Go to Post A chop saw may cut aluminum, a knife can also be used to eat ice cream. - fox46 [more]
Unread 24-03-2006, 21:51
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Re: Ramp help
not sure if this helps but this is a picture of our robot doing the ramp.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 24-03-2006, 21:53
Tim566's Avatar
Tim566 Tim566 is offline
FRC #0566 (Hot Wired)
Tim566 will become famous soon enough
Re: Ramp help
Originally Posted by Starke340
how far up the ramp do you make it before you flip?
Well not very far but we never actually measured . (we have 4 rear wheel drive with the cool treads and 2 front "wheelchair" wheels just slightly off the ground so they can roll when we go up the ramp but dont hinder our turning) please keep the helpfull responses coming because even if you dont give me the idea you may inspire me to think of it so please keep 'em coming.
The only thing about the future of which we can be
certain is that it is uncertain and it will be there whether we are or not.
So my advice is to enjoy life in the present while not disregarding the future.
To everyone going to the competions good luck out there and remember whatever you do have fun doing it
Unread 24-03-2006, 21:58
Tim566's Avatar
Re: Ramp help
Unfortunately I don't have any pictures to upload.
spinning wheel idea is interesting if it works
Unread 24-03-2006, 22:07
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Ramp help
This may not work with your robot at all...I really have no idea what the overall design is...
What you have been saying so far is that you have alot of traction in the back and no touching in front.
Again I'm not sure if this would work...but it may be possible to go up the ramp sideways. If you go up the ramp on an angle you wouldn't have to take the complete angle with all of that traction. Center of Gravity would be the only questionable factor here.
Any Pictures could help with troubleshooting...even microsoft paint drawings if pictures are difficult to find.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 24-03-2006, 22:39
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Ramp help
Hmmm to summarize the problem: You can't go up the ramp forwards because the robot flips. You can't go up backwards because your wheels slip right? And you have 6 wheels....the rear 4 wheels are drive wheels and the front wheels are slightly off the ground as "idlers".
My suggestion is if possible to get a running start at the ramp, running backwards so that momentum will carry you far enough up so that your drive wheels gain the top. Another method is to allow an alliance partner to boost you up (again going backwards).
Good luck!
Unread 24-03-2006, 22:44
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Ramp help
What we did when we couldn't ramp was made the front of our robot like a "sled" so it would slide up easier.
The front (or back) of your robot probably looks like a right angle. Take a saw and cut it so it has a 45 degree angle instead. This way, when you run at the ramp at high speeds, some of your forward momentum is converted into upwards momentum to help you get up the ramp.
Unread 24-03-2006, 22:49
Tim566's Avatar
Re: Ramp help
hmm...well i managed to scrap up some photos so heres the links:
Side view
Front view
Ask and ye shall receive
now I hope I get some brilliant ideas and hope these are good enough.
Unread 24-03-2006, 22:57
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Ramp help
If you use smaller wheels on the front it should not push your robot back as far and then not flip you, try that its a fairly quick solution, also hack off any of that stuff on the fron at the bottom that isnt needed so that you could lift those front wheels even more
KK4KQO
http://voltair.us
Unread 24-03-2006, 23:08
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Re: Ramp help
If possible you could have your alliance partners push you up the ramp. We pushed several high profile robots up the ramp at Peachtree.
Just a idea a fast and simple one.
Unread 24-03-2006, 23:10
Cactus_Robotics's Avatar
Cactus_Robotics Cactus_Robotics is offline
Driver Development & Drive Coach
AKA: Adam Shroyer
FRC #0498 (Cobra Commanders)
Cactus_Robotics is a jewel in the roughCactus_Robotics is a jewel in the roughCactus_Robotics is a jewel in the rough
Send a message via AIM to Cactus_Robotics Send a message via Yahoo to Cactus_Robotics
Re: Ramp help
Do you have bumpers? My team found that w/o bumpers our team would topple over but when we tried it during a actual match w/ bumpers we could get up no prob. the extra weight at the bottom did a lot to help us.
Cactus Robotics, We Drive It Like We Stole It!
2001 Team Spirit Award - Southern California Regional
2004 Sportsmanship Award - Arizona Regional
2004 Regional Finalist - Arizona Regional Thanks (Team 696 & 80)
2005 GM Industrial Design Award - Arizona Regional
2007 Rockwell Automation Innovation in Control Award - Arizona Regional
2012 Regional Finalist - Arizona Regional - Thanks (Team 2486 & 4146)
Unread 24-03-2006, 23:18
Tim566's Avatar
Re: Ramp help
all of those are good idea maybe combining some will get us there but please if anyone can think of anything else please share.
Unread 24-03-2006, 23:32
Tim566's Avatar
Re: Ramp help
Well I am going to bed and I will check in the morning to see what amazing ideas the night owls come up with.
good night and good luck to everyone.
Unread 25-03-2006, 00:16
AKA: Matt Starke
Re: Ramp help
looking at the side view, i would say move the middle wheel forward to enable more traction towards the front. this would also allow you rear wheels to catch the robot from tipping backwards, like a wheelie bar. this means cutting off that support piece in front of the middle wheel. maybe move that support piece between the two back wheels. so, move the skyway wheels as far forward as possible and move the middle wheel forward according to that. i don't know. that is my best suggestion so far.
Unread 25-03-2006, 05:26
Tim566's Avatar
Re: Ramp help
You guys all made great suggestions but if anyone else has others please do share them because the more ideas I have to run by the team the better. You can even agree with someone else's idea if you like but I would like more input on this matter before I leave in like an hour and a half. Thank you all very much for your time and support.
Unread 25-03-2006, 06:40
Tim566's Avatar
Re: Ramp help
Well I am leaving for the competition now so your ideas wont do much good for me but you can give more anyway for others or just to simply share knowledge thank you all very much for all your input you have been helpful.
Ramp and Tipping Nitroxextreme Rules/Strategy 10 10-02-2006 15:01
Ramp Scoring, At 00:00 or After? Rombus Rules/Strategy 21 05-02-2006 17:02
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Ramp Riot 2004: Call for Comments OZ_341 Off-Season Events 4 28-11-2004 14:53
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
