Go to Post I personally think mentors should sit behind two-way mirrors and hold a kill switch for all power tools. ;) - SenorZ [more]
Unread 26-03-2006, 15:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Is this legal
http://www.chiefdelphi.com/forums/sh...ad.php?t=45856
Do you think this is legal under the rules?
Unread 26-03-2006, 15:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Is this legal
I'm gonna say yes now, although my first reaction was the same.
It is a Commercially available Off The Shelf item (COTS) and as far as I can tell does not violate any other rules other than the possible way that it is secured on the robot.
I would have liked to have seen it held down with 80/20 posts above the weight coming off a right angle from the upright posts rather than just zip ties holding it down.
Other than that, it is a very innovative and creative last minute decision.
I applaud the team for their efforts that seemed to have worked out for them.
Unread 26-03-2006, 15:24
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Is this legal
After the pic was taken, the safety inspector said about the same thing regarding the 80/20 posts. The competing version of the robot had 4 very tightly secured L-brackets above the plate to keep it from bouncing around. My only other picture of it is from a distance where a ref and the signs are obscuring the mounts though.
The vices were removed during inspection, as they were deemed a safety hazard.
Engineering tidbit about those zipties: The unnamed main proponent of the zip ties was saying "they're 100lb test, therefore they can hold this 35lb weight". However, you have to consider that while ramming robots/walls/the ramp, the robot will probably decelerate at 5-10g's, thus applying up to 350lbs of force to the zipties as the weight decelerates. When thinking about test strengths, you must also consider the accelerations that those things will undergo.
Unread 26-03-2006, 16:34
IndySam's Avatar
Re: Is this legal
But if they had a shooter before wouldn't this be a secondary mode/accessory that would have to be weighed with the previous shooter mode/accessory?
Unread 26-03-2006, 17:18
scott scott is offline
Free Agent
AKA: Scott Ray
scott has a spectacular aura aboutscott has a spectacular aura about
Thumbs up Re: Is this legal
As long as they re-weighed and met all requirements, there is nothing wrong with it. I Love this, a team realized that their best quality was defense, and quickly improved upon it by lowering CG.
2015 INDY DISTRICT CHAMPIONS (1501 & 829)|2015 PURDUE DISTRICT FINALIST (1747 & 5402)|2015 IN STATE QUARTER-FINALIST (3484 & 461)|2014 IRI QUARTER-FINALIST (624, 33 & 2481)|2014 CORI CHAMPIONS|2014 QUEEN CITY REGIONAL CHAMPIONS (16 & 2665)| 2014 QUEEN CITY XEROX CREATIVITY IN DESIGN|2014 CROSSROADS QUARTER-FINALIST (3494 & 3940)|2013 CROSSROADS FINALIST (1288 & 1756)|2013 QUEEN CITY REGIONAL CHAMPIONS (379 & 1985)|2013 QUEEN CITY EXCELLENCE IN ENGINEERING AWARD|2012 QUEEN CITY QUARTER-FINALIST (379 & 1706)|2012 SMOKY MOUNTAINS QUARTER-FINALIST (1501 & 1261)|2012 SMOKY MOUNTAINS XEROX CREATIVITY IN DESIGN|2011 CAGE Match FINALIST (461 & 1760)|2009 WISCONSIN QUARTER-FINALIST (1024 & 2826)2008 BOILERMAKER QUARTER-FINALIST (1000 & 201)|2007 MIDWEST FINALIST(1000 & 648)|2007 MIDWEST XEROX CREATIVITY AWARD|2006 BOILERMAKER ENGINEERING INSPIRATION|2005 Creator of IRI Vex, "Enter-Action"|2005 CHAMPIONSHIP RADIOSHACK INNOVATION IN CONTROLS|2005 CHAMPIONSHIP GALILEO FINALIST(1108 & 492)
Unread 26-03-2006, 17:39
GB330033 GB330033 is offline
Programming Manager
FRC #1255 (Team Blarglefish)
GB330033 will become famous soon enough
Send a message via AIM to GB330033
Re: Is this legal
I see what you're getting at, but it's legal. This would be considered a modification, not an alternate configuration. I believe that's how they bypassed that. Very innovative.
Hook'Em
Unread 26-03-2006, 17:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Is this legal
The only reason they would have to do what you've described would be if they wanted to selectively swap out their shooter for their defensive setup. If they permanently (for that regional) hack off their shooter, and put dead weight on, they don't have to weigh in with all the old components as well.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-03-2006, 17:45
TF8 TF8 is offline
AKA: Tyler Forbes
#0190 (Gompei and the Herd)
TF8 is on a distinguished road
Send a message via AIM to TF8
Re: Is this legal
As an inspector at a few regionals I am going to have to agree with IndySam on this one. I personally would not allow it unless the weight plus the shooting mechanism plus the robot base did not exceed 120 pounds. It is quiet clearly a secondary strategy as shown by thier past behavior and have to be part of the multiple mechanisms weight ruling.
This is solely the opinion of me and only me, my posts represent my personal views only, and do not represent the views of either my team, nor its sponsors.
Tyler Forbes
Unread 26-03-2006, 17:47
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
Re: Is this legal
my impression of this is that even though it is not a custom made part it would still be forbode due to rule <29> which allows for only 25lbs worth of additional parts to be brought to events by teams as upgrades for their robot.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 26-03-2006, 17:48
Cory's Avatar
AKA: Cory McBride
Re: Is this legal
only if they plan on putting the other mechanism back on at the same regional. It essentially became a permanent change when they scrapped their shooter and stuck weights on.
Otherwise it's just treated as a modification.
2001-2004: Team 100
Unread 26-03-2006, 17:49
TF8 TF8 is offline
AKA: Tyler Forbes
Re: Is this legal
As an inspector at a few regionals I'm going to have to agree with IndySam on this one. The team must comply with the multiple mechanisms weight ruling. I personally would not let it go unless the base plus shooter plus new defense weights did not weigh more than 120 pounds together. This is obviously a secodary strategy based on their past experience. This one should not have made it past the inspectors.
Tyler Forbes
Unread 26-03-2006, 17:52
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Is this legal
Could you please explain. I am not aware of this happening before. I also did not hear of any rumor that they had planned this in advance. They really played well defensively all of the regional.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 26-03-2006, 17:55
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Re: Is this legal
I was unsure about this wiehgt too but did my best to secure it and seems like it worked very well this by all means wasnt a planned thing, many team members were against this until the saw it run defensively.
Unread 26-03-2006, 18:27
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
Re: Is this legal
<R29> Teams may bring a maximum of 25 pounds of custom FABRICATED ITEMS (SPARE PARTS, REPLACEMENT PARTS, and/or UPGRADE PARTS) to each competition event to be used to repair and/or upgrade their robot at the competition site. All other FABRICATED ITEMS to be used on the robot during the competition must arrive at the competition venue packed in the shipping crate with the robot.
This rule states that only 25 pounds of fabricated parts may be brought into the competition event. I don't know of any rule that limits purchased parts (other that cost rules).
As for the two configurations of this robot. I agree with others that because there was no intention to put the shooting mechanism back on then both configurations do not need to be included in the total weight. There was a answer in the Q&A last year that explained this very clearly. Although that was last year I would assume the interpretation would be the same. If this wasn't the case then all robots that decided to make a change to a part during the regional would have to include the old and new mechanism in their weight.
This robot was inspected before the elimination rounds and passed.
I can vouch for the fact that the didn't plan on doing this before the regional. The team actually discuss this idea quite a bit before the decided to go with it. It worked great and they were a very valuable defensive partner.
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 26-03-2006, 18:30
Re: Is this legal
There is no rule about a team altering their design at an event, provided that the change is permanent(for the regional, at least)or that all configurations weigh less than 120 pounds. If they completely scrapped their shooter, they are legal. If it would take them 3 hours or so to change back, I'd say it's borderline. But from what I can tell, it's legal. I'm sure the inspectors at the event thought about this one, and, since they passed it, I'll go with their ruling, not second-guess it.
Air Conditioning tube legal? Arkorobotics Rules/Strategy 4 31-01-2006 16:15
Is it legal to change pit locations ? capof541 General Forum 9 24-02-2005 12:36
Wireless Serial Link - Legal Yes/No? the_undefined Programming 12 28-01-2005 12:23
gas shocks legal? ajlapp Rules/Strategy 3 01-02-2003 22:42
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
