Go to Post We can read about torque and speed in books, we can build a robot and drive it, but determination and character are built by time and encouragement, not just by studying. - Eugenia Gabrielov [more]
Unread 26-03-2006, 14:32
Don Reid Don Reid is offline
Don Reid will become famous soon enough
CMUCam control registers
I am writing (another) program to run the CMUCam and help set tracking parameters. (This one doesn't need Java, or Lab view). I have a couple of questions, that maybe someone can answer.
First has anyone (Kevin?) found a way to read out the sensor registers? I would like to see what the camera's internal code uses for exposure etc.
Second, I copied the various sensor settings from Kevin's code, and one in particular is causing trouble. Is anyone using anything other than the defaults.
Here is what I extracted from the code (maybe I got it wrong, any proof reading would be appreciated).
//Reg,  Value
{0x29, 0x80},	// Common I	= (AEC off)
{0x13, 0x20},	// Common B = (8 bit, auto func off)
{0x2D, 0x81},	// Common J = (flicker rates off)
{0x2A, 0x80},	// Frame Rate Adj 1 = (FRA on)
{0x2B, 0x20},	// Frame Rate Adj 2 = (-3.8%)
{0x12, 0x20},	// Common A (AGC on, AWB off)
{0x00, 0x00},	// AGC	= 1x
{0x01, 0x80},	// Blue Gain = 1 + 0
{0x02, 0x80},	// Red Gain = 1 + 0
{0x03, 0x80},	// Saturation = 1 + 0
{0x06, 0x01},	// Brightness
{0x10, 0x01},	// AE
(Also set NF to 0)
With the AE setting (last), I get an all purple image. With larger values (like 0x40), it works well. Since it is critical that this program use the exact same settings as the camera on the robot, I need to resolve this.
The plan is to have this program and our second camera to get near the field and check out the settings. We had a serious trouble with false positives at our first regional (Portland), and will be in Las Vega next weekend.
Don Reid
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Direct control of a Servo or Speed Controller Schmitty! National Instruments LabVIEW and Data Acquisition 3 06-03-2006 13:53
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
Pre-manufactured control box for FIRST Ben.V.293 Technical Discussion 19 22-08-2005 12:53
2005 RadioShack Innovation In Control Award--What Won? Billfred Control System 8 12-06-2005 01:51
