006, 23:51
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
We too use the 2005 panel without feedback for the weight/convenience/space.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 17-03-2006, 14:30
Crazy Mad Filer
The feedback port on the 2005 model was my only argument for the panel. We already have more than enough space for more breakers on the 2006. Plus, you can just add another breaker panel if need be for meore space.
Team Amore 1852
Amore Robotics
Unread 18-03-2006, 22:13
Loki1989's Avatar
Loki1989 Loki1989 is offline
AKA: Mike Parker
FRC #5338 (RoboLoCo)
Loki1989 will become famous soon enough
we used the 2006 setup but i would have liked to have used the 2005 setup it seem like it would be easier to wire.
we busted out the 2005 panel when we ran out of space for our fifth cim therefore taking up more space and no to actually put it
2017 - FRC 5338 RoboLoCo - Mentor
2005-2013 - Team 1544 - One Byte Short
Unread 18-03-2006, 23:32
Umm Errr...
2005. Great investment
1139 Alumni
Unread 19-03-2006, 01:01
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
2005 never even considered all those super heavy maxi blocks and ground stud. We are even running a mini bike cim on a thirty amp breaker instead of a 40 to keep from things light and to open sooner (too much power) if balls jam the roller mech.
Unread 19-03-2006, 01:16
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
2005 breaker panel - weight, ease of wiring, cleaner layout - an all around superior solution. As soon as IFI's stock recovers, I will be purchasing a few for projects of my own, actually.
www.metalmoose.com
Unread 19-03-2006, 07:40
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
2005. Best money spent for robotics components
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 19-03-2006, 08:36
Loki1989's Avatar
AKA: Mike Parker
what i meant was that its sitting inthere with the 2006 setup i wasnt clear enough.
Unread 19-03-2006, 10:38
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
We used the 2005 one (after I bugged the student in charge of electrical to consider the options). It's much lighter, cleaner looking, easier to use .. I could go on forever.
Regarding FIRST bringing it back .. this was something I thought about and this is the conclusion I've reached (which might be wrong, but I'm willing to make a gamble on it). FIRST has always been looking for ways to cut costs in the kit. The breaker panel was gone this year, and so were the LEDs. Both are items that came from IFI. IFI is already responsible for the control system and the electronics (meaning spikes, victors, radios) .. and it leaves me under the impression that FIRST couldn't financially justify using the breaker panel (there were also stories from last year of the casing breaking open .. which is a big concern). By using the Maxi Blocks, the AB Terminal block, and the other things that IFI don't supply, it opens FIRST up to other sponsors that can provide the items at a lower cost, if any.
Now, I don't work for FIRST or IFI, so take that as an educated guess for whatever its worth. I would love to see the breaker panel come back again .. but if FIRST doesn't want to put it in the kit, at least allow it as an OTS part.
And I'm with The Lucas on this one, a "dumb" breaker panel would be awesome. The flashing light did nothing but drive us crazy after we kept tripping the fuse on our FP motor in 05.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 19-03-2006, 13:00
AKA: Tom Cooper
The best I am hoping for is the 2005 with out all the bells internal CPU, as an available option. Should be cheaper and if you are not going to use the interface why buy it? We have enough to do for the programmer with out trying to get breaker info back from the panel. However if, as part of the (2005+) panel we could get branch currents, then I would changing my tune.
Unread 21-03-2006, 16:39
Generator of Entropy
FRC #2973 (The Mad Rockers)
We used the 2005 at my request - clean, compact, light. I loved it when it came out. Didn't use the diagnostics.
I have a couple questions, however:
1) IFI instructions (and lettering on the panel) say "For optimum power distribution, the auto-resetting breakers should be installed from the lowest number to the highest number", starting with 30 Amps. Does this really make that much of a difference? Is it just the power drop due to difference in resistance because of a shorter circuit length through the board? Wouldn't I have an equal or similar increase in power drop if I had to add additional length wiring to reach the lower numbered terminals rather than taking the shortest path to the breaker board?
2) Likewise, isn't ground ground? Does it matter where on the ground panel I hook up my ground wires? Can't I hook the ground from source number 1 to any ground terminal and get the same effect?
Unread 21-03-2006, 21:31
AKA: Dr. Brooks
no team (WRRF)
I have not taken a breaker panel apart to check consistency of the design with the recommendations, but you want your high current grounds as close as possible to the ground lug, and you want your high current breakers as close as possible to the power lug, in order to minimize voltage drop for these circuits. The internal layout that you would guess from exterior layout is consistent with this.
We love this breaker panel and next year we might have time to put some of the diagnostic info on the IO display. I don't want to do a dash board, but I think that a led light when a new breaker pops and an indicator on the user led display of which one it is could be a good thing.
2006 code on 2005 RC? RedBarons Programming 1 04-03-2006 14:29
2006 Camera identical to 2005? de_ Programming 6 23-01-2006 03:28
CMUCam2 - 2005 vs 2006 changes kmcclary Programming 1 09-01-2006 17:24
2005 - 2006 NASA FIRST Robotics Sponsorships KathieK Fundraising 2 27-11-2005 11:04
