Go to Post Remind me again. Why do we let the GDC hold us captive to these hints year after year? - jholman [more]
Unread 19-03-2006, 20:12
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Any other robots w/Easy C at Boilermaker?
Curious if any other robots tried Easy C and was at Boilermaker? Was you using the camera?
If you did, can you tell me what matched you played? I want to watch your video in automode for a startup delay.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 22-03-2006, 21:20
Controls Engineer
AKA: chakorules
Re: Any other robots w/Easy C at Boilermaker?
Ok....
Any robots AT ALL using EasyC? Do you have a video clip of your robot starting auto mode at ANY regional?
Favorite CD quote:
Unread 22-03-2006, 22:14
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Our robot is %100 EasyC, but our regional (Lonestar) isn't until next week, so we will see. Testing auto with the dongle seems to be ok though. I don't think we have what you want, though, since our camera is sitting on the shelf where we can't hurt ourselves Seriously, we designed a low shooter so didn't need the camera.
Unread 22-03-2006, 23:39
Gdeaver Gdeaver is offline
FRC #1640
We're using easy-c. Early on the programmers played with the camera. I seam to remember that 3 seconds was the best we could get a lock on and some times much worse. Also there where problems reacquiring a lock when it was lost. The camera was sucking up to much time and resources with little hope of success. We abandoned the camera. Our shooter can make the goal from the near start position. We optically align it, turn the motor on and feed balls. It's very accurate but, our feeder is slow. From the 2nd position we drive a minimum 4.5 ft and feed balls. We use a vex encoder (cheap) for distance with the GTS function. For shooting in the offensive period we are using an analog organic processor with a binocular vision subsystem (Human) to aim. I commend any team that got a camera system working reliably.
Unread 22-03-2006, 23:48
Controls Engineer
AKA: chakorules
We didn't have any problems with the camera working at all. You can see where we get HIT and knocked off course here, but then we re-aim and finish taking the shots. Camera worked great for us.
http://www.soap.circuitrunners.com/2...n_010_bad2.wmv
I was curious if any other Easy C robot have a startup delay in auto mode. Watch this video, (we are 1501), lower left. you'll see that all robots start moving first but us. I wondered if that was the difference of using Easy C or something.
http://www.soap.circuitrunners.com/2...ker/in_005.wmv
Favorite CD quote:
Unread 23-03-2006, 00:54
AKA: Dan
I recall when we were playing with our camera that there is a delay for the camera and gyro initialization. So the question is are you starting the camera or gyro anywhere else but the Initialize loop? I'm thinking maybe you are calling a start at the beginning of the Autonomous loop? Because once the camera is initialized, it begins tracking whether the field is enabled or not, so there is no reason for any delay unless it gets reinitialized. Does it do the same thing with Autonomous test dongle?
EDIT: BTW, Your team's robot looks great Chris!
Unread 24-03-2006, 21:15
Controls Engineer
AKA: chakorules
I'll have to check into this. I think if I remember right, the "start" was only once in the INI function. Then the "capture" was twice I think. Once in Auto and Operator functions. Again, I'll have to look at it sometime.
Favorite CD quote:
Unread 26-03-2006, 10:07
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You should be starting your camera and initializing the gyro in the Initialization() function. I would also recommend starting timers and pretty much any other sensor in there as well. That way its ready once the program starts. Our team had no problems with startup delay.
Nice Robot and good job in automous by the way!
I would also recommend to any team in general if you don't want
to use the camera to drive use it for a manual aiming system that lights up the LEDs on the OI. I would recommend that you also fix the camera because it
complicates things when its panning and tilting.
I think going to post a program today with a function any team can import
to use a fixed camera mount to use it and the OI aim manualy with the camera.
Contrary to popular opinion..."wedge" robots are out David Brinza Rules/Strategy 23 24-02-2006 09:42
Do robots have feelings? Mike Chit-Chat 23 02-01-2006 19:48
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
How are robots lowered? Yan Wang Rules/Strategy 5 22-02-2004 22:10
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
