Go to Post Past success does not guarantee future results.... - Koko Ed [more]
  #61   Spotlight this post!
Unread 20-03-2006, 19:35
general's Avatar
general general is offline
That's me!
AKA: Bryan
FRC #0213 (Dirty Birds)
Team Role: Webmaster
general is an unknown quantity at this point
Send a message via AIM to general
Re: php/forms/posting/I NEED HELP!!!!!!!!!
Originally Posted by MattD
Yeah, that works too. I just like to explicitly concatenate my strings. (Try saying that 3x fast..)
i don't even understand what you said
http://www.khsfirst.com/
  #62   Spotlight this post!
Unread 20-03-2006, 19:40
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Concatenation is the joining (or addition) or two or more strings of text. In PHP the string concatenation operator is "."
In most programming languages, when you want to add in the value of variable within a string of text, it must be concatenated with it, and not just within a string literal (everything inside the quotation marks) in order to be recognized. PHP picks up on the usage of variables inside of literals though, but I still like to use the concatenation operator. It's just a preference thing, really.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
  #63   Spotlight this post!
Unread 20-03-2006, 20:05
general's Avatar
That's me!
AKA: Bryan
Thank you, all of you for all of your help!
  #64   Spotlight this post!
Unread 21-03-2006, 20:39
general's Avatar
That's me!
AKA: Bryan
sry got another question, Will this work?( all of the second ones are the code ex. <-- &#33--> is " ! ")
$write = str_replace("!", "!", $write);
$write = str_replace("$", "$", $write);
$write = str_replace("&", "&", $write);
$write = str_replace("'", "'", $write);
$write = str_replace("(", "(", $write);
$write = str_replace(")", ")", $write);
$write = str_replace(",", ",", $write);
$write = str_replace(";", ";", $write);
$write = str_replace("?", "?", $write);
$write = str_replace("^", "^", $write);
And will two words work in a
PHP Code:
str_replac()
  #65   Spotlight this post!
Unread 21-03-2006, 21:35
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
PHP Code:
str_replac()
Use arrays instead of a ton of str_replace calls.
Example:
$bad_words = array('guy', 'dog', 'cat');
$good_words = array('male', 'canine', 'feline');
$write = str_replace($good_words, $bad_words, $write);
http://www.mikesorrenti.com/
  #66   Spotlight this post!
Unread 21-03-2006, 21:44
MattD's Avatar
If you're looking to handle HTML entities, I would just use the htmlentities() function, rather then hard-coding every entity that you want to have replaced.
PHP Code:
$write htmlentities($writeENT_QUOTES);
  #67   Spotlight this post!
Unread 21-03-2006, 22:38
general's Avatar
That's me!
AKA: Bryan
oh shoooooooooooot, all the str_replace s are case sensitive!!!!!!!!!!!!!!!!!!
  #68   Spotlight this post!
Unread 21-03-2006, 22:49
Mike's Avatar
AKA: Mike Sorrenti
Use str_ireplace
Same thing as str_replace, but case insensitive.
  #69   Spotlight this post!
Unread 21-03-2006, 22:51
general's Avatar
That's me!
AKA: Bryan
Originally Posted by Mike
Use str_ireplace
it dosent work in my version
  #70   Spotlight this post!
Unread 29-03-2006, 14:36
general's Avatar
That's me!
AKA: Bryan
ok so it works great, but now theres like 25 quotes. I want to make a second page so you dont have to scroll forever to get to the bottom. Do i have to make a new database or can i use the same one?
