Go to Post Speculate away! - IndySam [more]
Unread 26-03-2006, 12:08
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: HELP with drivetrain decision
It all depends on what kind of wheels you are using... The KOP gearboxes with two CIM's output about 175 foot lbs of pushing power, and unless you have very grippy wheels, that is not your bottleneck. Like Luke said, the KOP skyways won't do much in the way of traction, no matter what kind of torque is put into them, they will just spin the second you get into a pushing match. I would try getting more traction with your wheels before adding the two motors, you can do this with zip-ties, or some IFI tread, or a little belting screwed to them in place of tread, aswell as any number of other ways.
*EDIT* I don't think that adding another CIM to only one side of your robot would make it lopsided, as it would only cause a difference in torque, not speed. It might even be your best bet, once you have ample traction. At pittsburgh, we were able to play a KILLER defense with only one side of our drive train, and we use 2 CIMS in each gearbox, one gearbox to a side. By killer defense, I mean that we were still able to push everybody that we tried to, even having only one functioning gearbox. *EDIT*
Hope this helped,
-CodyC
Big Cim's vs. Small Cim's waialua359 Motors 4 11-02-2006 21:57
New CIMs in kit transmission Reyner General Forum 6 15-01-2006 16:59
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
Could a magnetic field around CIMs cause fuses to blow? scitobor 617 Electrical 41 15-02-2005 08:56
