Go to Post I didn't say this! - Max Lobovsky [more]
Unread 21-03-2006, 16:00
Jackel148's Avatar
Jackel148 Jackel148 is offline
FTC #0160 (Impulse)
Jackel148 is an unknown quantity at this point
Question Ultrasonic will not work with another Ultrasonic plz help
Let me first say that I am working with Vex programing for teh FVC compatition. I have tried several times to get my ultrasonics working together. I have tried putting a print to screen for each and they work individually, however, when I try to put them both together they will not work. Can anyone help me with my problem?
Unread 21-03-2006, 17:10
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Re: Ultrasonic will not work with another Ultrasonic plz help
how are you setting them up? ie pointing at each other or straight forward towards a target?
Eat, Sleep, Build Robots
Unread 21-03-2006, 18:07
Electrical Engineer
Rookie Year: 1995
Jackel,
Each sensor must be on its own interrupt line and digital output line. Also, you must stagger the output pulse so that both will not transmit a pulse at the same time.
I can give you code fragments on how to so it in C but not EasyC.
Mike
Mike Betts
As easy as 355/113...
Unread 21-03-2006, 18:08
Gdeaver Gdeaver is offline
FRC #1640
Your are probable having the 2 sonars interfere with each other both physically and in the timing subroutines. Don't know how you have them set up and what your measuring, but you could mount one sonar on a servo. Point in 1 direction read it , move to another direction and read it.
Unread 21-03-2006, 18:13
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
And you might want to think about how to handle when another robot is also sending out sonar pulses.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 21-03-2006, 21:57
Jackel148's Avatar
FTC #0160 (Impulse)
I have them set up so that the two of them are facing forward and I am trying to get them to both line up the bot so that it is straight...I tried putting a boared in the middle so that they could not interfere with each other however when I did a print to screen I got nothing which is what happened the rest of the times.
If it is them interfering with each other how would i fix that?
Unread 21-03-2006, 22:36
Electrical Engineer
Rookie Year: 1995
Here is a code fragment for managing 3 ultrasonic sensors:
int Service_Ultrasonic_Sensors (void)
  ultra_counter++;
  switch (ultra_counter)		// Process Ultrasonic Transducer
	case 1:
	  for (pulsecount = 0 ; pulsecount < PULSE_WIDTH ; pulsecount++)
		rc_dig_out10 = 1;		//	Make another pulse
	  rc_dig_out10 = 0;			//	The pulse is over
	  break;
	case 2:
		rc_dig_out11 = 1;		//	Make another pulse
	  rc_dig_out11 = 0;			//	The pulse is over
	  break;
	case 3:
		rc_dig_out12 = 1;		//	Make another pulse
	  rc_dig_out12 = 0;			//	The pulse is over
	  break;
	case 4:
	  if (ultra_left_flag == TRUE)
		INTCONbits.GIEL = 0;		//	Disable Low Priority Interrupts
		ultra_left_time = ultra_left_stop - ultra_left_start;
		INTCONbits.GIEL = 1;		//	Enable Low Priority Interrupts
		ultra_good_count++;
	  else
		ultra_left_time = -1;
		ultra_bad_count++;
	  if (ultra_front_flag == TRUE)
		ultra_front_time = ultra_front_stop - ultra_front_start;
		ultra_good_count++;
	  else
		ultra_front_time = -1;
		ultra_bad_count++;
	  if (ultra_right_flag == TRUE)
		ultra_right_time = ultra_right_stop - ultra_right_start;
		ultra_good_count++;
	  else
		ultra_right_time = -1;
		ultra_bad_count++;
	  ultra_left_flag = FALSE;
	  ultra_front_flag = FALSE;
	  ultra_right_flag = FALSE;
	  ultra_counter = 0;
	  break;
	default:							// for any unexpected result
	  ultra_counter = 0;
	  break;
The code above can be called once per communications loop or via a timer interrupt, et cetera...
the variables ultra_bad_count and ultra_good_count were used during development and can be deleted.
An example interrupt routine is:
void Service_DIO4_Interrupt(unsigned char state)
	if (state == 1)						 // rising-edge interrupt
	ultra_front_start = Read_Timer_3 ();	 // Read Start Time.
	else									// falling-edge interrupt
	ultra_front_flag = TRUE;
	ultra_front_stop = Read_Timer_3 ();	  // Read Stop Time
The user routine has only to test for the time to be greater than zero to know that it is valid data.
Hopefully, this helps.
Mike
Mike Betts
Unread 21-03-2006, 22:44
Jackel148's Avatar
FTC #0160 (Impulse)
I will try to convert this please check back tommorow and see if it worked thanks for the help.
Jackel
Unread 08-05-2006, 00:13
Steve0100's Avatar
Steve0100 Steve0100 is offline
Steve0100
Steve0100 is on a distinguished road
Jackel,
Mike
This is the same problem that I just encountered, in trying to use 4 Ultrasonic sensors on a 4- wheel holonomic robot. Very very frustrating.
Does anyone have an EasyC solution to using multiple sonar sensors? I've tried using waits in between Ultrasonic sensor readings to try and avoid timing loop interference, but that has not worked. Each sensor works individually but not when more than one is used at a time. Is there too much latency in Starting and Stopping each individual Ultrasonics sensor in turn?
Thanks!
Unread 09-05-2006, 14:03
Ctx32 Ctx32 is offline
Ctx32 is an unknown quantity at this point
Thanks!
I have 4 working using EasyC, But i need help with the encoders
I was going to send a pic, But don't know how on this forum.
My email is ctx3201@comcast.net
Let me know and I'll send it to you or tell me how to send a pic to this forum.
Calvin
Unread 10-05-2006, 15:31
Calvin
Heres the pic link:
http://i71.photobucket.com/albums/i1...01/4Ultras.jpg
3D Studio Max won't work David the bomb 3D Animation and Competition 3 03-03-2004 17:12
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
