Go to Post Whether or not your team has the technical mentors, as long as your kids are still inspired by the adult technical mentors of other teams, and get the picture that we're trying to portray in this program, the best that you can do is the best you can do. Do it, and be proud of your results. - Beth Sweet [more]
Unread 23-03-2006, 23:54
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Build Options
In IFI’s fix for the 8.2 - 8.3 Voltage Issue and Large Code configuration, the illustration of the Build Options window shows a “-k” parameter in the Alternate Settings box. Ours didn’t already have it. Should we add it? Is it the parameter that defaults chars to unsigned?
Unread 24-03-2006, 00:00
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Re: Build Options
doesnt the compiler documentation explain those settings?
I havent read it, I'm just wondering
Unread 24-03-2006, 00:56
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Re: Build Options
From the MPLab C18 User's guide. That's the only thing I could find on the param.
You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
Unread 24-03-2006, 01:05
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Build Options
Yes, that's what the -k signifies. Setting it should only matter in your code as the libraries are precompiled with their own setting and a byte is a byte when passed.
However, from my standpoint the "fixes" aren't. I used Timer1 and Timer3 to measure robot wheel speed. Even with the fixes in place, Timer3 wasn't working properly. Actually, make that Timer3 just appeared to not work at all.
I know of at least one other team that was never able to get their code to function properly on the 8722 based controller (2006). They were allowed to fall back and use the 8520 based controller (2005, 2004) where their code DID work properly. I know my code exectuted properly on the 8520 before I moved it to the 8722.
Basically, this controller issue cost us a working autonomous.
Where do you actually build your robot and who does the building??? Elgin Clock General Forum 47 14-11-2006 17:50
Who should build the field? Rich Wong General Forum 17 08-03-2006 17:38
CNC Options? Andrew Blair Technical Discussion 5 06-02-2006 18:12
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
Build season wrap up Ryan Albright General Forum 2 24-02-2004 23:17
