Go to Post Inspiration is created by a vision and is reinforced with success. - rourke [more]
Unread 23-03-2006, 23:33
Musician's Avatar
Musician Musician is offline
Mechanical/Electrical/Driver/Music
AKA: Cody
FRC #0339 (Rappahannock Robotics)
Musician is an unknown quantity at this point
Robot Metamorphosis
this year, we changed our robot around so much and so often (last minute and at the regionals) that after each change in was like a new robot. (there will be and article on this at our website sometime)
I was just wondering what kind of last minute metamorphosis other robots have went through?
EDIT: oh yeah, while talking about fixing robots, our team has been sponsored by Igus for the past 3 years and i've never heard of one of their bearings breaking. this year we broke 3. 2 within like an hour and a half of each other. have you guys broke any?
2006 - Semi-Finalist at the Chesapeake Regional
2005 - Quarter-Finalist at the Duel on the Delaware
2005 - 1st seed at the Duel on the Delaware
2005 - Semi-Finalist at the Capital Clash part of the Digital Expo in D.C.
2005 - Finalist at the NASA/VCU Regional
2004 - Quarter-Finalist at the NASA/VCU Regional
2004 - Motorola Quality Award at the NASA/VCU Regional
2003 - Featured on the Discovery Science Channel
2003 - General Motors Industrial Design Award
2002 - Winner of the Johnson & Johnson Mid-Atlantic Regional
2001 - Xerox Creativity Award
Unread 23-03-2006, 23:46
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Re: Robot Metamorphosis
We ended up never mounting our shooter, adding a hopper, adding a door, removing the hopper, and adding netting... So quite a bit.
You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
Unread 23-03-2006, 23:48
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
Well, our drive has been in multiple stages, each one slightly different than the rest.
We originally planned for a 6WD robot in which the middle wheels could pivot up in order to create a 4WD setup in order to hold our ground while shooting, and also to create a "nook" in the center so we could go up the ramp with ease. Lo and behold, the entire contraption weighed 10lbs for the frame pieces and motors, and that happened to put us 5 lbs overweight.
To follow up to that system, we made a simple 6WD, with the center wheels lowered to allow turning, but what resulted was a teeter-totter effect when we tried to shoot, which was hilarious to watch when our shots hit above and below the goal.
That is how the robot shipped.
During our first fix-it window, our main engineer, Art worked on developing a castor-drop system similar to the one we used on our 2003 champion robot.
To make a long story short, what ended up happening was that the center wheels were removed altogether, the castors were added up front, powered by pneumatics, so then we installed an entire pneumatic system in whatever space was availible on the robot.
I once asked Jim Zondag from FRC 33 Killer Bees: "Are you guys done with your robot?"
He replied with, "This robot won't be done for a long time, because we keep on fixing it"
I think that making continuous improvements is one of the best parts of FIRST, just because there's always room for a little change.
_Alex
Unread 24-03-2006, 00:05
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
well, we orignally had a shooter...which we still do, just different. It was supposed to be single axis, dual 6" skyway wheels. It is now a powered roller. More specifically, it's the roughtop belting wrapped and strapped (yes it's held on by string) around a plastic CIM motor coupler from yesteryear. it works well for getting low goals anywhere from mid-field right up to the corner ramps. The drivetrain stayed the same, and thankfully we didn't have to remove the pneumatics!
Unread 24-03-2006, 00:56
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
well nothing much really this year, but last year we had to add a whole new arm right before the competition(i mean Thursday).
This year we had some regular trouble with our hopper, but we were able to fix it at our first regional.
Unread 24-03-2006, 01:02
IraJason IraJason is offline
In Search of "Bang Head Here" Sign
AKA: Ira Goldberg
FRC #3632 (D-Tecs); FRC #1712 (Dawgma)
IraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant future
Send a message via AIM to IraJason Send a message via MSN to IraJason
During build, we had put together 3 completely different chassis designs in 24 hours before we settled on one. Probably saved us a lot later on in terms of weight.
Many respectable physicists said that they weren't going to stand for this - partly because it was a debasement of science, but mostly because they didn't get invited to those sort of parties."
-Douglas Adams The Hitchhiker's Guide to the Galaxy
2007 Galileo #6 seed, 5th Alliance Captain, Semi-finalist
2007 Philly Regional #4 Seed, Philly Regional GM Industrial Design Award Winner
2006 Philly Regional Highest Rookie Seed,Philly Regional Rookie All Star
Unread 24-03-2006, 23:40
YonZ's Avatar
YonZ YonZ is offline
FRC #0694 (Stuypulse)
YonZ has a spectacular aura aboutYonZ has a spectacular aura about
drivetrain count=6
Hartford:
1. brecoflex treads
<snap!>...
2. brecoflex tread MATERIAL wrapped around tread pulleys, 2wd (didnt have enough materials for 4)
3. wheels swapped for 2wd, diff material on pulleys
NYC:
4. 2 Omniwheels and material 2 pulley wheels, 4wd
5. 6wd with small IFI wheel in center
-(4. reinstated)
6 (potentially tomorrow). Omniwheels break, we might continue driving with the broken ones as they wont cause too much of a problem, else we'll be swapping those for skyway wheels
What haven't we tried? pneumatic wheels...thats about it...
Team 694
  • 2006- NYC Regional Website Award / NYC Regional Creativity Award / NYC Regional Finalists
  • 2005- NYC Regional Chairman's Award / NYC Regional Control Award / NYC Regional Semifinalists / Championship Galileo Division Semifinalists
  • 2004- NYC Regional Entrepreneurship Award / NYC Regional Quarterfinalists
Unread 25-03-2006, 00:42
DarMagi DarMagi is offline
DarMagi will become famous soon enoughDarMagi will become famous soon enough
We actually took a week to design what everyone wanted on Autodesk, then we built that, of course with some tweaking, such as a ball pusher that was scrapped and a dumper/hopper that was way too long. Other then that, I definately recommend putting a design in autodesk before you start building, it helps to pick out design flaws. Of course, you can have some people still building an actual chasis while this is going on.
Unread 26-03-2006, 16:45
Musician's Avatar
AKA: Cody
we used autodesk, but we didn't have time to test the robot and see what went wrong (we had some very unexpected difficulties in machining some of our parts). so we got to test it at regionals (the smile is sarcastic)
Unread 26-03-2006, 18:15
Nuttyman54's Avatar
Mentor, Tactician
I would like to nominate 1281 for their AWSOMELY EFFECTIVE modification. See the picture
Interesting stories of the 06 building season lallamavolador General Forum 25 23-02-2006 12:37
Robot songs Alex Burman Chit-Chat 19 24-01-2006 08:07
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
