Go to Post For FIRST robots, the phenomena listed above just do not apply. - Paul Copioli [more]
Unread 23-03-2006, 14:50
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
power to the cam?
ok everytime i try to go into labview to config the camera and i hit run, i get this, "The application is closing because of a reported error. You should confirm that the correct serial port has been selected. You should confirm that the camera has power and is connected to the PC via serial cable.", now how the heck do i see if the camera is powered, the pwm out put has power but i dont know if im trying to make a non powered cam to work or not, any help is apreciated
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 23-03-2006, 14:53
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: power to the cam?
There are three LEDs on the camera board. If any of them are lit, then the camera has power. Make sure they are lit fairly brightly: if they look dim, you may have a drained backup battery.
Unread 23-03-2006, 15:17
AKA: Cameron Dennis
Question Re: power to the cam?
where are these LEDs i do not see any on the camera board
www.frc1266.com
Unread 23-03-2006, 17:33
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
There are 3 LED's on the camera, and they're all right next to the power switch, on the bottom or top, depending on how you have it mounted. Also, make sure you have the NI VISA drivers installed in LabView, you will get that error message if you don't have those correct drivers installed.
Good Luck,
-Chris
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
No power - no problem P1h3r1e3d13 General Forum 2 20-02-2006 07:18
Fried Cam? Denz Programming 5 01-02-2006 21:43
Steps to make cam work? magical hands Programming 7 31-01-2006 17:43
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
