Go to Post As a rookie team member at my first event, i had a great time, the little glitches meaning nothing. - Gluedtothefloor [more]
Unread 02-03-2006, 13:13
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
Team 116 OI Adapter board
This season, Team 116 designed and built Operator Interface Adapter boards to make OI prototyping and wiring of switches and potentiometers very quick and easy.
We'll be at the NASA / VCU Regional, Richmond, VA and the Peachtree Regional, Duluth, GA.
Here's the Team 116 Operator Interface Adapter Board page with images, and I plan to add additional info later. And here's 2 adapter boards and a prototyping control panel in our team photo section.
It took a long time to hand-wire the boards, though it provided a good learning experience for soldering. Hopefully we'll be able to get PC boards made for next season.
and here's what it looks like (though the LED's are no longer in the design):
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 07-03-2006, 22:37
ECarlson's Avatar
AKA: Eric Carlson
Re: Team 116 OI Adapter board
This photo gives a good example of what these boards are used for.
As the web site says, this is a photo of 2 boards being used to connect a sample control panel to the OI.
- Eric
Unread 07-03-2006, 23:01
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
*Guiness Commercial Voice*
Brilliant!
And what type of connectors are those on the cables?
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 07-03-2006, 23:12
ECarlson's Avatar
AKA: Eric Carlson
On the ribbon cables? and if so, which end are you asking about?
- Eric
Unread 08-03-2006, 06:50
..what type of connectors are those on the cables?
They're called "insulation displacement" connectors. They squeeze right on to ribbon cable.
Unread 09-03-2006, 16:56
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Where did you buy those game ports?
They look so professional and definitely much easier to wire to than soldering to each pin
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 09-03-2006, 17:17
Umm Errr...
Nice breakout box. If you made a PCB and sold em, lots of teams would buy.
1139 Alumni
Unread 09-03-2006, 23:38
ECarlson's Avatar
AKA: Eric Carlson
They're ordinary low-density 15-pin D-sub ribbon cable connectors. A number of companies make them. The ones we bought were Digikey part numbers CMP15T-ND & CFP15T-ND. They were the least expensive ones at Digikey, though they had some cheaper at Jameco, but we were in a crunch to order.
These connectors are pretty nice. They have built-in strain reliefs, and you can have the cable exit either out the side (like we did) or out the back. We used a vice to attach the connectors to the ribbon cables.
The connectors that attach to the PC board have separate strain reliefs available, which we ordered and added after these photos were taken (I forgot to order them the first time). That's why the cables in the photos exit the PC-board connectors towards the center of the board (we built them with the plan to add the strain reliefs later). Now that the strain reliefs have finally been added, the cables properly exit away from the board. We also added pull-tabs with the strain reliefs, but I don't think they are necessary.
- Eric
Unread 09-03-2006, 23:59
ECarlson's Avatar
AKA: Eric Carlson
Thanks. First we plan to have a few PC Boards made for our own team. And, while it has been mentioned, our team hasn't yet started planning for any large-scale manufacturing of boards, but we will discuss it at some point, and hopefully we'll have something available so other teams can benefit.
If we hear from lots of interested teams, it would certainly give our team a good push towards making something available.
- Eric
Unread 10-03-2006, 01:55
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
We made something similar. It's effectively an adapter that allows you to patch pots and switches into the OI. One connector goes to the OI, another goes to a joystick. A group of pins (with our traditional sig, +5, gnd arrangment) let's you connect the pots and switches. A set of jumpers let's you set whether each individual line goes to the joystick or its respective pot/switch pin. Sorry, but I don't have any pictures.
You guys had a good idea with using ribbon cables though. Our boards just have right angle DB15 connectors, so we needed the 15 pin cables to go with them. That ended up being bulkier than expected.
We also made PCBs, homebrew style - cheap, decent quality, but not good for high volume. After you've got a design on the computer, you can print it onto a glossy magazine page with a laser printer. Then you iron it onto a copper clad board. The toner melts and sticks to the board. After it cools, you can dissolve the paper in water without hurting the toner. The toner is some kind of waterproof polymer, so it will work as an etch resist when the board is placed in your copper eating chemical of choice. Once the unwanted copper is gone, drill the holes and clean the board. Now, you're ready to solder.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 10-03-2006, 20:05
ECarlson's Avatar
AKA: Eric Carlson
I'd love to see a photo of your board. I hope you can take some photos and post them.
One of my earlier design plans included a right-angle PC-board mount D-sub connector for the joystick, and a regular round cable and D-sub for the OI connection, but neither of those would have worked well with the pre-drilled boards we used. So that design restriction forced me to come up with the ribbon cable design, which I like a lot. My design ideas and plans went through many iterations before the board reached the form it is in now.
Among other things, I originally thought I was going to put some type of connector on each switch and pott, then I realized that was totally unnecessary, and would create unnecessary work later to prepare the switches and potts. Then I was going to use screw-terminal blocks, but that would require a screwdriver to use, and screws can loosen. Then I decided on the spring connector blocks, because they don't require tools, and they don't loosen.
Thanks for the tips on making PC boards. That could come in handy.
We thought about making our own PC boards, but it would require lots of jumper wires to achieve a single-sided design, and a double-sided design is a lot harder to do by hand. Also, there would have been 120 holes to drill in each board to mount all the parts (now down to 112 holes, with the removal of the LEDs, but still a lot of precision drilling).
- Eric
Unread 10-03-2006, 20:13
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Can't you just use a CNC mill with an itty-bitty drill bit?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 22-03-2006, 13:37
Electrical Engineer
AKA: Phil Baltar
FRC #1351
I finally got some pictures. They're a little hard to see, but I think you can get a general idea out of them.
ID:	4152  Click image for larger version
Version: 3.12
Unread 26-03-2006, 15:45
ECarlson's Avatar
AKA: Eric Carlson
Looks like a nice simple design. I did apply some sharpening to the photos to get a better look.
For future designs, you might want to consider the advantages of dip-switches over jumpers: there are no pins to bend or jumpers to lose. And, the advantage of spring terminals over pin-connectors: there are no pins to bend, you don't need to attach connectors to the switches/potentiometers, and they can't be bumped loose, though the pin connectors are more compact.
- Eric
Unread 15-01-2007, 22:23
ECarlson's Avatar
AKA: Eric Carlson
So, have any more teams designed nice wiring systems for their Operator Interfaces? We're planning to have a few circuit boards made with my design. I'm planning to use smaller quick-wiring connectors, which will be easier on the fingers, and will make the boards smaller. Of course, I'll update the info web page once the new boards are done.
- Eric
[moderated]: Worst Call Ever and Congratulations from San Jose ducttapejason General Forum 45 12-05-2005 13:23
**FIRST EMAIL**/Welcome 2005 FRC Championship Teams! Andy Brockway FIRST E-Mail Blast Archive 1 04-04-2005 16:33
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
