Go to Post Tolerance, forgiveness, humor, and lessons learned are tools we can find here. - JaneYoung [more]
Unread 23-03-2006, 18:07
P1h3r1e3d13's Avatar
P1h3r1e3d13 P1h3r1e3d13 is offline
Unregistered User
FRC #0295
P1h3r1e3d13 is an unknown quantity at this point
Question VEX Ultrasonic Sensor delay
I am using EasyC and a VEX Ultrasonic sensor, and the "GetUltrasonic" command hangs up my code for 1/4 - 1/2 second each time it's used (once per loop).
Has anyone else had this happen? Has anyone had this not happen? Has anyone fixed this problem? Has anyone used the Ultrasonic sensor with "hard" C? If your ultrasonic code (Easy or hard) runs smoothly, would you mind sharing it?
Thanks
Edit: Should this be in the EasyC for FRC section? Sorry about that.
Unread 26-03-2006, 07:27
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: VEX Ultrasonic Sensor delay
Are you running the current version. The ultrasonic should not hang your code.
Adam
Unread 26-03-2006, 19:07
Unregistered User
FRC #0295
Yup - current version of EasyC.
I know it shouldn't hang the code. I'm assuming you mean you have experienced it working properly, and I'll take that as a good sign.
I just realized it doesn't seem like I'm even getting data - I have it outputting to the OI display and all it shows is u000 or an occasional u012. It has worked before, though (in a completely different program), so the sensor itself is not broken.
Unread 28-03-2006, 06:31
AKA: Brad
#0190 ( Gompei and the Herd)
Is it possible to try a short test program to make sure that the sensor is working the way it is installed in your robot. If you are seeing the delay in the short program, please post it and I'll try to reproduce and fix the problem.
Brad Miller
Robotics Resource Center
Unread 28-03-2006, 13:45
Unregistered User
FRC #0295
Thanks.
It may be a week or two now before I get the chance, but I will try that.
I appreciate your helpfulness.
Vex Ultrasonic Sensor not responding SomeoneKnows Programming 6 18-12-2007 16:48
Radio Shack to discontinue VEX? jeffmorris General Forum 52 24-03-2006 16:33
Vex navigation with ultrasonic and encoders GlennGraham Electrical 4 13-01-2006 12:58
VEX UltraSonic and Encoder SOLD OUT... Chris_Elston Electrical 5 09-01-2006 13:22
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
