Go to Post The awards may or may not come...but the real trophies are the students. - David Brinza [more]
Unread 24-03-2006, 21:20
Tim566's Avatar
Tim566 Tim566 is offline
FRC #0566 (Hot Wired)
Tim566 will become famous soon enough
Ramp help
Our robot is having problems getting up the ramp (backwards unable to pull itself up the ramp and forwards tipping over) so if anyone would be able to provide a quick effective solution it would be greatly appreciated or even just brainstorms
<edit> quick responses are appreciated since our last day of comp is tomorrow</edit>
Thank you from me and i am sure the rest of the team
The only thing about the future of which we can be
certain is that it is uncertain and it will be there whether we are or not.
So my advice is to enjoy life in the present while not disregarding the future.
To everyone going to the competions good luck out there and remember whatever you do have fun doing it
Unread 24-03-2006, 21:23
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Cool Re: Ramp help
If you could, balance the weight more efficiently.
Tomasz Bania
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 24-03-2006, 21:24
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Re: Ramp help
if the problem is traction i would suggest putting on the innovation first tread to gain some extra pull. you could also gear down your wheels by putting on a bigger size of gear on the actual wheels. you would loose a little speed but gain the torque needed. if you have the weight and some wheels, omni-wheels may or may not help. they could pull up the ramp depending on the situation. does that help at all?
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 24-03-2006, 21:26
Tim566's Avatar
Re: Ramp help
thank you very much for your speedy responses but traction is not an issue and as for redistributing weight we don't have much to work with. so any other ideas?
Unread 24-03-2006, 21:30
AKA: Matt Starke
Re: Ramp help
last year i recall 340 actual making a quick battery hoder and riveting it on in a differnt place to shift our weight. it worked great. the moving around of 13 pounds works good. another idea is if you have a compressor, try and find a place to put it were you need the weight. there is 20ish shifted pounds right there. i hope that this helps.
Unread 24-03-2006, 21:32
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Ramp help
well, you cant do much else but redistribute your weight. Without a low center of gravity, you cannot get up the ramp.
unless, though, you have some weird robot that requires a special routine in order to climb the ramp. in that case i would talk to your programmer to develop that routine.
I wish i could help you more man, but without your robot in my view thats kinda hard to do.
--ss32
(sorry read my next post... i dont think i read your description of the problem clearly enough )
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Last edited by Uberbots : 24-03-2006 at 21:45. Reason: ermmm.... read my next post...
Unread 24-03-2006, 21:36
Tim566's Avatar
Re: Ramp help
hmm... that would be a great idea but i am not sure if our robot design would allow that... but thank you anyway. so anyone have the miracle idea to help us get up the ramp? (our motors should have enough power to push us up)
Unread 24-03-2006, 21:40
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: Ramp help
Maye just try to get a little momentum by starting further back, if you're not doing that already.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 24-03-2006, 21:42
AKA: Matt Starke
Re: Ramp help
thats alright. im not giving up yet . it sounds like you have 4 wheel drive. if this is the case, make it 6 wheel drive. this will enable you rear 2 wheels to act as a wheelie bar. thats all i can think of for now.
Unread 24-03-2006, 21:43
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Re: Ramp help
Oh wait, it is simply unable to pull itself up the ramp? well ok then.
What you need to do (well what we did anyway) is approach the ramp slowly, but then GUN the motors as soon as youhit the ramp. That way, you shouldnt flip like you would if you rammed the ramp. Im not sure if this method will work for your robot, but its worth a try right?
RPI 2012
BREAKAWAY
Unread 24-03-2006, 21:44
Tim566's Avatar
Re: Ramp help
we tried that it actually led to slight tread damage and our wheels bounced off the ramp so it was unsuccessful but keep feeding me idea I appreciate the responses thank you everyone and keep 'em coming.
Unread 24-03-2006, 21:46
AKA: Matt Starke
Re: Ramp help
how far up the ramp do you make it before you flip?
Unread 24-03-2006, 21:48
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Re: Ramp help
OH so you have a tread system... thats new.
Well then, what i would sugest is work a strategy out with your alliance. tell them that you need help with the ramp, and if the time doesnt allow then you could help push them up.
without some design modifications, im sorry but you just cant get up that ramp.
RPI 2012
BREAKAWAY
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: Ramp help
1. Move battery to front of bot.
2. Move ?????? to front of bot
3. Post picture of robot to increase helpfulness of responses.
4. Attach bars that slide out so that they hit the ground when you climb up the ramp, like a wheelie bar. Perhaps have some sort of ratchet mechanism so they don't then slide back in when going up the ramp.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
mehul mehul is offline
no team (Technotics)
Team Role: Animator
mehul is an unknown quantity at this point
Re: Ramp help
im not an engineer or something but in our robot, it was difficult to go up to, but some how during the match we diecided to have our shooter wheel on top speed rotating towards the ramp creating somekind of a momentum towards the actual ramp and the robot acctually climbed up, it will take few tried before u perfect it.
Ramp and Tipping Nitroxextreme Rules/Strategy 10 10-02-2006 15:01
Ramp Scoring, At 00:00 or After? Rombus Rules/Strategy 21 05-02-2006 17:02
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Ramp Riot 2004: Call for Comments OZ_341 Off-Season Events 4 28-11-2004 14:53
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
