Go to Post "Everything is possible. Just depends on how much it costs and how much physics you have to apply..." - Kimmeh [more]
Unread 13-03-2006, 05:54
gandhi gandhi is offline
gandhi is an unknown quantity at this point
CO2 & Pneumatics
Is it Safe to use an air compressor pressure gauge/ regulator with a 12oz CO2 tank? The CO2 tank is from a paintball marker. Attached to this post is a small diagram of how I would like to connect this system together
Unread 13-03-2006, 06:11
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Re: CO2 & Pneumatics
Well, paintball tanks are filled in the thousands of psi, also, unless you have a syphon tube in the tank, you get a little bit of co2 liquid that expands some what spontaniuosly (changeing pressure AFTER the regulator) So if the regulator is rated to handel 2000 psi on the inlet, go for it IMHO
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 15-03-2006, 22:29
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
hey, where did you get the regulator that you will be using. I have been searching all day for a regulator under 40 bucks that can regulate a CO2 tank?
oh, to answer some of your questions, my friend did research today, and if you regulate the pressure to 120 or lower you can use the same everything directly from the regulator with the FIRST pneumatics. The hosing can be used even before the regulator is the tank is below 3000 psi I think.
So, where did you get a regulator?
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 25-03-2006, 17:44
Umm Errr...
The tubing in the FIRST kit CANNOT handle 3000psi. Its only rated for about 120psi.
Will paintball stuff work on normal pneumatics stuff? Absolutely, and our team has done it before.
1139 Alumni
Unread 26-03-2006, 19:14
Andrew of FoN Andrew of FoN is offline
I wonder what would happen if....
AKA: Freddy D
FRC #0075 (RoboRaiders)
Andrew of FoN has a spectacular aura aboutAndrew of FoN has a spectacular aura aboutAndrew of FoN has a spectacular aura about
The statement that CO2 is under thousands of pounds of pressure is oncorrect. The average internal pressure of a CO2 tank is 850 PSI. The output of compressed air tanks for paintball is, on average, 800 PSI. You can buy various compressed air tanks with various output pressures (450 and 800). Or you can purchase an adjustable output tank. You have confused the internal storage pressure on a compressed air tank with it's output pressure.
Any regulator can handle and regulate CO2. It will not handle it as well as it would with compressed air, but it will handle it. Also, keep in mind that many of your higher priced regulators have high rehcarge rates, which means they can recover from a drop in pressure extremely quickly (50 milliseconds or less).
The CO2 should never reach above 900 PSI. Because it is self-regulating, a change in air temperature along with the consumption rate will effect the pressure. The greater the temperature, the greater the pressure. The greater the consumption rate, the lower the pressure. Now, in order to see any noticable difference in pressure through a difference in consumption rate, you would need to be firing your pneumatics extremely quicky for a long period of time. But, since this is going on a robot, you should not have to worry about that.
Now, your budget of $40 is alittle low. I will try and search around tonight for you and see if I can find anything suitable for your needs.
I hope this helps.
-Andrew
Unread 26-03-2006, 23:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Not nearly enough detail on what you're trying to do. Give me some requirements of what you need to accomplish and I'll you come up with something safe. What are you powering? What is the pressure required? What is the flow rate needed? There is a lot more to consider when working on gas powered systems.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 27-03-2006, 02:46
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I hope this helps.
-Andrew
Andrew, He may have been thinking of regular CO2 tanks which can easily reach many thousands of PSI. I have a tank in my basement for our bar style pop machine which when filled and the next month or two will run at over 1200 PSI.
Not just any regulator would work for high pressure. Pressure regulators DO have in many instances a maximum input pressure. Too high a pressure will destroy a regulator without much difficulty. Thus it must be designed for the pressure. For example, quick search on Google look at "Supply Pressure, Maximum"
Also, he never mentioned using this on a robot. The diagram does show a "resevoir" but this does not specifically mean a robot "reservoir".
This appears to be an idea to refill a low pressure relatively quickly from high pressure. Keep in mind that, if this is for a FIRST robot, the rules say you must use the kit compressor. See this thread
-Mike
Unread 27-03-2006, 07:38
-Mike
Also you need the right regulator for the type of gas to get a bottle filled. The Compressed Gas Associaion (CGA) has standard fittings for regulators that differ depending on the gas type. This is mistake proofing to prevent things like mixing an oxidizer with a combustible.
Thank-you 294 & 67
Unread 27-03-2006, 17:57
AKA: Freddy D
MikeAA- Thank you for the correction. I got alittle caught up in their paintball confusion and I got stuck on that point. I should have clarified that I was refering to regulators that can be found in the paintball industry.
I guess next time I should make such a post right after I get home from a Regional
Thank you once again Mike
-Andrew
Robot Builder and a Guy who needs more sleep
Team 75- The Revolution has started!
"It's close enough"
pneumatics for 2006 competition? Joobacca Pneumatics 10 21-01-2006 23:14
Using previous years pneumatics? ChuckDickerson Pneumatics 0 30-01-2005 18:22
pneumatics and joysticks Jared Stofflett Pneumatics 3 24-02-2004 23:56
pneumatics and joysticks Jared Stofflett Programming 1 24-02-2004 17:45
'IT' info... archiver 2001 19 24-06-2002 01:58
