#28
Re: How does your auto-aim work?
Our auto aim works similar to 696s but the camera is directly mounted to the shooter, our brain just goes "Where are we?" followed by" Where does the camera say we want to be?" and then using the error computed from that, runs through a P, I, and D formula with their own specific gains (some of them very low) set, then we run sanity checks on all the values to make sure they're sensible, add them up, check that (We're so paranoid ) before returning it from our aiming function, then, depending on mode it's either use to drive the Heads-Up display, the pan motor, or both.Firing consists of three modes: Manual - Camera feedback drives LED HUD on operators safety glasses, operator can start firing checklist at will, pan control is handled by a dial on controls representing absolute position, no auto-targeting. Semi-Auto - Camera feedback drives pan motors to maintain targeting on goal, drives LED HUD on glasses, operator can start checklist at will, auto-targeting, no search. This mode is currently not implemented due to a few reliability issues. Auto - Camera feedback drives pan motors to seek and maintain targeting with search algorithm, drives LED HUD on glasses, checklist constantly cycling and firing when completed, auto targeting and search within current field of view. The checklist runs through a series of sensor checks to make sure the system is ready to take a shot: 1. Is there a ball in the firing mechanism? (Optical beam sensors) 2. Is the piston in ready position? (Reed switch) 3. Are the impeller wheels up to speed? (Tachometer/DC Motor from kit) 4. Do we have permission to fire? (Firing button still pressed/Auto fire mode) 5. Are we on target? (Camera/Overridden in manual mode) We use manual mostly while in driver mode because our operator responds to changes faster than our conservative PID control (we slowed it down for system stability, working on improving that as well) whereas our autonomous mode, at least a few of them ;-) uses the camera based Automatic Mode to acquire a lock and score during autonomous. It worked pretty well, in the semifinals and quarterfinals of SBPLI we were rammed several times in autonomous, the turret corrected and continued scoring. The heads-up display are two bright LEDs mounted so they're on the edge of our operators peripheral vision, they indicate to which side of the turret the target is on, in other words, which way to turn, both light when on target, neither light when the target is not visible to camera and they blink back and forth rapidly if communications with the camera fail. |
| What Artist Influence You? | Koko Ed | Chit-Chat | 12 | 01-12-2006 11:33 |
| Springs and Work | sanddrag | Math and Science | 11 | 17-05-2005 18:35 |
| (part II) We aim for the stars | Ken Leung | General Forum | 6 | 03-05-2005 16:57 |
| Who knows how the motors [I]really[/I] work? | Wetzel | Chit-Chat | 5 | 13-02-2002 21:50 |
| Does anyone on this board work at home depot? | mnkysp6353 | General Forum | 2 | 30-12-2001 13:27 |
