Go to Post "If all else fails, use a bigger hammer" - Steve Florence - Logan Byers [more]
Unread 23-03-2006, 15:06
in between teams
AKA: Luke Van Oort
Re: Interesting Drive Train Idea...
Humph, eight motor drives are for wimps, fourteen... that's more like it! Seriously, why not just make a eight motor eight wheel drive, with the front and rear wheels raised a wee bit? You'd need a really high traction material to harness the power, which would wear down quickly, so you'd have to use wide wheels, but it'd turn nice, and be insanely powerful. Given, this can't push as much as a tank, but it will turn better. Or you could use a pneumatic pop caster on the tank treads... hmm.... where's that Bercoflex catalog...
Team 1219: 2009 - Mentor
Unread 26-03-2006, 13:44
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by DjAlamose
Has anyone ever though of this, Omni tank Treads?
I don't really think there is a good way to do it. I may be wrong, or I possibly havn't thought of something, but I think an omni tank tread system would essentially be pointless in one aspect.
You could create a holonomic or mecanum system with tank treads by mounting rollers on treads, but that defeats the point of treads, traction. It reduces the contact area of the tread greatly to add rollers that allow a holonomic or mecanum system to function.
Tank treads are likely too high in traction to allow a swerve drive systems wheels (treads in this case) to turn properly, but it might be possible.
Returning to the actual topic, having a massive drivetrain is nice, but it can be overkill. I wouldn't go beyond 6 motors, otherwise you would be adding a great extent of weight (not just the weight of the motors, but also the gears required to add them into your drivetrain), removing a motor from your manipulator, and adding significant complexity in both design and manufacturing. 4 small CIMs geared properly (especially in a low gear of a shifter) is adequate for a majority of shoving matches, but I can see why you would want to add additional motors for that "extra kick". Personally, I agree that I would mount them directly into the drivetrain, rather than as an extra kicker at the end.
Beware the slippage issue though. If you're not slipping, you're stalling your motors. Additionally, you may actually strip the treading from your wheel (116 managed to do this twice ). If you're slipping though, that extra motor may just be wasted power.
Drive train and gearboxes Naveen Technical Discussion 15 16-01-2006 17:08
Where Are "Chassis & Drive Train Instructions" Robeaux Kit & Additional Hardware 1 10-01-2006 16:17
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
2 truck drive train Alex1072 Technical Discussion 14 26-03-2004 21:53
