Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Unread 23-03-2006, 09:05
koenig3456 koenig3456 is offline
Programming Coach
None #0681 (EARTH Squad)
koenig3456 is an unknown quantity at this point
Question Using MPLAB SIM
I tried using the MPLAB SIM debugger to debug a program that uses WPILib. I get a Stack over flow error before the main() function is reached. Is there any way to use the MPLAB SIM debugger to debug a program that uses WPILib?
Unread 23-03-2006, 10:27
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Using MPLAB SIM
I don't know about WPILib, but the stack overflow error is the same that I get when I accidentally run a program compiled without the _SIMULATOR symbol defined. Set it on the MPLAB C18 tab of your project's "Build Options" dialog.
Unread 11-05-2006, 13:57
b0b0b0b b0b0b0b is offline
b0b0b0b is an unknown quantity at this point
Re: Using MPLAB SIM
Thanks, this solved my problem.
Unread 23-01-2008, 22:33
sfs sfs is offline
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
Re: Using MPLAB SIM
I am getting the exact same error, even when the _SIMULATOR macro is defined in the MPLAB C18 tab. Is anyone able to use MPLAB SIM with the most recent WPILib (WPILib2k6.lib) on the FRC? I get this error message when trying:
CORE-E0001: Stack overflow error occurred from instruction at 0x0030b2
Unread 10-02-2008, 16:40
robofan robofan is offline
FRC #0540
robofan is an unknown quantity at this point
Re: Using MPLAB SIM
I solved stack overflow issue by adding the following code to ifi_frc.h:
#ifdef _SIMULATOR
#define RESET_VECTOR 0x000
#define HIGH_INT_VECTOR 0x008
#define LOW_INT_VECTOR 0x018
#else
#define RESET_VECTOR 0x800
#define HIGH_INT_VECTOR 0x808
#define LOW_INT_VECTOR 0x818
#endif
Also, you need to remove or comment out the following lines in ifi_frc.h:
//#define RESET_VECTOR 0x800
//#define HIGH_INT_VECTOR 0x808
//#define LOW_INT_VECTOR 0x818
Unread 11-02-2008, 14:39
sfs sfs is offline
AKA: Steve Siirila
Re: Using MPLAB SIM
#ifdef _SIMULATOR
#else
#endif
That might work if you are using Kevin Watson's ifi_frc base code, but what about those using WPILib where no source code is available?
MPLAB SIM debugger Questions Chris_Elston Programming 2 16-01-2005 11:28
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
